BMW M2 Forum > M2 Photos, Videos and Builds > Active Autowerke | M2 Build Documentation **Updated 7/13/16**
Closed Thread
      04-21-2016, 06:26 PM   #23
MTHRAR
Drives: LBB M2
Is this car DCT or 6MT? Curious, as based upon the weight, I would assume 6MT.
      04-21-2016, 06:36 PM   #24
6ixSpd
Save the manuals!
6ixSpd's Avatar
6012
Drives: '16 M3, '23 718 Spyder
Lol. Bimmerpost with the typos.
'16 M3 | '23 718 Spyder
Past: E92 M3, F87 M2, E39 M5, etc
      04-21-2016, 06:49 PM   #25
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
Did I hear group buy pricing for the exhaust tips?
      04-21-2016, 06:59 PM   #26
TTFS
TTFS's Avatar
130
Drives: M2, F10 M5, E46 M3, E90 M3
Looks good boys keep it up -Justin
      04-21-2016, 07:04 PM   #27
inFamousKicks
Member.
inFamousKicks's Avatar
Drives: 2011 135i
Yes!
The car definitely needs 18s (with not such a low offset) and a drop. Looking forward to where this build is taken.
'11 N55 135i 6MT || ///M-Sport|| Alpine White/Coral Red|| KW V1
      04-21-2016, 07:22 PM   #28
Franklin Joseph
Drives: BMW
So what do you guys think of a good wheel size/offset (square setup) for the track?
would 18x10 et 25 work? (with suspension/camber)
thanks
franklin
      04-21-2016, 08:05 PM   #29
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
Subscribed.
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      04-21-2016, 08:07 PM   #30
Kr3st
Wheel Whore
Kr3st's Avatar
Drives: 2016 F80 M3
2016 BMW M3  [0.00]
Yea, it's 6spd.
2016 F80 M3: BBS FI-R | JRZ RS-One | ActiveAutowerke Full System including downpipes + Swain Coating | ActiveAutowerke Active8 | Maximum PSI Intake
^Build thread link | Instagram | Facebook
      04-21-2016, 08:26 PM   #31
wdeerfield
A family of bimmers
Drives: '18 G01 X3M40i
wow. the m2 can swallow wheels. i imagine some people who lower this thing will be putting 19x10s and 19x12s on it with some stretch and track guys will be doing 18x10 easily. with the power and size of this car and how it can handle, seems this is an evolution of the e46m3
love the white!
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills
      04-21-2016, 08:33 PM   #32
David@ActiveAutowerke
Originally Posted by JTO24 View Post
Great thread! Looking forward to your progress
Originally Posted by swagon View Post
EC-7 look good.
Looking forward to this build, and other tuner shops as well.
Thanks!
Originally Posted by kong24680 View Post
I'd like to see it with a set of zcp wheels
I think those would look great as well.
Originally Posted by DarkAgent View Post
subscribed
Originally Posted by Sean@PSI View Post
Sick as usual guys!
Thanks man
Originally Posted by Boss330 View Post
Look forward to more updates and lap times.
If the turbo is the std N55 (which it could be understood it is since the tech training manual doesn't list anything apart from the wastegate actuator as changed from the std N55 turbo), it makes sense that you experience high IAT's above 5000rpm and only could run 1psi extra boost above 5k.
Will be interesting to see if the turbo is at it's limit or if it's capable of supplying enough volume of air also with increased boost above 5k...
I think the turbo has more in it, but now I'm also thinking that there may be a torque limiting map in the ECU. We're going to try and bench flash the ECU to see if we can make some more reliable power.
Originally Posted by Pyrat 2 View Post
et22 front and rear? no rub? what tires sizes are you running? That's exciting. I'm aiming for 265 front and 285 rear.
No, the et22 was too aggressive. The goal is to run 275/35/18 square, and I think we'll need to be closer to et30 with some camber up front to make it work.
Originally Posted by Car22 View Post
Volks look good!
Originally Posted by phoenx View Post
The pic with the te37's has me really questioning my recent m3 purchase lol.
I'm a sucker for TE's as well!
Originally Posted by DS_BMW View Post
So about 70 whp less than the s55.
The S55 actually makes about ~380whp on our dyno, so our M2 is only about 50whp behind.
Appreciate 5
      04-21-2016, 08:37 PM   #33
ASAP
ASAP's Avatar
10131
Drives: '23 X3 M40i
That's exactly what it sounds like...
      04-21-2016, 08:39 PM   #34
6MT.
Maaaaaybe. Andrew put up a thread in the sales section. I'll get with him tomorrow to see what we can do about intro pricing for the M2 tips.
Thanks Justin! I heard you guys have some stuff in the works as well!
Originally Posted by inFamousKicks View Post
Yes!
