M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Major Diagnostic trouble....Any experienced BMW Techs or Enthusiasts please Help
      12-12-2017, 09:49 AM   #1
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2020 BMW X4M CS  [0.00]
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
Posted in the wrong forum but youll have a good idea of where i am by Reading. Thanks in advance or any advice hor help,,,
Original Tread:TryingmtoDiagnose issue: Please Help!
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3
      12-12-2017, 11:04 PM   #2
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
      12-12-2017, 11:07 PM   #3
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
Here is a Carly deep diagnostic of all control Units... I believe they are almost all related as it went from the 2 o2 codes to 35 in an instant...
      12-13-2017, 09:32 PM   #4
gingerbread
Drives: BMW
Sounds like the PT bus and or Flex ray bus are having communication issues.... the no power at Terminal 15N is where you should start, think has something to do with the power distribution box in the engine bay.
You said it all started with o2 sensor short circuits I think? Always start simple check all fuses for the car. one little thing can daisy chain pretty quick in these cars. also just saw that you power steering module and electronic damper is not communicating and they get a signal from Terminal 15N. look into that
The lpfp has a module that runs the pump, that sends and receives messages over the PT bus. so if the bus has issues, OBD2 live Data will no show right. probable solving the bus errors with fix your wierd fuel readings
      12-13-2017, 10:07 PM   #5
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
LMAO. You took the words out o my mouth...
Exactly what I said to friend last night...Oddly I didnt see that fault on Carly only the sendable file and as soon as i saw thatit made sense...
      12-13-2017, 10:11 PM   #6
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
funny. took the words right outta my mouth
As soon as I saw that fault which didnt show on the app; only the email...a light went off...
      12-13-2017, 11:38 PM   #7
cookiesowns
cookiesowns's Avatar
587
scan it with ISTA+. Let me know if you need help. Have you tried removing the JB4? JB4 shorts will cause these issues.
FSociety3812.50
      12-14-2017, 10:09 AM   #8
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
I see wrong picture was uploaded lol
+1 This is true
Everyone including myself has TMAP Short Circuit thanks to jb4 amongst other things.
My friends that never had Jb4 and went str8 to flash 0 faults in ISTA+
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      12-14-2017, 10:52 AM   #9
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
+1 This is true
no i uploaded our convo from 2 days ago where said flexray bus is responsible or most o the other codes...
And o course I removed JB4, reversed all coding, Loaded Bootmod3 stock map, did plugs, reset dme, battery is new, switched around coil packs, tested fuel rail pressure...all the basic things just to rule them out
The specialist will do ista...and ill take ur advice since enzo didnt getthe dme i will have bootmod3 remove tamper code go back to dealer for puma and istep updated...
Also important to not Navogation is not working Found a threa her ewith EXACT SYPTOMS eneded up being telecomm box...$500 new, found one used or 250....Have to ind where it is ...thats also causing emergency call malf SOS...
      12-14-2017, 10:54 AM   #10
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
the 02 codes, who knows maybe i shorted jb4 and somehow send voltage to a dangerous part o dme...
      12-14-2017, 12:26 PM   #11
TT1351
TT1351's Avatar
508
Drives: 135, GTS, E30 M3+
FWIW, somewhere on here I read about spark plugs, specifically how the OEM ones are the way to go as opposed to the commercially available equivalents. I was always under the impression that it really didn't matter, but this thread convinced me otherwise. May be in the 1 Series side of the house and was N54 specific as I recall. Just a thought.
      12-14-2017, 08:38 PM   #12
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
I learned early the plugs are VERY SENSITIVE to damage and Correct Installation...I have a nice Torque wrench and gapper and ive done them 3 times now no issues...
U may be right ...def no improvement w colder NGK Plugs, just heavier wallet LOL
