BMW M2 Forum > Pricing / Ordering / European Delivery / PCD > M2 Competition base price guesstimate (USA)
View Poll Results: M2 Competition base price guesstimate (USA)
same price as current M2 2 1.04%
around $2K more 3 1.55%
around $3K more 14 7.25%
around $5K more 50 25.91%
over $5K more 124 64.25%
Voters: 193. You may not vote on this poll
      12-13-2017, 01:10 PM   #23
akkando
akkando's Avatar
5865
Originally Posted by Artemis View Post
As we know, some official base M2 figures:
  • max output: 272 kW = 370 hp (metric) or 365 hp (mech [USA]) @ 6500 rpm
  • max torque: 500 (465+35) Nm = 369 (343+26) lb-ft @ 1400-5560 rpm
Akrapovič tested a stock M2 (2016) (i.e. before fitting their exhaust). Their test results (see here):
  • max output: 284.3 kW = 386.5 hp (metric) or 381.2 hp (mech [USA]) @ 5500 rpm
    = 272 kW + 4.5221%
  • max torque: 558.8 Nm = 412.1 lb-ft @ 2500 rpm
    = 500 Nm + 11.76%
M2 Competition:
  • max output: 302 kW = 410.6 hp (metric) or 405 hp (mech [USA])
Purely hypothetical exercise: if exactly the same factor as measured by Akrapovič for the base M2 would apply for the M2 Competition, you get the following results:
  • max output: 302 kW + 4.5221% = 315.66 kW = 429.2 hp (metric) or 423.3 hp (mech [USA])
As I understand it typically BMW underrates their engines a lot more than they did with the N55 M2. BMW underrates the S55 power a lot more than the M2 N55. Now, perhaps BMW won't leave much extra on the detuned S55, anything could happen, but if it's similar to the M3/M4 I would expect at least an 80 HP difference between the M2 and M2 Comp when the power is actually measured.
      12-13-2017, 03:32 PM   #24
jmh600cbr
jmh600cbr's Avatar
271
Drives: G80
2021 BMW G80  [0.00]
this is curious. why does BMW understate their performance?
2018 F87 LCI gone but not forgotten
2021 G80 6MT BSM
      12-13-2017, 06:03 PM   #25
Fangi0
El Chueco
Drives: '18 M2 6MT, '15 F10 M5
Originally Posted by Chako View Post
Yet another way to look at it is these S55 cars seem to run WHP numbers very close to their rated crank power (on Dynojet). So if the M2 Competition comes rated at 405HP there's a strong possibility it will make 405WHP with the factory tune.
^^ this. On point again, Sir Chako. The M2 was expected to be along the lines, and "surprised" us with "only" ~380 hp @ crank.
Chako105.00
      12-13-2017, 08:40 PM   #26
Fangi0
El Chueco
Not to deviate from the main topic of the thread, my $0.02:
Unlike N/A engines, turbocharged ones are more sensitive to variations in intrinsic (i.e. temperature) and environmental variables. A safe practice is to declare lowest throughput bound achieved with the least favorable input set (fuel, air conditions, engine temp, etc). It is smart from both engineering and legal standpoints --if it holds for the worst case scenario, holds for all... plus BMW won't get hit with a class action for false advertisement. From a marketing standpoint, it maintains/respects model "hierarchy". And it might even help keeping insurance premiums lower.
Conjectures of mine, though, I have no factual information from BMW to sustain the claims above.
Past: '10 E92 M3 6MT | '02 996T | '97 E36 M3 4D 6MT
jmh600cbr271.00
Chako105.00
      12-13-2017, 11:05 PM   #27
stefan
stefan's Avatar
Drives: M2 Comp
Originally Posted by Fangi0 View Post
Another angle: according to DINAN (mid page, Specs tab), the S55 in the M3/4 base, non-ZCP:
BMW Factory Rated HP: 425 (484 Measured)
BMW Factory Rated Tq: 406 (446 Measured)
Also purely hypothetical, using the above, linearly adjusting:
Rumored M2 Comp HP: 405 --> 461 Measured?
Rumored M2 Comp Tq: 400 --> 440 Measured?
Now a hypothetical wish: whatever the numbers turn out to be, I secretly hope they fit it with (at least 0.5") wider rear wheels/tires...
Originally Posted by GimmeanM View Post
Not likely on the wider wheels. All F80/82/87 have had 9 "and 10" wheels (except for the GTS with 9.5 and 10.5). But they can clearly put wider tires on the same 9" and 10" wheel:
F87: 245/265
F80/82 base: 255/275
F80/82 Comp pack: 265/285
But I agree and hope that it has wider rubber, or Cup 2 tires ...and I'm thinking about this for the limited edition model CS if it ends up being made. No way the M2 Competition is going to have cup 2 tires.
I tend to agree with you that they will leave the wheel width and go with 255/275 (non-cup) tires.
275/35? might just fit? Wonder if they will be dropping 10mm in line with most zcp. They may need to add camber.
As for pricing it would seem that demand persists despite 2018s increase for virtually no additional equipment. So it stands to reason you will see a hefty increase for the fully fledged M car. Seats, mirrors, motor. 5K+ easy.
///M Power
      12-14-2017, 12:41 PM   #28
Motivate
Drives: Shopping for a new one
I voted over $5k. The only way it can be below a $5k increase is if BMW only upgrades the engine and that's it.
      01-26-2018, 04:50 PM   #29
Damage Inc
Damage Inc's Avatar
790
Drives: 2017 M2
it depends.
If its an "add on" to the base, as a comp pack, then it will be a $4k option.
If its a CS model, then it will be $5k more.
Hunch is it will be an M2 CS that is $6k more. Remember they will build to a price, and not steal from M4 sales.
Similar to the early Cayman vs. 911 days.
Current: 17 OG M2 / R8 Performance
Past Performance Cars: 01 M3, 05 M3, 06 M5, 08 M6, 08 M3, 11 M3, 13 M3, 15 M3, 911 C4S, 911 GTS, 17 M2,R8 V8, R8 RWS
      01-30-2018, 06:15 PM   #30
bim2er
bim2er's Avatar
Drives: '18 Mineral Grey M2
I have no reason to believe that a limited edition M2 CS needs to less that a base M3/M4, especially when an M4 CS is so much more than a base M4. IMHO, a M2 CS typically would not attract most base M3/M4 buyers. CSs are tilted toward the track, so many buyers will not put up with the suspension or the lightened interior deletions.
'74 2002tii, Sienna Braun Metallic, Manual, Sold; '84 e28 533i, Burgundrot Metallic, Manual, Sold; '95 e36 M3, Avus Blau Metallic, Manual, Sold; '06 e60 M5, Silver Grau Metallic, SMG, Sold; '09 e82 135i MSport, LeMans Blue, Manual, Sold
      01-30-2018, 08:40 PM   #31
filet.M2c
filet.M2c's Avatar
784
Drives: M2c / mach e
M2 Competition ≠ M2 CS
      01-30-2018, 08:59 PM   #32
bim2er
bim2er's Avatar
I'm not the one to whom you need to explain that. Try previous posts.