The plan is a square 18" setup with 275/35/18.
thanks
franklin
We haven't quite spec'd all of that out yet. Ideally we want to run 275/35/18 square with 18x10. I think et25 will be too aggressive though. From what I can tell the rear will need to be closer to 35 and the front will need to be closer to 30 with some camber.
With a street tire we'd like to run close to -2.5* camber up front and -1.5* in the rear but we'll see what's necessary to fit the wheel/tire combo.
Originally Posted by m5 guy View Post
Subscribed.
Originally Posted by Kr3st View Post
Yea, it's 6spd.
DCT is so 2015.
love the white!
The rear will fit a pretty big wheel/tire. There isn't as much room as the M4, but with the stock wheel and tire there is about 20mm of room on the inside between the tire and the shock, and I'd say about 15mm of room on the outside.
      04-21-2016, 08:50 PM   #35
bernstem
bernstem's Avatar
Those Volk TE37s look great! I really like the 18 inch look and beefy sidewalls.
      04-21-2016, 10:10 PM   #36
jusblazeee_f22
jusblazeee_f22's Avatar
Drives: '13 E92 M3
Those volks thooo
      04-21-2016, 10:33 PM   #37
fusionrace
Rogue
fusionrace's Avatar
Drives: 2016 M2
2001 325i  [0.00]
1989 m3  [0.00]
1990 m3  [0.00]
2009 M3  [0.00]
Thanks for the updates.
      04-22-2016, 12:44 AM   #38
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
2017 BMW F80 M3  [0.00]
Why develop a new intercooler? It has the same part number stock as m235i. I am sure the ones developped for m235i will be a straight fit.
      04-22-2016, 03:31 AM   #39
Boss330
Boss330's Avatar
Drives: BMW
The M235i ones could be restrained by space limitations inside the front bumper/fascia. Possibly room for larger intercooler in the M2?
      04-22-2016, 03:58 AM   #40
Bosozoku
Almost completely sane
Bosozoku's Avatar
Drives: '17 M2, '00 S2000
Originally Posted by David@ActiveAutowerke View Post
... The goal is to run 275/35/18 square, and I think we'll need to be closer to et30 with some camber up front to make it work. ...
It would be really interesting to compare lap times for stock vs. square 275/35/18 setups.
BMW specified over 200 tire parameters to Michelin for the M2's special tires.
Oh, and dropping the car reduces suspension travel.
That can be bad when you're tracking the car and you hit the bump stops.
Just sayin'.
'17 BMW M2 (BSM 6MT Exec CarPlay, TechnicPnP ASD bypass, IND M Perf shift knob + keyhole cover, Pedal Haus pedals + heel plate, 3M CR90 tint, BavSound Ghost woofers, Racing Dynamics strut tower brace, Dinan midpipe, Turner intercooler)
'00 Honda S2000 (Silverstone Metallic, black leather, factory titanium shift knob + front lip + trunk spoiler, front shock tower brace, front subframe x-brace)
      04-22-2016, 04:11 AM   #41
Bosozoku
Bosozoku's Avatar
6MT.
DCT is so 2015.
Agree. It's one of those weird sport + comfort features.
F1-simulation paddles + slushbox-simulation auto mode.
BMW developed it just to "keep up" with other car makers.
      04-22-2016, 04:39 AM   #42
Robin_NL
S0THPAW
Robin_NL's Avatar
8715
Drives: HS M2 Competition
Yep, afaik Porsche PDK 7speed and Ferrari's 7DCT are basically the 'same' Getrag DCT gearbox BMW uses with optimalized software etc.
But anyway. 1:12.2
Cheers
Robin
      04-22-2016, 04:53 AM   #43
Powaup
Powaup's Avatar
Drives: 2021 Supra 3.0 (Past: 2015 M23
2015 BMW M4  [10.00]
TE-37s look great!!!
Check out my YouTube Channel Powaup
Instagram: @ Powaup
      04-22-2016, 05:52 AM   #44
M3 Adjuster
Albania
7905
Originally Posted by W///
This is fantastic! You guys certainly aren't waiting around huh?
First off, it's great to see the M2 with something other than stock wheels. Looks very purposeful.
Secondly,we all expected that the N55T won't have as much headroom as the S55 for tuning so far, but definitely looking forward to what you guys come up with.
Keep up the good work!
Why should they ? Customers await ?!
18x9.5 - skinny wheels
Franklins query was the same as mine which is .. Will my 1M track wheel setup fit ?
We both dropped 18x10s with 275/35 continentals on the 1M instantly for a track setup , and I think definitely more than 9.5 is needed with that size tire. I love my 285/30 BFGs
Let's get some wide wheels on that wide body
I imagine that like most BMWs a square setup and some camber will make it a great track machine that doesn't cost you an arm a leg in tire because you can rotate all around.
Closed Thread
