M2 Technical Topics > Suspension | Brakes | Chassis > BMW M Performance Coilovers and Rogue Engineering Suspension Parts
      06-10-2019, 02:58 AM   #23
mic_crispy
Drives: 2002 | 964 | x1 M35
I thought these only lowered the car 20mm?
      06-11-2019, 02:00 AM   #24
M Fifty
844
Drives: M2 & 330CI
They are basically KW V3, so the front can go as low as, while the back is limited by the length of the spring (the KWs use a much shorter spring with a helper spring).
That said, there are a couple of options to get the rear lower without spending money:
1. don't use the adjustable spring perch and retain the original upper spring seat
2. the spring is located on the adjustable perch by a two-piece seat, so ditch the rubber bit and retain the plastic spacer.
HTH
Tags
bmw m2, detailersdomain, rogue engineering
