02-01-2024, 01:16 AM | #1 |
Rep 48
3DM Roadsport Öhlins Coilovers
Is anyone here running 3DM's custom Roadsport Öhlins package (listed here)? I'm interested in a road-focused coilover setup for my OG M2 and thought this might be a solid choice (especially given they are revalved to suit the lower spring rate).
I'd love to hear feedback from anyone who runs them - particularly in comparison to the stock setup. And perhaps compared to other popular choices like the Bilstein PSS10. |
02-04-2024, 12:01 AM | #2 |
Rep 28
Nothing but great experiences from what I have read and seen online - no personal experience. I currently have the M Performance suspension but if that wears out in the near future - the Ohlins R&T 3DM RTR kit would be my choice. I would also pair that with Millway street camber plates, but your application may vary. Some have opted to change the springs from the 90/190 Nm standard to something softer using Swift springs - would see what 3DM offers.
I first heard about 3DM through Obsessed Garage. I like that the suspension can come pre-assembled to a specified ride height which you may have to dial in further depending on wheels etc. Not sure if you follow Obsessed Garage, but Matt has had the 3DM Ohlins on his E92 M3, E36 M3 and on the M2 CS giveaway car (w EDC delete in this instance) and nothing but good things to say. |
Alanine16.50 |
02-04-2024, 06:59 PM | #3 |
Rep 502
3DM ohlins is good but I outpaced mine pretty quick.
If youre looking for road and track you won’t find any better than this. https://ogsharkmotorsport.com/nitron/ |
02-05-2024, 01:39 AM | #4 | |
Rep 48
02-07-2024, 01:00 PM | #5 |
Cruisin'
48
Rep 79
I have this kit on my M2C. I use it for 90% road/twisty mountains and I'm completely happy with it. Barry is super nice and knowledgeable.
I cannot provide input on how well it will do on the track, since I've yet to go. If you are new to coil overs and or linear springs, the car will be noticeably stiffer. Make sure you adjust your damper/rebound/compression settings accordingly and how your roads are (this second one is often glossed over).
IG: f87jcm2
02-07-2024, 07:08 PM | #6 | |
Rep 7,340
02-07-2024, 07:36 PM | #7 | |
Rep 48
So you're running the 70/160 Swift spring combo? If you're running the suggested ride height (10mm below stock), do you have any pics you can share, please? Finally - I'm happy with stiffer - what I really don't like is the behaviour of the stock suspension over road imperfections - I think it's referred to as "crashiness". |
projekt-47.50 |
02-08-2024, 02:05 PM | #9 | |
Cruisin'
48
Rep 79
I am running 590/600mm Front/Back. The recommended ride height by BMW M division for M cars are 595/600mm, measuring from the bottom of the fender, to the bottom of your wheel. As for picture of my car, here's one I posted a little while back: https://f87.bimmerpost.com/forums/sh...postcount=1745 There's also one more photo on my IG, linked on my signature.
IG: f87jcm2
Alanine16.50 |
02-08-2024, 02:11 PM | #10 |
Cruisin'
48
Rep 79
I would say the coilovers are an overall improvement even if you have rougher roads. The dampers no longer "crash" on you when you hit a bump or mild pot hole. A comment many have made when on stock suspension which I also observed when I just got the car.
IG: f87jcm2
chris7197393.50 |
02-08-2024, 04:30 PM | #11 |
Rep 295
I'm about to pull the trigger on a set of the 3DM's RTR 70/160 myself. I'm currently running an early Ohlins with the 90/190
and GC plates - the combination is harsh and noisy. OK if I was tracking but I don't. |
02-09-2024, 07:44 PM | #12 | |
Cruisin'
48
Rep 79
GL with the swap!
IG: f87jcm2
02-15-2024, 02:31 PM | #14 |
Cruisin'
48
Rep 79
Update here. I spoke to Barry recently regarding my situation.
If you purchase the RTR with OEM top mount version and not made any custom requests, you will need to purchase longer front springs to add camber plates. RTR with OEM top mounts run on shorter springs up front, to provide more inner clearance (the clearance part is mentioned on the purchase page - and this is how they achieve it). Therefore, if you purchase RTR with OEM Top mounts, but want the flexibility of possibly adding camber plates in the future, make sure you mention this to Barry when purchasing your kit. He should accommodate your accordingly.
IG: f87jcm2
redgs4320.00 |
02-15-2024, 04:25 PM | #15 |
Rep 20
I have a 70/160 3DM Ohlins setup on my M2C. It was my daily for 4 years. I had stock suspension for 20k miles before changing over. I've considered going to 80 in the front after having had this setup for about 3 yrs. I believe the OG is slightly lighter upfront so you're probably good at 70.
I also did the millway street camber plates. I enjoyed them until I started getting a rubbing noise but turns out I had my front dampers set to different stiffness lol. No one screws up my car better than I do. Overall I strongly recommend Barry and 3DM for a solid street setup. I would 100% do it again and if anything, I would've done it sooner. |
02-15-2024, 04:27 PM | #16 |
Rep 86
I have the Road and Track RTR with 90/190 springs. I don’t mind the stiffness at all, and I still think it’s an improvement from the CS adaptive suspension.
I have the Vorshlag camber plates and experience no NVH. I have it dialed to less then Barry’s recommended 15 clicks, to 17. Last edited by thrilla; 02-15-2024 at 04:29 PM.. Reason: More info |
02-20-2024, 05:50 AM | #17 | |
Rep 295
projekt-47.50 |
02-20-2024, 05:20 PM | #18 |
Rep 48
Thanks for all the responses, and also the note about shorter springs being used be default. I'm trying to decide what to use for top mounts for a road-oriented setup that will do a few trackdays: a fresh set of OEM mounts (which adds $450 to the cost of the coilovers) or the popular Millway Street camber plates.
02-21-2024, 12:44 PM | #19 | |
Cruisin'
48
Rep 79
In hindsight, I really should have planned for camber plates for my car, regardless.
IG: f87jcm2
Alanine16.50 |
02-21-2024, 02:00 PM | #20 | |
Rep 48
02-21-2024, 02:23 PM | #21 | |
Cruisin'
48
Rep 79
Since you are lower and want to run wider tires, your car will be in a much more aggressive stance, needing more negative camber so you can clear you tires and not rub. Thus, needing camber plates for the front.
IG: f87jcm2
Alanine16.50 |
02-22-2024, 12:16 AM | #22 | |
Rep 557
Have had the Millway Street camber plates for 70K km without an issue, for a while ran -3.0 on track but now go -3.5 (-2 on street), am a little quicker @3.5 and tyres (A052) also wearing better. imo the camber plates will in time pay for themselves through better tyre wear. After 60K km I had the Ohlins out for servicing so took the opportunity to put new bushings in the camber plates, the old ones were actually still in very good condition but changed them anyway. |
medphysdave4636.50 projekt-47.50 |
