04-24-2016, 06:31 PM | #1 |
Rep 119
Drives: M2, F10 M5, E46 M3, E90 M3
TuningTech FS BMW M2 Dyno Tuning & Testing (ECU Flash)
Featured on BIMMERPOST.com Seeing how we posted one of the first dyno runs in United States, we were not sure what to make of the power. But the car made strong consistent numbers back to back. Other vendors who we all love and respect such as the guys at iND and Active Auto put identical numbers showing the car M2 is consistent across the country which was good to know that BMW got it together. We installed a custom down-pipe on our car and the gains were fairly decent perhaps because the car had less than 500 miles and was flowing very well. The car showed 15 psi stock and we modified the factory ecu with our stage 1 tune to 17 psi. The M2 like the M4 and M5 platform is very much tuneable especially when the computer is not being tricked with piggyback that hits torque limiter or require a back end flash that requires an ecu to be taken out of the car just like ecu tuning. This motor is very strong and it does not heat soak. We did a number of back to back hard runs and the car was very consistent and impressive. One of the benefit of ecu tuning is you can tune it on 91 or 93 without having to worry about the car pull timing and drop boost because the vehicle does not like the fuel in the car etc. We are expecting to raise the boost to 20 psi for our stage 2 tune once she reached 1k because we have noticed as the car breaks in more the numbers appear to be get stronger and we got a little lazy working on a Sunday morning. We did some testing with 93 fuel and doing a E85 blend for a E30 mix on the dyno back to back from our initial back to back 93 runs. The car gained very little after several back to back runs. Please note we did not change the ecu parameters at all simply look for consistency of power and fuel mixing blend possibilities. In fact the car had a dip in the power after the addition of e85 blend. We believe the blend may help keep the power from dropping due to its cooling characteristic on very hot summer days, but it did not gain as much as we had hope and others have assumed. We are confident we can custom tune the factory ecu with down-pipe close to the 450whp range. Please be patient as we are eager to get the car fully tuned. The car will be at Wannagofast in Hot Springs VA were our shop M2 will be raced in the 1/2 mile rolling event. I know threads like this tends to create a lot of opinion, while we all respect everyone thoughts lets keep it civil. Here is a where the magic happened and the runs. 93 Octane Runs 93 + E85 Blend 93 vs Blend on the same graph |
04-24-2016, 10:39 PM | #4 |
Rep 119
Who has tuned a factory ecu M2 stateside for them to believe. Our car bone stock with less than 20 miles read 337 whp, Burger ran the car at 330whp, AA ran it at 331 whp, AMS dyno done by iND ran it 336 sae.
The result are what they are when people are blindsided by piggy back that's all they have to compare. |
04-24-2016, 10:47 PM | #5 |
Rep 119
04-25-2016, 08:37 AM | #7 | |
Rep 2,400
Out of curiosity, have you flashed tuned a 235? And what were the results? Obviously, a flash tune has many potential advantages, but generally speaking, they're not 20-30 whp advantages...or at least not that we've seen on this platform before.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
04-25-2016, 09:00 AM | #8 |
Rep 2,809
2016 BMW ///M4 ZCP - President / Master Calibrator | JordanTuned, LLC (www.jordan-tuned.com)
IG and Twitter: @CaryTheLabelGuy |
04-25-2016, 09:24 AM | #9 |
Rep 2,400
Your an F80 guy. Do you recall why TTFS's M3/M4 dyno threads got deleted?
04-25-2016, 10:18 AM | #10 | |
Rep 2,809
No but seriously, I have no clue. Maybe they weren't official vendors at the time? That happens a lot.
04-25-2016, 10:36 AM | #11 |
Rep 1,963
This is my guess.
Current
AW BMW M2 Past VO BMW 1M |
04-25-2016, 11:28 AM | #12 |
Rep 1,153
TTFS--
This looks more promising than I thought it would given early returns. But what is the significance for those of us in non-93 states? Some of us live in Washington, for example, which is a 92 state.... |
04-25-2016, 11:34 AM | #13 | |
Rep 119
Thanks David, I see the Active Team is right up there too
04-25-2016, 12:30 PM | #14 |
IG @bmwF9xG80
3807
Rep 7,587
Great work TTFS
A few questions just to make sure, these runs were with your DP + Stage1 tune only or just the Stage1 increase to 17psi boost ? Your type of Dyno "Dynocom" reads like or higher than a Dynojet ? Do you think the E85 Blend required a bit more to fully adapt and maybe show a bit more gain ? I saw Terry dyno'ed 394whp/456wtq with E30 blend on a piggyback with 17 psi if I'm not mistaken. Since I know you guys are currently testing/working still, have you tried to Dyno on 18-20 psi as well to see what number yields before DP or after DP ? Just for curiousness and seeing how the curve looks on the dyno ? In terms of ECU Flash, what parameters are being edited at the moment? Is it similar than like the N55 you have seen ? etc
60-130mph 6.5s X4M #HCP
04-25-2016, 12:40 PM | #15 | |
Rep 1,963
Current
04-25-2016, 03:14 PM | #16 |
Rep 3,942
Can the top speed limiter be raised or removed with the flash?
04-25-2016, 04:16 PM | #17 |
Rep 327
Drives: Ex BMW owner, will return soon
Great numbers but as I know nothing of fuel types, only that in my country they use 95 or 98, would it make less power?
04-25-2016, 08:15 PM | #18 | |||
Rep 119
Frank does all our tuning so we would have to comment on the parameters feel free to email him. info@tuningtech Quote:
Yes. Quote:
95 Ron is 91 Octane |
04-26-2016, 12:12 AM | #19 |
Rep 343
TTFS is more than legit guys. Go over to M3F and see everything they have done for that community.
As a long time E46 M3 owner, I always planned to go FI eventually and use TTFS, but the F87 called my name. Can't wait to see what you guys do with Pure Stage 2 etc etc. |
04-26-2016, 02:36 PM | #20 |
Rep 998
Personally, I think the engine was the least attractive part of the new M2 (same engine as m235i). Would definitely be a killer with a bigger turbo and more cooling though
04-26-2016, 02:46 PM | #21 |
Rep 4,490
In UK (and perhaps the rest of EU) bmw quoted crank power/torque outputs of 370 and 343/369 are based on 98RON.
Anything above about 325whp on 93 USA/98 EU fuel means the cars hitting quoted figures. I'd be sceptical about dyno claims achieving the same whp on 91US/95 EU fuel as it implies there's no DME corrections for lower grade fuel - I estimate higher fuel grade to be circa 15-20 bhp at the crank. BP |
04-26-2016, 02:56 PM | #22 |
Global Moderator
6377
Rep 2,309
Drives: E90 M3 6MT
2011.5 E90 ///M3 | 6-Speed Manual | Slicktop | Jerez Black | Fox Red
E9x M3 Press/Media Archives Thread | S65-based Racing Engines Thread |
8
AndrewC198910902.00 |
