02-16-2016, 01:53 PM | #25 | |
IG @bmwF9xG80
3813
Rep 7,593
Pistons with a modified top ring But I'm pretty sure there's a mention in the technical doc of a rod somewhere don't remember
60-130mph 6.5s X4M #HCP
02-16-2016, 02:26 PM | #26 |
Rep 204
http://f87.bimmerpost.com/forums/sho....php?t=1224109
More details than any review will be able to cover. |
02-16-2016, 03:52 PM | #27 |
Rep 699
Yeah, the word rod wasn't even mentioned so who knows. In terms of having a car to keep and mod, the m2 just seems like a deal of a lifetime. You can always upgrade the cooling and turbos to be equal to or better than the m4. Not to mention it has a hell of a lot more block rigidity considering its got massive iron sleeves. I wonder what the differences in the head are.
02-16-2016, 03:53 PM | #28 |
Rep 3,888
02-16-2016, 04:14 PM | #29 | |
Rep 1,153
02-16-2016, 04:34 PM | #30 | |
Rep 699
Magnesium is not even close to an ideal alloy for load bearing engine internals. Where did you hear that its using the m235i's crank? Theres no information I could find on that... They will likely re-use the same crank in the m235, m4 and m2. The only difference is that the m4 doesnt have the increment wheel on the crank which likely explains the 4lb weight difference. There would be no point for them to recreate another crank. Last edited by N54B30A; 02-16-2016 at 04:40 PM.. |
02-16-2016, 04:36 PM | #31 |
Rep 699
The way I see it, the m2 likely has the strongest block out of all of the turbo i6's. You get the rigidity of both a closed deck and cast in iron sleeves which is far stronger than the tiny .3mm thick LDS coating.
02-16-2016, 05:00 PM | #32 | |
Rep 3,888
02-16-2016, 05:05 PM | #33 |
Rep 699
Yeah, seems like bmw likes to hide these things.
02-16-2016, 07:24 PM | #34 | |
Rep 3,888
Apparently the M2 uses the exact same crank as the M235i:
02-17-2016, 12:46 AM | #35 |
Rep 294
I'm sorry but nowhere can I find any information saying that the engine in the M2 is based off the S55 basic casting and block. Or that it's of a closed deck design.
On the contrary BMWs own product technical data states that it is a further development of the N55. And I quote: "The N55B30T0 engine is the power plant for the F87 BMW M2. It is a further development of the N55B30O0 engine from the BMW M135i and BMW M235i, which is familiar from the current BMW 1 Series and 2 Series models." As you can see clearly there are very little similarities between the block found in the S55 and N55: S55 top and N55 bottom |
02-17-2016, 02:17 AM | #36 | |
Rep 551
One look under the hood of the BMW M2 and there's no doubt it's an M. A fully aluminum closed-deck block design and grey-cast iron liners allow cylinders to endure higher pressure under the most demanding driving conditions, while lightweight components and a forged crankshaft allow immediate throttle response. Quoted from: http://m.bmwusa.com/#m2LP |
02-17-2016, 04:57 AM | #38 |
Rep 62
02-17-2016, 08:27 AM | #39 | ||
Rep 2,402
Well you didn't look very hard. Multiple sources... http://www.bmwusa.com/standard/conte...rience/m2.aspx Quote:
Your pic is the regular N55 block. Odds are, BMW wouldn't make 2 closed deck, N55-based blocks. The M2's N55 likely usse the same base S55 casting, but gets liners vs. the more expensive arc coating of the S55.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
02-17-2016, 08:28 AM | #40 |
Rep 2,402
02-17-2016, 08:33 AM | #41 |
Rep 2,402
The cast crank from the standard N55 engines (not the M235's).
02-17-2016, 09:31 AM | #42 |
Rep 732
"Saul Goodman Reviews New BMW M2"
'23 F93 M8 GC ZCP - HRE S101SC - Full Akrapovic - '15 Audi R8 4.2 S-Tronic (Past) YouTube '21 F96 X6M ZCP Akrapovic/MSS/BC Forged, ‘18 G30 M550i, '18 G01 X3 M40i, '15 F10 M5 ZCP HRE S101 #1 & #2/Akrapovic, ‘13 W204 C63 AMG - ADV1 5.01SL's |
02-17-2016, 10:00 AM | #43 | |
Rep 2,402
02-17-2016, 10:53 AM | #44 |
Rep 1,501
Me too! i am already anxious. Thanks for the extra anxiety, motoman!
miiipilot
'24 M2 Brooklyn Grey, 6mt, Bi-Color, Black M-Color seats, '16 MG M2, DCT, Exec. Took Delivery 4/30/16 (Sold) |
