04-17-2018, 03:15 PM | #24 | |
Rep 2,505
I wrench on my own cars as well and I applaud anyone that does the same. I am getting quotes as we speak for an external 2 garage at my house so I can install a 2 post car lift.
04-17-2018, 03:25 PM | #25 |
Rep 6,125
A lift in your garage changes the game!
But - then you will have all sorts of "friends." Like winning the lotto... haha
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
classyfast670.50 |
04-17-2018, 03:39 PM | #26 | |
Rep 328
295/30-19 Rear Fit perfectly on factory 437M with ZERO issues and mucho traction. Shorter sidewall is the difference in making this width work. At 80MPH (GPS), your speedo will read 2MPH high (82MPH). |
M2C_PLUS1774.00 Project_F871231.00 |
04-17-2018, 04:56 PM | #28 |
Rep 754
Drives: 2022 M3 Competition
Man, that takes guts. I'll live through you!
2022 M3 Comp BGM/Fiona Red, Executive, Drivers Assistant Pro, Parking Assist, 826M black wheels
(SOLD) 2018 M2 BSM LCI, DCT, Executive, Drivers Assist, CarPlay |
Endeav390.00 |
04-18-2018, 12:34 PM | #32 |
Rep 6,125
Nice! That will be super helpful to put the power down.
04-18-2018, 03:44 PM | #33 |
Rep 2,214
Salutations, from BC! Looks like it will be a blast once it's done.
Q: What are your intentions with the car, just street driving/highway pulls? Or some track time, eventually? Cheers, D
04-18-2018, 03:59 PM | #34 | |
Rep 239
I was lucky enough to do 4 full track days last year in the M2 and it was a blast at stock power level. I definitely plan to track with the Pure Stage 2 turbo, but it'll be at a lower boost level. I can only imagine that the car would be quite the handful if I were to track with 500+ wHP - hence why I plan on turning the boost down for those days!
Instagram - @niru.s1k
24 BRG M3 - Pending Delivery 17 BSM M2 (SOLD) - PureTurbos Stage 2 - BM3 - Tuned by F80Paul @ Paul Johnson Tunes |
04-18-2018, 04:24 PM | #35 | |
Rep 2,214
I have a full track build taking place currently on my 2'er, and thought of doing PS2 and running low boost, as well, and the JB4's boost-by-gear from 1-3 (MT) as that would solve any overpowering scenerio's I'd be faced with, on R compounds and a fast track. I can't imagine the tighter tracks, running more than 380-400whp in the lower gears, it would be fun, but... lol I assume you're keeping the JB4 as your boost/meth controller? That was my intention as well, even if I don't go PS2, but the BEF +JB4/meth on stock turbo at the very least. Can't wait to see what this beast puts down, great job on the DIY, too, CLEAN work!
04-18-2018, 04:30 PM | #36 | |
Rep 239
Our local track has one straight with a much tighter back-half, and you definitely wouldn't want anything much more than stock power for the back half. Like you said, it could be fun, but perhaps a little too much - especially for someone who isn't chasing lap times. Ideally once the car is fully dialed in I'd like to take it to Brainerd Raceway in Minnesota and get the full track experience. Appreciate the kind words - thanks!
Dylan861330.00 |
04-18-2018, 05:44 PM | #37 | |
Rep 2,214
Awesome man, and again great job! I hope you enjoy it for years to come
Endeav390.00 |
04-19-2018, 12:31 AM | #38 | |
Rep 1,348
Great car and thread will be following.
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 |
04-19-2018, 10:43 AM | #39 | |
Rep 239
For port methanol injection you have two routes for a controller, AIC6 or JB4 - I went the JB4 route. Because of this I decided to go MHD for the flash route just because of how well it is supported by the creators of the JB4 - they're familiar with MHD and are able to provide a proper back end flash for the car since they know what the JB4 will be doing etc. Nothing against BM3 - if I had gone the AIC6 route I'd definitely be sticking with BM3. I went methanol because I'm located in Canada. Unfortunately up here we don't have any ethanol mixture at the pumps. I'd have to buy E95 barrels, store them, and mix them at home. Not the most convenient and ideal situation. Another factor was that the N55 has fueling issues up top once you go over a certain power level, and ethanol doesn't 100% fix that issue. You'll eventually reach a bottle-neck by trying to run JUST the OEM fueling setup. The only real way to get around that is some form of supplemental fueling in addition to the OEM HPFP - this can be direct port fuel injection (bigger LPFP), or direct port methanol injection. If you have access to ethanol the best way to go about this would definitely be direct port fueling and just running some form of ethanol mix in the gas tank!
ceedawg467.50 |
04-19-2018, 07:00 PM | #40 | |
Rep 752
Thanks. |
04-20-2018, 07:32 AM | #41 | |
Rep 239
Turbo should arrive sometime this afternoon. Fuel-It Methanol PI will arrive Monday. I'll hopefully have everything turbo-related bolted on late this evening assuming everything is in the one box from PureTurbos!
04-20-2018, 08:19 AM | #42 |
Rep 2,577
As for BEF, something funny - My buddy of 2013 335i AWD PWG on PS2+meth+PI, broke 1/4 mile record in early 2017 at Fast4Ward, the biggest drag racing event national wide in China. His time was 11.11@125mph, which is still the second best all time N55 record.
The BEF he used is BM3 OTS STG2 of late 2016, a very early version that's not remotely perfect, and the funny part is he didn't even bother flash newer versions since then... Yet he has the perfect log. What I'm trying to get at is you don't need a perfect BEF to perfectly push that hard. On the other hand, not pushing hard, flash alone can meet your goal Good luck with meth with BMS!
Lemania 2320
04-21-2018, 06:48 PM | #43 | |
Rep 1,348
04-21-2018, 11:01 PM | #44 | |
Rep 239
Turbo arrived on Friday, went to work immediately to get it all bolted on. It took about 5 hours to get it bolted back on the vehicle. Everything went quite smoothly with only the inlet pipe slowing us down!
Comparison of Compressor... Comparison of Turbine... Here are some more progress pictures... So far I've just been running the MHD (BMS) BEF and the JB4 in Map 3 with a methanol additive of 75 (around 19.5 psi max). I don't want to run the turbo too hard just yet. My N20 TMAP sensor arrives Monday along with my direct port methanol injection kit. Once those are on the car (hopefully Monday evening) I'll be able to push the car some more and get rid of the boost taper and truly feel what this turbo is capable of. Expect more pictures to follow of the next couple installs and then I'll be sure to document the tuning process as well. Quote:
24 BRG M3 - Pending Delivery 17 BSM M2 (SOLD) - PureTurbos Stage 2 - BM3 - Tuned by F80Paul @ Paul Johnson Tunes Last edited by Endeav; 04-21-2018 at 11:56 PM.. |
