10-31-2017, 06:15 PM | #1 |
Rep 450
Metallic ringing on startup with sportcat
Just put on a fabspeed sport cat over the weekend. When I was under the car on the first startup after installing it, I noticed a metallic ring type of noise coming from the exhaust. I had never listened to the car from underneath with stock exhaust so I didn't know if it was normal or not so I left it as is. Now on cold starts there is a distinct metallic ring for the first 10-20 seconds that seems to go away after the valve closes. I can hear it from inside the car with the windows closed and it definitely wasn't there before. I think everything lined up nicely on the install and I used all new gaskets including the V Band Crush gasket for the midpipe. Any thoughts?
11-01-2017, 12:53 AM | #2 |
Rep 2,829
a vid will help us out to help you.
BMW I12 i8 Frozen Yellow- H&R springs, 22" Radenergie F10 Monoblock Forged /// F87 M2 Aw -Vorsteiner Aero Kit, VFF-107,Macht Schnell-Springs,VF-Engineering/Hex tuning Stage Two,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe/// Wish list :Mexico delivery 2024 BMW M2 (G87) |
11-01-2017, 07:50 AM | #3 |
Rep 450
I'll try taking one later today. It's pretty subtle, we'll see if it picks up over the sound of the exhaust itself
Reading more last night I think it's the wastegate that's open on startup making it so loud, not the valve. So may be related to that more so. |
11-01-2017, 10:41 PM | #4 |
Rep 450
Not the greatest audio but just for context, the audio picks up right after the initial loudest 8-10 seconds of the cold start (this was too loud for the mic), where it gets slightly quieter, and then at 15-16 seconds you can hear it go into normal idling. You can clearly hear the metallic ringing noise in this middle period. I assume the first 8-10 seconds of cold start is open wastegate and then that closes and the valve stays closed/open (?) for the next 5-10 seconds before it gets quiet. The metallic noise happens from initial startup to when the valve changes. It's not coming from the engine bay at all and appears to be loudest right at the downpipe/midpipe area but I can't really localize it. Any ideas?
Edit: this is a 2018 m2 with 1300 miles, no other mods. |
11-15-2017, 01:31 PM | #7 |
Rep 450
Reinstalled the whole thing, there are definitely no leaks and the vbands look perfect and there are no spots that are rubbing. The noise appears to be coming from the the crossmember that the midpipe attaches to or the transmission directly above that. It actually doesn't sound like it's coming from the exhaust. Still can only hear it on cold start while the wastegate and valve are open. Not sure why it's just started after install of the downpipe, maybe it's just the vibrations of the increased flow/sound...
11-18-2017, 03:38 PM | #8 | |
Rep 752
I've had that happen on multiple aftermarket exhausts (sounds just like your video), usually when the valve is closed however. Do you have a valve controller for opening and closing? |
12-14-2017, 08:18 AM | #9 |
Rep 450
Update: the noise is getting louder. Still most prominent in a cold start but I can hear it through the engine noise while driving now. I'm considering taking off the downpipe to see if it changes or goes away. Not really sure what's causing it anymore
12-14-2017, 09:51 AM | #11 |
Rep 4,541
Drives: 2015 328d xDrive
start the car while it's on a lift. that should help you find your problem area real quick.
NYC Bimmer259.50 |
12-14-2017, 12:35 PM | #12 |
Rep 450
I started the car while on jacks (and crawled under after). It's hard to say exactly where it's coming from but like I mentioned previously it seems to be above the cross member that the mid pipe attached to. I started with and without that bracket attached and the noise persisted. It almost sounds like it's in the back part of the transmission area but clutch in and out doesn't change the noise at all. I'm really not sure what to make of it or how a simple down pipe change could cause the change. I'd like to avoid taking it off again as it's a bitch to do but may end up at that point
12-14-2017, 12:36 PM | #13 |
Rep 450
I've checked the clearance on everything and it appears solid. It's also loudest right after cold start which makes me thing it's exhaust flow related?
12-14-2017, 04:22 PM | #14 |
24091
Rep 190,614
It wont go away on its own, did you check the exhaust valves?
12-14-2017, 06:03 PM | #15 |
Rep 450
12-14-2017, 06:53 PM | #16 | |
Rep 3,949
12-14-2017, 08:41 PM | #18 |
Rep 450
12-14-2017, 09:02 PM | #19 | |
Rep 220
Subscribing. I'm interested in exactly this setup and a little concerned. |
12-15-2017, 01:27 AM | #21 |
3160
Rep 9,134
12-15-2017, 03:30 AM | #22 |
Rep 87
I also have that metallic ringing sound at cold start, but after the valve closed, it goes away. The shop installed it. Mine is not as bad as yours. Maybe because of your bad recording and garage parking lot. I didn't notice the metal ring until ~300 miles because my exhaust got a lot louder after awhile (in a good way) lol.
That ringing sound is only at the cold start (5-10s). I thought I'm the only one. I just feel sorry for my neighbor when I go to work. I wish I can fix it oh well... Last edited by XProject; 12-15-2017 at 03:40 AM.. |
