M2 Technical Topics > Suspension | Brakes | Chassis > Monster DIY: KW V3, torque specs, re-indexing, spacers, alignment, coilovers install
      08-31-2020, 02:29 PM   #67
Kankles
Rear Admiral
Kankles's Avatar
Drives: Bavarian Milk Wagon
2019 BMW M2C  [0.00]
Originally Posted by M Fifty View Post
ECS Tuning actually sell the official BMW tool for use on the standard nut - but it costs more.
https://www.ecstuning.com/b-genuine-...302360213~oeb/
Crazy, basically double the schwaben price (which is good quality IMO)
      08-31-2020, 03:46 PM   #68
M Fifty
846
Drives: M2 & 330CI
As with everything else, others may sell for less (market dependent)
Kankles1485.50
      08-31-2020, 06:10 PM   #69
Mosely
Mosely's Avatar
594
Drives: '18 M2 | '20 X5 | '07 E92
Originally Posted by Kankles View Post
I know this is an older post but in case anyone else is curious. The stock 14x1.5 (ID) top nut is an 18mm (OD) and a schwaben tool is super helpful in removing.
https://www.ecstuning.com/b-schwaben...3046sch01a-01/
A lot of aftermarket (KW) use a 14x1.5 (ID) nylock style nut that has a 22mm (OD). For these a 22mm O2 sensor socket works really good.
TEKTON 47749 3/8-Inch Drive by 7/8-Inch (22 mm) Offset Oxygen Sensor Socket https://www.amazon.com/dp/B00GMN4D1Q..._VIptFbHQHRK4E
For the same price as the shwaben thing, you can just buy the pass through spline socket set (Amazon: Crescent X6 is what I bought). Find a thin walled 10mm 1/4" drive and it'll fit up the middle. I had the schwaben and socket set and found the sockets much easier (and you can use them for other things instead of a one off!).
IG Photo Gallery:
instagram.com/dr_m2sko/
Kankles1485.50
      09-01-2020, 12:14 AM   #70
Kankles
Rear Admiral
Kankles's Avatar
2019 BMW M2C  [0.00]
Good call on the pass through set. I was eyeing these but I already had the other sockets.
Here's a set that includes an 18 and 22mm.
Channellock 39100 Ultra Access Socket Set, 16 Piece https://www.amazon.com/dp/B00PB39K9I..._KGDtFbGD2S616
      09-01-2020, 10:34 AM   #71
nearwater4me
Drives: '22 G82 Base
For the 10mm hex shaft, the brake bleeder wrench works perfectly.
      09-01-2020, 03:33 PM   #72
MikeF87LCI
MikeF87LCI's Avatar
Drives: BMW F87 M2C
Just ordered that Chanellock set for when I get round to fitting my V3s
Kankles1485.50
      09-02-2020, 07:58 AM   #73
Kankles
Rear Admiral
Kankles's Avatar
2019 BMW M2C  [0.00]
Let us know how it turns out
      09-02-2020, 12:37 PM   #74
M Fifty
846
Drives: M2 & 330CI
On cars with a slightly less unusual nut, I have used a large 1/2" drive spark plus spanner with the rubber cup removed and a selection of 3/8" to 1/4" extensions and sockets.
Once again, on the stock strut tops - when torquing up the nut - once it's seated (for which you do need both the 'outer' and 'inner' sockets), you can just use the the torque wrench on the nut without having to hold the shaft.
HTH
VisualEcho6638.00
      09-02-2020, 12:38 PM   #75
M Fifty
846
Drives: M2 & 330CI
Obvs. this does not apply when using camber plates fitted with ball races.
      09-02-2020, 03:52 PM   #76
wavyyyy
Drives: M2C
2023 bmw m3 6mt  [0.00]
I went ahead and used a pass through, worked perfectly for me.
      09-04-2020, 01:24 PM   #77
MikeF87LCI
MikeF87LCI's Avatar
Drives: BMW F87 M2C
[/QUOTE]
If anyone needs a cheap pass thru set can recommend that one above.
Shipped in 4 days US to UK, looks like it'll do the job just fine feels pretty solid in hand (I have plenty of snap-on tools for work) comes in handy case too.
Kankles1485.50
      09-13-2020, 01:58 PM   #78
MikeF87LCI
MikeF87LCI's Avatar
Drives: BMW F87 M2C
Fitted my KW's today, think they still require some adjustment. Just wanted to see what ride height others have gone with. Mines probably a bit too low to be practical at the moment.
About 377mm front
And 386mm rear
That has actually settled slightly measured 385 and 390 when first installed.
Not actually heard any rubbing as of yet and I'm running 255/275 on 437m
Cheers
Kankles1485.50
      09-13-2020, 03:26 PM   #79
Wei718
Wei718's Avatar
340
Drives: 718 GT4
About 377mm front
And 386mm rear
Cheers
Post a picture! I want to see how low you are sitting.
      09-13-2020, 04:04 PM   #80
MikeF87LCI
MikeF87LCI's Avatar
Drives: BMW F87 M2C
Here's a few quick phone pictures
Kankles1485.50
      09-13-2020, 08:30 PM   #81
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
5 to 10mm difference front to back seems about what to shoot for. Ride height is a bit subjective. You're probably about 10mm lower than mine sits. Not sure where you measured from, but the alignment rack put mine at 600 front, 607 rear.
Motorcity BMWCCA Member
Instagram | YouTube
      09-14-2020, 02:27 AM   #82
MikeF87LCI
MikeF87LCI's Avatar
Drives: BMW F87 M2C
I measured from bottom of the rim to the edge of the wheel arch. Like I say, it's already settled a fair bit so could do with lifting it 10-15mm. Heard a slight little chafe on front arch liner this morning too
      09-14-2020, 01:07 PM   #83
M Fifty
846
Drives: M2 & 330CI
So, just out of curiosity, how did you come up with "About 377mm front. And 386mm rear", if you measured "from bottom of the rim to the edge of the wheel arch"?
The diameter of the wheel should mean the measurement is the thick end of 600mm not 400mm.
      09-14-2020, 02:53 PM   #84
MikeF87LCI
MikeF87LCI's Avatar
Drives: BMW F87 M2C
Ahh shit my bad! The should be 5xx not 3xx
      09-14-2020, 03:58 PM   #85
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
In that case, you're about 20mm lower than I am
Instagram | YouTube
      09-17-2020, 11:26 PM   #86
Kankles
Rear Admiral
Kankles's Avatar
2019 BMW M2C  [0.00]
About 377mm front
And 386mm rear
Cheers
Looks good! I'm at max ride height as my front tires are aggressive (265/35 RSR on 437M).
I will try to install the linear springs this weekend as they've just arrived from KW
      09-18-2020, 02:14 AM   #87
MikeF87LCI
MikeF87LCI's Avatar
Drives: BMW F87 M2C
I've since raised mine. Didn't like how low it'd gone, front tires were starting to tuck under the arch. It should be around 595mm mark, need to re measure.
Sits way better now...
Appreciate 4
VisualEcho6638.00
Kankles1485.50
dtmurf484.50
      09-19-2020, 11:26 AM   #88
Kankles
Rear Admiral
Kankles's Avatar
2019 BMW M2C  [0.00]
KW V3 rear height adjustment: While installing linear springs today we also drilled some holes into the upper rear spring mount so we can use a two-prong tool to hold it into place while you raise/lower the ring/spring. Works great. (This is a tool for installing/removing discs on a Makita cordless grinder but could use many other tools to accomplish this.)
Thanks Megator and Nico
VisualEcho6638.00
Megator517.50
