M2 Technical Topics > Suspension | Brakes | Chassis > Sparta Evolution Brake pads review from Novice track driver
      06-28-2021, 09:31 PM   #1
Sungillest
Sungillest's Avatar
102
Drives: OG M2 ZL9 |Macan 2.9TT
Good evening y'all
I had a chance to get the sponsorship from Sparta Evolution Brake pads (SPP 1.0), and fluid (product links are down below). I did not install them myself. But I took them to my friend Blake (master technician) to install them for me.
Installation:
Installation was fairly easy,
Remove 2 pins on the caliper, pull out the metal clip(anti rattle clips) press down(squeeze) the pads(so that pistons are pressed), then remove OEM pads, install the SPP1.0 pads.
The only issue was the edges on retainer did not have enough tolerance, so it needs to be modified (Grinding the edges).
Below I have attached the installation pictures taken by him.
Small Review:
I have used it for more than 2 months, the initial bite is stronger than OEM (Brembo) pads. Also they are not making noises when cold compare to other performance pads options. Not to mention they are really making less brake dusts.
They are great value for the money, if I have to replace my OEM pads, I will definitely checkout their SPP 1.0 pads over the stock Brembo pads made by Textar. Stay tuned they have another line up will come out shortly SPP 3.0 which is more track focused.
With the upgrade pads, fluid and steel brake lines gave me more confidence going into the corners. So far, I have only attended 1 track event with this setup at Eagles Canyon Raceway in Texas. But more AutoX and track events will come shortly(July)!
I will continue updating my review after I attend more track/AutoX events!
Huge thanks to Sparta Evolution for sending me their SPP 1.0 pads, and fluid!
I will continue enjoying my braking power!
Track event video can be found on YouTube or here
https://www.instagram.com/p/CPtZjeqJ...pdf8B8T7StUs0/
Checkout Sparta Evolution Brakes!
Check out their website:
https://shop.spartabrakes.com
https://www.instagram.com/spartaevolution
Front pads: https://shop.spartabrakes.com/produc...pp10-1609-170/
Rear pads: https://shop.spartabrakes.com/produc...pp10-1656-160/
Brake fluid: https://shop.spartabrakes.com/produc...-racing-dot-4/
neonbrown274.50
Tags
autox, brake, f87, f87m2, sparta, sparta evolution, track
