01-28-2016, 11:21 AM | #1 |
Dinosaur supervisor
3030
Rep 4,214
M2 M Performance suspension info (German)
Here is the full info and price in German...
From: http://www.1erforum.de/threads/m-performance-gewindefahrwerk-f87-m2.225684/ Die Nachrüstung M Performance Sportfahrwerk für BMW M2 Modelle erhöht die fahrdynamische Leistungsfähigkeit der Serienfahrzeuge deutlich. Die zusätzliche Fahrzeugtieferlegung (Gewindefahrwerk) sorgt nicht nur für ein dynamischeres Fahrgefühl, sondern verstärkt auch das sportliche Erscheinungsbild des Fahrzeuges. Die Dämpferkraftverstellung erfolgt separat für die Zug- & Druckstufe. Die verstellbaren Dämpfungskomponenten bieten verschiedene individuelle Fahreigenschaften für Fahrdynamik und Komfort. Verkaufsargumente/Vorteile
Lieferumfang
33 50 2 413 033 1.962,18€ netto Einbauzeit ca. 5,0 Stunden Verfügbar ab Ende März |
01-28-2016, 12:20 PM | #4 |
Rep 146
01-28-2016, 01:25 PM | #5 |
Rep 536
Here is the full info and price in German ... From: http://www.1erforum.de/threads/m-per...f87-m2.225684/ Retrofitting M Performance sports suspension for BMW M2 models increases the driving dynamics performance of production vehicles significantly. The additional lowering of their vehicle (coilover) not only makes for a more dynamic driving experience, but also reinforced the sporty appearance of the vehicle. The damping force adjustment is done separately for the rebound and compression damping. The adjustable damping components offer various customized for driving dynamics and comfort. Sales features / benefits
This even sportier suspension tuning is an excellent roadholding achieved. Pronounced neutral handling and significantly reduced Wank-movements of the vehicle body. A much more direct connection of the vehicle body to the road increases driving dynamics significantly. Improving performance especially in highly dynamic driving style. Visually attractive black stainless steel muffler with red coil springs and blue spring plates. Compared to the competition The coilover kit is with the experience of professional tailored test drivers. The tests were carried out on a plurality of race tracks. The chassis was also used for various road conditions designed. The sport suspension is designed to inspired from racing to driving dynamics for everyday road use offer. The choice of materials was carried out under the guidelines, best durability and corrosion resistance to series level to offer. Functionality The height adjustment provides an adjustment range between 5-25 mm (5 mm lower than original equipment). Independently adjustable damping technology for rebound and compression stage (16 settings options Rebound / 12 setting options of compression damping). High-quality damping components for a long life. Delivery 2 stainless steel complete with height-adjustable spring plate struts for the front axle 2 dampers for the rear axle 2 individual springs with height-adjustable spring plate behind Mounting Accessories Set preparation see EPC. 33 50 2 413 033 € 1,962.18 net installation time ca. 5.0 hours Available from the end of March |
01-28-2016, 02:59 PM | #7 | |
Rep 450
'74 2002tii, Sienna Braun Metallic, Manual, Sold; '84 e28 533i, Burgundrot Metallic, Manual, Sold; '95 e36 M3, Avus Blau Metallic, Manual, Sold; '06 e60 M5, Silver Grau Metallic, SMG, Sold; '09 e82 135i MSport, LeMans Blue, Manual, Sold
01-28-2016, 04:18 PM | #9 |
Almost completely sane
694
Rep 1,080
I read somewhere that BMW will provide recommended setups for well-known race tracks.
Looking forward to seeing those.
'17 BMW M2 (BSM 6MT Exec CarPlay, TechnicPnP ASD bypass, IND M Perf shift knob + keyhole cover, Pedal Haus pedals + heel plate, 3M CR90 tint, BavSound Ghost woofers, Racing Dynamics strut tower brace, Dinan midpipe, Turner intercooler)
'00 Honda S2000 (Silverstone Metallic, black leather, factory titanium shift knob + front lip + trunk spoiler, front shock tower brace, front subframe x-brace) |
01-28-2016, 05:11 PM | #10 |
476
Rep 1,711
So, do we still have to pay for installation if we order the car with this suspension?
Here is the best answer I could find to my own question: "BMW has stated that M Performance Suspension will come out in April. We really won't know that detail until it is time to order" Last edited by Groundpilot; 01-29-2016 at 01:38 PM.. |
01-29-2016, 01:52 AM | #11 |
Rep 8,160
So it's based on KW V3's and costs roughly the same. A little bit more expensive than M235i V3's and a bit more cheaper than M3 V3's.
No reason to buy original KW's IMHO. |
01-29-2016, 04:23 AM | #12 |
Croatian
884
Rep 3,613
Drives: PORSCHE
Need this.
NARDO GREY '18 PANAMERA TURBO
Ducati V4 S Corse (track only) Husqvarna FS450 (track only) Looking for an SUV |
01-29-2016, 04:45 AM | #13 |
Dinosaur supervisor
3030
Rep 4,214
Exactly. Sounds like the best solution. Basically a KW3 developed by BMW M with full warranties for the price of the normal KW item.
02-12-2016, 12:17 AM | #14 |
Rep 2,214
02-12-2016, 02:43 AM | #15 |
Rep 209
How easily can the suspension settings be tuned?
I hope compression and rebound have some kind of easily accessed knobs or screws. I would hope that only ride height adjusmtents would require the wheels to come of |
02-12-2016, 06:31 AM | #16 | |
Dinosaur supervisor
3030
Rep 4,214
You can change ride height without removing the wheels too if you have access to a lift and turn the wheels right/left depending on which side you are working on. |
02-12-2016, 06:36 AM | #17 |
Rep 1,136
Are these settings manually adjusted:
Independently adjustable damping technology for rebound and compression stage (16 settings options Rebound / 12 setting options of compression damping). High-quality damping components for a long life. If not it's off to the friendly stealer but could get pricey until the "best" setting gets discovered... |
02-12-2016, 07:31 AM | #18 | |
Dinosaur supervisor
3030
Rep 4,214
BMW will provide a recommended street setting and also a few different track settings (at least for the US). You don't have to go to the dealer to change the settings. You just do it yourself, I don't know where the rear shocks are adjusted but hopefully at the bottom so you don't have to tear down the interior in the trunk. |
02-12-2016, 07:55 AM | #19 | |
Rep 1,667
In this app age it would have been logical to make adjustments by iPhone, now that is what I would have called progress! |
02-12-2016, 08:47 AM | #20 |
Rep 1,136
02-12-2016, 08:55 AM | #21 | |
Dinosaur supervisor
3030
Rep 4,214
When you have a set height it is quite easy to change the settings with the knob from street mode to track mode when it is necessary. No need to use the same setting on the road and track if you don't live in a country where the roads are kept smooth like a race track. |
02-12-2016, 10:37 AM | #22 |
Rep 8,160
Jesus. They don't even want to get their hands dirty these days!
If you want to use an app, buy KW DDC or the aforementioned Bilstein IRC. It's not like you're gonna play with the adjustments every single weekend. Factory settings are fine for most... |
