BMW M2 Forum > BMW M2 Discussions > Driving modes (Comfort, Sport, Sport+, MDM & DSC OFF)
      08-01-2019, 06:34 PM   #67
David.m
Drives: M2 LCI 6MT BSM
Originally Posted by akkando View Post
I feel the same way. They're might be a way with a flash tune to force sport throttle in every mode or sport shifting in every mode. Pretty sure you can do the throttle mapping at least. Then traction/MDM mode would have what you want because it uses sport shifting if you're picking the gears yourself.
Anyone know if it’s possible to code in Sport throttle permanently? I feel it’s closest to old fashioned cable accelerator but I want MDM as well.
      08-21-2019, 04:07 PM   #68
Bosozoku
Almost completely sane
Bosozoku's Avatar
Drives: '17 M2, '00 S2000
Originally Posted by ajvdh View Post
At least for the OG M2, DSC off gives you "sport" throttle mapping, not "comfort". There's a handy chart from BMW which shows that. You can also confirm it by switching between modes.
I agree totally with you about "sport+", it's useless for anything other than roasting tires.
Thanks for the tip!
I guess with DSC off, BMW expects us to be good enough to handle a little instability and to appreciate the quick throttle response. Eventually I'll run with DSC off on track. (Maybe at Laguna Seca next week.)
P.S. And yes, "Sport+" throttle is just there to impress customers on test drives. Not good for your clutch, unless you have an ultra-light setting on your right foot (if 6MT).
'17 BMW M2 (BSM 6MT Exec CarPlay, TechnicPnP ASD bypass, IND M Perf shift knob + keyhole cover, Pedal Haus pedals + heel plate, 3M CR90 tint, BavSound Ghost woofers, Racing Dynamics strut tower brace, Dinan midpipe, Turner intercooler)
'00 Honda S2000 (Silverstone Metallic, black leather, factory titanium shift knob + front lip + trunk spoiler, front shock tower brace, front subframe x-brace)
      12-14-2019, 02:24 PM   #69
UnknownKnown
Drives: 2020 M2C
Does this chart apply to the M1/M2 buttons?
For example, MDM sets the throttle response to "Comfort".
But I can have M1 be with MDM and throttle response set to "Sport+". Does the M buttons override the rules on the chart?
      12-14-2019, 04:30 PM   #70
akkando
akkando's Avatar
5865
The chart I think is for the n55 m2 not m2c.
That said I believe the m1 and m2 buttons are just to store your preferred settings on one button unless you say you don't want a setting to override. So if you set m1 to mdm on, fastest shift, slowest throttle response, comfort steering, then that's exactly what you get when you press it.
If you set m2 button to DSC off, medium shift, don't override throttle, and don't override steering then it will set the settings you chose an not override your current settings for the ones you said don't override. So if it was in sport steering then it will stay in it, if it was in comfort steering it won't change when you hit m2.
      01-18-2020, 05:52 PM   #71
evonick
Drives: BMW M2 F87
What I don't understand, is what the table means by Chassis. Since the M2 doesn't have adjustable suspension, what does Chassis mean? Iow, apart from DSC/MDM stuff, does the Sport button do *anything* except change the throttle map?
Btw I have a manual car.
      01-18-2020, 07:44 PM   #72
boostm3
boostm3's Avatar
683
Drives: '18 LBB M2 6MT Exec
Yes.. increases the engine sound, pops, and crackles.. And of course, it quickens the throttle mapping for a more responsive ride.. In this car 'chassis' would refer to the steering, which you can make stiffer if you choose.
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17
      06-19-2020, 02:51 PM   #73
DCrew
Originally Posted by CosmosMpower View Post
What modes and situations cause the exhaust flap to open?
I'm bumping this post because I'd like to know the answer to this too. Anyone know? My exhaust sounds the same regardless of modes while idling, so wondering if it's working right or it is designed to open only under certain conditions.
Cheers -
      06-21-2020, 06:21 AM   #74
tranck
tranck's Avatar
501
Drives: 2018 Alpine White BMW M2
2018 M2  [0.00]
Cheers -
Put the car in Comfort Mode and turn the DSC off which will open the exhaust fully.
Go to a parking garage - drive to about 3K RPM in 1st gear - let off the gas and...
You will hear a glorious sound.
Do the same in Sport Plus and you'll hear the difference.
      06-21-2020, 01:27 PM   #75
akkando
akkando's Avatar
5865
Cheers -
The modes are exclusive and can't be combined. There's no comfort mode AND something else.
Activating MDM mode with a quick press of of the DSC button will make the exhaust pop more, but it can't be combined with anything.
The only exception really is sport mode can configure the tightness of the steering wheel and reduced throttle response.
M2C On the other hand offers more ways to configure things like shift speed etc.
