BMW M2 Forum > M2 Photos, Videos and Builds > Active Autowerke | M2 Build Documentation **Updated 7/13/16**
Closed Thread
      04-22-2016, 02:33 PM   #67
David@ActiveAutowerke
Originally Posted by Icsunonove View Post
It is correct. Check it out here http://www.rimsntires.com/specspro.jsp
OEM front is ET29, so ET33 is 4mm plus 15mm as the tyre goes from 245 to 275. Wheel width does not matter because the tyre increase is wider than the wheel.
But as you said, most likely 19mm will not clear.
You are correct about the et29 offset. The et31 I remember is from the 1M.
However, the stock 245 is stretched on the 9" wheel. If anything protrudes past the outside it will be the rim protector portion of the tire. I don't think that the rim protector of the 275 on the 10" wheel will stick out further than the protector of the 245 on the 9" wheel.
If you are comparing tread widths, the top of the wheel will have a 30mm total difference, or 15mm per side. However the widest part will still be at the rim or the tire protector on the rim.
That said, after doing a quick search I found a thread where they tested the 18x10 et33 EC-7 with 275/35/18 on a F82 M4 and they cleared the suspension. Seeing as the M2 utilizes a lot of the same suspension components the et33 with 275 might actually work.
      04-22-2016, 02:44 PM   #68
Originally Posted by rwalker View Post
Difference from what?
I think it is, because the top nut is the same as used on all the F-series cars.
Will you post pics? I'm looking for the possibility that it's an off-center mount, like the ones on the M4 GTS...
The M4 mount has 3 holes for the large aluminum strut brace. The M2 doesn't use that brace, but instead has a single bar that connects the mount to the firewall, similar to those on the E9X chassis.
I can snap a couple pics tomorrow morning for you. But if you're referring to the position of the shaft in the the mount, I know for a fact that it is centered.
      04-22-2016, 02:51 PM   #69
rwalker
Drives: the wheels off
Ok, makes sense. It's actually the same bracing as on all the other F3X and F2X cars, according to realoem.
Understood. Please do snap those pics, it'd be greatly appreciated!
      04-22-2016, 03:26 PM   #70
chris82
chris82's Avatar
Drives: 128i
2009 BMW 128i  [9.80]
Can't wait to see what you guys do with it! but I'm hoping those Volks don't make it onto the final unit
      04-22-2016, 04:17 PM   #71
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
David@ActiveAutowerke can you confirm on closed-deck block ? S55 or N55 turbo ?
Same TMAP/MAP as M235 so the Active8 fitted no problem right ?
I saw the Dyno 337/398 on your testing with box on, only 7whp+ gain but a whooping 54wtq+ before broke-in looks promising!
What would be the equivalent of this on dynojet ? 330/344 Mustang Stock around 355-360whp/365-375wtq ?
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      04-22-2016, 04:40 PM   #72
raysspl
raysspl's Avatar
992
Drives: walking, bicycle, & bus
Good gawd! Well done!
re
      04-22-2016, 07:06 PM   #73
F85MTuNED
IG: @88jae88
F85MTuNED's Avatar
1621
Drives: ///Ⓜ️
Solid work
IM POOR..
      04-22-2016, 08:28 PM   #74
Joshhleee
///M Enthusiast
Joshhleee's Avatar
Drives: '12 F30, '15 x5 5.0, '15 M4,M5
Nice. Can't wait!
-Josh
      04-22-2016, 09:12 PM   #75
Unforunately for us, but fortunately for you, the Volk offsets are too aggressive to work haha
We did not tear open the engine but yes we were able to get our Active-8 unit to work. We had to create a custom base map but we got it to work. We were seeing abnormally high IATs when adding more boost in the higher RPMs but once we get the car back from Sebring we will spending more time on the dyno tuning.
Originally Posted by BOOSTINJAE View Post
Solid work
Originally Posted by Joshhleee View Post
Nice. Can't wait!
-Josh
Thanks all!
      04-22-2016, 10:20 PM   #76
CanAutM3
General
CanAutM3's Avatar
21117
Drives: 2021 911 turbo
Loving the look with the EC-7s
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
      04-22-2016, 11:45 PM   #77
OrangeCrush
OrangeCrush's Avatar
1236
Drives: VO 1M #513/740
Me too.
