| 05-05-2016, 05:03 PM | #1 |
4697
Rep 57,783
Posts ![]()
Drives: F80 M3
Location: Santa Barbara, AP Racing, Brembo, GIAC, Nitron, Ohlins, Pagid, www.hpautosport.com
Ohlins Road and Track F87 M2 BMS MR40S1
This is the latest step in the Öhlins Racing automotive philosophy for your F87 M2. With almost a 100% certainly that the purchaser has the options to choose spring rates for these new kits.
– Road&Track by Öhlins. A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrifi cing comfort in your day-to-day transports. The time of compromises is over! We have also added a clever light-weight design with a majority of the parts in aluminium and on top of that all shocks have suffered through vast corrosion tests according to ISO 9227. The end result is a 2-year limited warranty on all of our products - worldwide. FEATURES www.roadandtrackbyohlins.com General Front Rear > DFV (Dual Flow Valve) > Rebuildable > Corrosion salt spray tested (ISO 9227) > 2 year limited warranty > McPherson strut > Single bleed adjuster > Spring preload adjuster (approx. 10 mm lower than standard) > Coil springs 90 N/mm > Dustcovers > Use with original top mounts > Conventional shock absorber > Single bleed adjuster > Separate spring preload adjuster (approx. 10 mm lower than standard) > Coil springs 190 N/mm > Dustcovers > Use with original top mounts or your choice of camber plates currently available PART NO: BMS MR40S1 • CHASSIS CODE: F87 We can fill the gap Ohlins left behind with Swift springs. More details here with pricing: http://f87.bimmerpost.com/forums/sho....php?t=1258532 Last edited by HP Autosport; 07-06-2022 at 12:06 PM.. |
| 05-05-2016, 11:43 PM | #2 |
4697
Rep 57,783
Posts ![]()
Drives: F80 M3
| 05-12-2016, 05:14 PM | #5 |
4697
Rep 57,783
Posts ![]()
Drives: F80 M3
| 05-15-2016, 03:30 AM | #6 |
![]() 1774
Rep 1,679
It says; $3.453
I see also the 2 years limited warranty. In that case I prefer JRZ, price about the same, but longer warranty |
M3 Adjuster7903.00 |
| 05-15-2016, 10:32 PM | #7 |
4697
Rep 57,783
Posts ![]()
Drives: F80 M3
Ohlins R&T's are very robust. I can't recall a single warranty claim ever since becoming an Ohlins Premier Dealer in 2009. As a JRZ dealer I am afraid to make that statement. Longer warranty is excellent, but taking the strut/shock off the car for warranty work is always a hassle.
| 05-16-2016, 03:37 AM | #8 | |
![]() 1774
Rep 1,679
I had my fair share issues with the JRZ-RS1, but I have to say it was solved all under warranty, the best service I`ve ever encountered in my automotive history. I can not in any way share experience on the Ohlins, I know they have an outstanding name and record, but I`ve never tried them myself. It is only the warranty and unbelievable good, outstanding service at JRZ that forms my decision to go for JRZ again. They will do anything to keep the customer satisfied ! |
| 05-16-2016, 04:20 AM | #9 | |
Rep 4,775
Current '22 X3M LCI.. ![]() |
| 05-16-2016, 07:02 AM | #10 |
4697
Rep 57,783
Posts ![]()
Drives: F80 M3
| 05-19-2016, 11:30 AM | #11 | |
7903
Rep 11,785
| 05-22-2016, 02:48 AM | #13 |
4697
Rep 57,783
Posts ![]()
Drives: F80 M3
Ohlins is an excellent choice when directly bolt on, minimum increase in NVH and the least amount of tinkering after installation is the goal.
| 05-24-2016, 12:12 AM | #14 |
4697
Rep 57,783
Posts ![]()
Drives: F80 M3
| 05-31-2016, 11:19 PM | #15 |
Rep 3,473
Drives: Harrop E90 M3
Is there any data on the spring rates on these coils? Compared to stock would be great. TIA
| 06-01-2016, 12:24 AM | #16 |
4697
Rep 57,783
Posts ![]()
Drives: F80 M3
| 06-04-2016, 07:21 PM | #17 | |
CalcioGuy
50
Rep 124
Waiting for my 2019 M2 Comp. in september!
| 06-07-2016, 02:54 PM | #18 |
4697
Rep 57,783
Posts ![]()
Drives: F80 M3
| 06-07-2016, 04:52 PM | #20 |
4697
Rep 57,783
Posts ![]()
Drives: F80 M3
| 08-23-2016, 01:55 PM | #22 |
4697
Rep 57,783
Posts ![]()
Drives: F80 M3
| Bookmarks |
