11-30-2017, 09:00 AM | #1 |
Mr. OEM
542
Rep 796
Fitted paddle shifters to my SMG E36 M3
Car now fitted with paddle shifters. IMHO, the best mod I've ever done. Just feels so much better driving it.
Also shaves some time, even how little it is, off the gear change process. No hand-to-stick movement and the throw of the stick is longer than the tiny flick of the shifter. And as always, everything is 100% reversible Zero cutting or splicing in factory wiring. Ok it will leave some holes on the back of the wheel, but I have a brand new spare M wheel. Short vid
'1998 BMW M3 3.2 Cabrio • Alpinweiß III auf Schwarz • Deutschland-ausführung • 1 von 12 • SMG • SRA • PDC • AUC • GSM • HK • UURS • IHKA • FGR • MFL • |
12-05-2017, 02:16 PM | #2 |
MGySgt
629
Rep 1,246
Drives: See Garage List! ;-)
Garage List 2010 M5 [10.00]
2016 BMW 340xi M Sport [9.00] 2019 X5 50i M Sport [5.50] 2010 535xi [0.00] 2013 M5 [0.00] 2012 X5 M [0.00] |
Swueeeet Mod! I want to do this to my '10 E60 535xi Sport!
JMD
12-05-2017, 04:19 PM | #3 |
Rep 2,062
It's money I wouldn't really wanna spend on my E36, but I didn't know people did SMG swaps into E36's! I haven't gotten around to doing my M3 to 328ci suspension, subframe and diff swap. Good job!
12-06-2017, 08:25 AM | #6 |
7436
Rep 12,293
No swap, OP is in Europe
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
12-06-2017, 03:48 PM | #7 |
Rep 2,062
I saw that after I found some YouTube videos of the SMG doing SMG things lol.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's |
12-12-2017, 06:21 AM | #8 |
Mr. OEM
542
Rep 796
Some familiar faces here...
As said, this is the SMG1 gearbox offered on EU spec M3 3.2 models. Since it's the oldest system, it's over 20 years old now, don't expect DCT like shifts. But it has its charm and while I didn't specifically plan on buying an SMG1 M3, this one happened to cross my path and ticked all the boxes. In the 4+ year of ownership, I've connected with the system and having 2 friends who also own SMG1 cabrio's and together have deducted its workings and how to troubleshoot, it's a nifty system if you consider the age and context. I'm a manual guy myself, but I've never missed not having a clutch pedal.
12-13-2017, 01:36 PM | #9 |
Rep 397
12-14-2017, 09:58 AM | #10 |
Mr. OEM
542
Rep 796
And for those not familiar with the EU SMG1 stock shifter, this is how it looks:
So these 20+ year newer paddles match the alu-silver/black perfectly. Doesn't even look out of place. And some other angles of the shiftpaddles SMG1 hydro unit at bottem left
12-16-2017, 01:40 AM | #11 |
Rep 2,359
Drives: G87 M2; E92M3 MT&DCT; M3 euro
I assume you've never seen an ITB on E36 M3 either.
Pass me if you can.
12-16-2017, 02:18 PM | #12 |
Rep 2,062
I have seen ITB's as my first BMW in the 90's was an M5, but no, I didn't know the SMG was ever in the E36.
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's Last edited by m5james; 12-16-2017 at 02:27 PM.. |
12-16-2017, 04:28 PM | #14 |
Rep 2,359
Pass me if you can.
10-22-2018, 02:51 AM | #15 |
Rep 1
Sorry for upping and old thread, but i just stumbled upon this, and my hats off to you sir, looks really nice! What kind of paddles did you use? Looks like the F-generation but it seems there are a lot of differences F10 vs F30 etc.
10-22-2018, 05:51 PM | #16 | |
Mr. OEM
542
Rep 796
Thanks. Still loving this mod. Not sure how I would describe these paddles. BMW used them on many different models the last, what, 7+ years, if not longer. Though I did notice there are two versions of this style paddle, which looks identical viewed from the front, but the back side is very different. The 'base' plate is the same as the latest M5 paddle shifters, so I could easily swap over to a different style, but the black/silver looks better to me and a pefect match with the stock shifter. Old model back https://www.ebay.de/itm/BMW-F11-F12-...IAAOSwPCtbWu-U Later model https://www.ebay.de/itm/BMW-F20-F21-...YAAOSwFetamEcw Older model paddles in general seem of a better construction, with metal pivot bar and metal thread (insert) to bold it on, all later models it's all plastic.
10-22-2018, 06:01 PM | #17 |
Rep 1,881
can you upgrade to the e46 SMG shifter as well? That shifter looks huge for something that does almost nothing...
I am never able to post pictures on forums, all my pics are on IG @baye30 https://www.instagram.com/baye30/
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V] |
10-22-2018, 06:16 PM | #18 |
Rep 3,235
Those paddles are the same ones used in the E82 DCT equipped cars. I had the same paddles for my car. Didn't like them. Found the paddles to be too short requiring too long of a finger tip reach. And there is no extension of the paddles downward. So what you see in the pictures is all you get. I swapped out those stock paddles for a Nelson Racing Wheel paddle kit.
10-23-2018, 03:57 AM | #19 | |
Mr. OEM
542
Rep 796
While the stock one looks huge, it's not too big and has a nice feel to it. Since the whole assembly is based on an automatic gearbox mechanism with a heavy throw, the smaller E46 shifter would make it uncomfortably hard to use it. The shifter still comes in handy navigating roundabouts and sharp corners.
10-23-2018, 04:01 AM | #20 | |
Mr. OEM
542
Rep 796
It was already nice there is just enough room between wheel and stalks to fit these. With longer downward extension, it would interfear with the cruise control stalk, since this one is closer towards the steering wheel. Although I could remove it, since the steering wheel buttons now control all cruise functions. Maybe I should do a journal topic, since the option list on this E36 is arguably the most extensive one.