Someone needs to throw the 11" et44 on back with 305's!
Current
AW BMW M2
Past
VO BMW 1M
      04-23-2016, 12:04 AM   #78
OrangeCrush
1236
Originally Posted by M3 Adjuster View Post
DCT - Pay more to get less.
Tell friends you will save .02 seconds per shift while car actually has 10 less hp all the way around the course.
Originally Posted by Robin_NL View Post
Agreed:
6MT=€6800,- more expensive(CO2tax), DCT is standard in the Netherlands.....
I'd rather go Dutch
*Help me out OrangeCrush *
Cheers
Robin
LOL. So far I am loving the DCT. Shifts are super fast and sounds awesome when in sport + and when accelerating hard the shifts kind of give you a good jerk but in a smooth way. And I love the blips when down shifting. I mostly use the paddles and am having a blast. When I feel like relaxing I put it in drive mode (auto) so I can enjoy my line of coke or my cheeseburger American style.
I loved my 1M and before I took possession of the M2 I was worried that had I made a mistake on transmission choice but as of right now, I'm hooked and not really sure if I would go back or not, if given the choice, especially if they keep improving it.
BTW, the speed of the shifts would more than make up for a 10 HP difference.
Current
AW BMW M2
Past
VO BMW 1M
      04-25-2016, 12:48 PM   #79
chris82
chris82's Avatar
Drives: 128i
      04-25-2016, 01:19 PM   #80
Gato Grande
Gato Grande's Avatar
Mexico
72
Drives: 2017 M2
Great. So you're only gonna run with 19s?
Great so
      04-25-2016, 01:21 PM   #81
Gato Grande
Mexico
72
Drives: 2017 M2
[QUOTE=Gato Grande]
Dropped. So you're only gonna run 19s?
      04-25-2016, 03:03 PM   #82
[QUOTE=Gato Grande;19821573]
This weekend we will be running the car in bone stock configuration. With the stock 19s and all. Our goal is to just get a solid average lap time without any modifications.
We plan on running a set of square 18s the next time around though.
      04-25-2016, 06:14 PM   #83
Gato Grande
Mexico
72
Drives: 2017 M2
[QUOTE=David@ActiveAutowerke;19822221]
can't wait………...
      04-26-2016, 06:08 PM   #84
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Looking forward to more !
IG: @bmwF9XG80
      05-04-2016, 01:50 PM   #85
Hey all! Sorry for the lack of updates but we were busy at the track this past weekend!
We had the car at Sebring and to be honest I think it's the most fun stock car I've driven around the track. The crew from BC Racing also came out to shoot some video so within the next week or so they should have some great footage of the car putting down some laps.
All in all the weekend went great, and the only issue we ran in to was with the brakes. The stock pads clearly are not track pads, and were not sufficient enough to even finish the weekend. We're already working on a brake solution and should have some more information soon enough.
That said, here's a shot of our M2 next to my student's M235i! I was able to drive the M235i and the M2 back to back so I'll have some comparison notes to add in to the full review once we get the video back from BC Racing. Stay tuned!
For a sneak preview of one of our Sebring laps, check out the video on our Facebook! https://www.facebook.com/ActiveAutowerke/
      05-04-2016, 02:45 PM   #86
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
Have you ever driven a stock 1M around a track?
      05-04-2016, 03:05 PM   #87
LBBDrew
Drives: 2017 LBB M2
Looking forward to the full write-up and more video footage. When you say the stock pads weren't sufficient, do you mean you wore through them already or just that they didn't provide enough stopping power? How many laps/hours did they last?
      05-04-2016, 03:51 PM   #88
Unfortunately I haven't had the opportunity to.
They felt great for about 4 laps. After that they start to fade to the point where I wasn't able to activate ABS at all and I'd get a long pedal. I also managed to kill the entire front pad set in about 25 laps.
We have some new race pads on order so we'll see how they do. I'm scheduled to be at Homestead Miami Raceway on the 14th.
Closed Thread