      06-23-2020, 05:41 PM   #76
DCrew
I should have been more specific. Let’s set aside traction mode — I hear no difference between comfort, sport, and sport+. Are there specific throttle or driving conditions where the baffles open in sport and sport+? Thanks —
      07-11-2020, 08:14 PM   #77
Bosozoku
Bosozoku's Avatar
AFAIK, the biggest audible difference is more lift-off burbling as you increase the sportiness of the setting.
Also I think the muffler is bypassed (flaps open?) for more noise in Sport and Sport+. Not sure though.
My guess is that this is not just to make the car sound cooler, but to also make the throttle response
quicker if you lift briefly to counter steer, then get right back on the throttle. The fuel keeps flowing
for a second or two so the engine is still ready for the next throttle press, and that extra fuel explodes
in the exhaust system. So you get the throttle-off burble. And immediate power within the first inch of throttle
pedal travel.
All of which makes the car livelier and more fun. Fine and good at low to medium speeds.
But if you're really pushing it at the limit in a fast turn, you probably don't want twitchy hair-trigger
throttle response. All the driving instructors and racers say you're supposed to gradually apply power as you
hit the apex and track out so you don't transfer too much weight off the front tires and plow or - more likely -
kick the rear end out because you've exceeded the rear tires' traction limit.
I'm thinking "Traction Mode" uses the Comfort throttle mapping because of that. Makes the car feel
sluggish on the road, but makes it smoother and more controllable on the track. You can maintain traction
more easily at the limit.
Just my $0.02.
      07-11-2020, 09:43 PM   #78
Killed by Death
Killed by Death's Avatar
12656
Drives: '23 X3 M40i
Sorry but Comfort is for Pu$$ies...Yes I've had a few so please indulge me
      03-09-2021, 03:08 AM   #79
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
326
Drives: 2018 BMW M2 LCI
So what's the most extreme setting.... Sport + w/ the DSC long press?
With Comfort and DSC (short press) is MDM.... that's just Comfort but w/ the noises? What if you have the MPE and you had that open? Same thing?
      10-27-2021, 08:06 PM   #80
ZPrime
I INDIC8
ZPrime's Avatar
Drives: 2018 LBB M2, 6MT
2018 BMW M2  [9.50]
No, you're not understanding here.
Each thing is basically its own mode, on an N55 / OG car.
Comfort
Sport (you can configure "engine" [throttle], "chassis" [steering weight] or "both", via the iDrive)
Sport+
DSC short press AKA "Traction"
DSC long press AKA "ESC OFF"
"The most extreme" depends on what you mean... noise? Throttle response? Amount of slip allowed?
The MPE behaves entirely independent of the modes (which is different from what happens with the stock exhaust). MPE gets its flaps opened or shut by the bluetooth controller. Stock exhaust (which only has a single flap, on the left side of the car) has the flap controlled by the ECU, and the flap opens and closes at different points in the rev range depending on engine load and what mode you're in.
      01-15-2022, 11:20 PM   #81
Angelanadine
Driving Enthusiast
10
Drives: BMW M2C
I hope this is the right place to post my question, but:
I drive my M2C in Sport Mode. Really don’t care for the automatic Rev matching. Is there any way to turn off the artificial rev matching without just fully disabling the traction control and various other ‘nannies’ completely? I prefer having the safety mechanisms engaged, I just really don’t want the rev matching.
TIA
      01-16-2022, 07:45 PM   #82
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
326
I think you meant “automatic” and not “artificial”. Coz that is not artificial, it’s real rev matching.
In my case I love it. I have read a few posts of people not wanting it also but sorry I have not read (or just don't recall) any on how it can be deactivated. Myb others can chime in.
      02-02-2022, 06:26 PM   #83
BallHog5873
BallHog5873's Avatar
176
Drives: 997.2 Manual, 2016 328D Wagon
TIA
not through the car itself. possibly through some after market software/tune.....
      02-02-2022, 06:28 PM   #84
BallHog5873
176
DSC long press puts the car back in comfort. you can't be in sport + with traction all off. Its a point of contention among all 2 series owners. Possibly something that will be changed on the G87
      02-05-2022, 06:14 PM   #85
Angelanadine
Driving Enthusiast
10
Drives: BMW M2C
Any specific recommendations? Thanks
///M2C
///M Mom Car
      02-05-2022, 06:20 PM   #86
Angelanadine
Driving Enthusiast
10
Drives: BMW M2C
Yes, absolutely meant automatic, not artificial, thanks for catching that.
///M2C
///M Mom Car
      04-05-2022, 05:16 PM   #87
BallHog5873
176
I think you can through Bootmod3
      04-08-2022, 09:55 AM   #88
mrandoms
Drives: 2020 m2 comp
Anyone find the sport+ throttle map too "on/off" for track use? Are there any throttle tuning options?
