12-16-2015, 08:03 PM | #1 |
Rep 1,644
CAR Magazine Article - Interview with M2 engineers
Featured on BIMMERPOST.com Info is from interviewing the engineers who worked on the car. You'll need to register for a free account to read. MAKE SURE YOU SAVE THE PAGE SINCE YOU ONLY GET ONE LOOK PER FREE ACCOUNT. Highlights:
12-17-2015, 01:07 AM | #3 |
Rep 8,165
You've reached your article limit
and yet I had not read anything. Agreed about the Fahrerlebnisschalter. There should be just an option in iDrive to change the DCT shift times. It can't be difficult to program it into the system. |
12-17-2015, 03:01 AM | #4 |
Rep 233
Ripped out sound deadening material to reduce weight? Haven't seen a lot in the way of weight reduction and now I'm wondering how noisy this thing will be.
12-17-2015, 04:20 AM | #5 | |
Dinosaur supervisor
3030
Rep 4,214
Maybe we can code the speeds, sucks otherwise. |
12-17-2015, 08:05 AM | #6 |
1130
Rep 4,686
Drives: L'Orange
so does the M2 have the M3 chassis components and subframes like the 1M had from the E9X M3?
no mention of that at all.... I'm curious why the M3/4 tires wouldn't fit if they had the same hub and underpinnings. The 1M used the exact same spec as its M3 counterparts. |
12-17-2015, 08:28 AM | #8 | |
Rep 1,644
12-17-2015, 09:14 AM | #9 | |
Rep 2,924
In addition, a racing derived rigid connection, without rubber bushings, is used to fix the lightweight steel gridtype rear axle subframe to the body. Not sure if it means same M3/4 subframe. |
12-17-2015, 09:40 AM | #10 |
Rep 341
12-17-2015, 10:02 AM | #11 |
Rep 1,644
A couple of more notes:
-The M2 should be more stable at the limit than the 1M. This was due to them not having enough time to calibrate based on using a turbo motor. -One of the guys they interviewed said he prefers the M2 over the M4 bc its smaller and could potentially be faster through a slalom. This car is very much an M4 under the skin from what they said. Just not getting the twin turbo, fancy gadgets, or weight reduction. I interpreted the lack of CF parts as being not worth the cost for low volume production car when they could save decent weight by removing sound material. |
12-17-2015, 10:31 AM | #12 | |
Rep 2,370
12-17-2015, 10:37 AM | #13 |
1130
Rep 4,686
Drives: L'Orange
Not really. To me this car is the "1M, part 2" so the comparison is really a crucial part of the evaluation of the M2. It's funny to me how people are trying to separate the M2 from the 1M but in reality this is an attempt to recreate the 1M. I think the M2 is just about the only car in the BMW lineup worth considering so i appreciate it; but i'm wondering HOW the M2 is selling for cheaper than the 1M in the australian market and what costcutting BMW have done to keep the price down here. I don't need to find 1M advantages....there are already many :P Last edited by IEDEI; 12-17-2015 at 10:53 AM.. |
4
12-17-2015, 12:06 PM | #15 |
Rep 9,788
12-17-2015, 12:33 PM | #16 | |
Rep 2,672
The M2 compares better to M4 and M235 as it appears it is a derivative of F8x M3/4 and M235 based on the parts and s/w used. I would say the 1M was a derivative of E9x 335/M3. |
12-17-2015, 12:35 PM | #17 |
Rep 846
12-17-2015, 12:47 PM | #18 |
1130
Rep 4,686
Drives: L'Orange
Ah very true....however that tire rub only happened with the winter setup on the 1M. I had to have my liner replaced (free of charge) so my winter wheels would stop rubbing. I never felt any rubbing with the 'stock' tire/wheel setup though......right?
12-17-2015, 12:56 PM | #19 | |
Rep 212
12-17-2015, 01:02 PM | #20 |
Rep 334
I dont understand this following part, can some1 pls explain?
"The M2 should be more stable at the limit than the 1M. This was due to them not having enough time to calibrate based on using a turbo motor." thanks! |
12-17-2015, 01:03 PM | #21 |
Rep 1,644
From the article: "The 1M rode like it had ants in its pants, and you caught its oversteer more with punches than steering inputs. I ask if that feistiness was intentional, or a by-product of the M melting pot. ‘By-product,’ confirms Isenberg. ‘We were still learning with the turbocharged engine. For the M2, the ride is much more compliant, and it’s not so tricky at the limit."
12-17-2015, 01:08 PM | #22 | |
Rep 13,104
///M is art ↔ Artemis
