08-12-2017, 10:56 AM | #23 |
Rep 198
Mak, did i read this correctly? You dynoed a dct in 4th? Should be 5th
*1996 S54 E36 M3* •2017 F87 M2•
Sold: 07' e90 335i, 08' e92 M3 |
08-17-2017, 12:21 PM | #25 | |
Rep 2,210
retired: 2014 435xi|MPPK|335 bhp|3/5 stars |
09-18-2017, 10:13 PM | #27 |
Rep 166
Today I installed my catless dp from vrsf and my intercooler. I love how the car sounds now. I will post a vid up soon.
Tomorrow I'm going to call English racing for a dyno pull and see what happens. I was missing a piece for my jb4, but mike is taking care of it. (Shoutout to mike, at extreme) and then I'll do another dyno with the jb4. Stay tuned. |
09-19-2017, 09:43 PM | #29 |
Rep 166
Dyno day is scheduled for oct 3. I'm going to do a few passes with the jb4 off, then turn it on to map 2, do a few passes and then I may or may not run a couple of gallons of e85 mixed with the 92 octane on map 7. I have heard you can do that.. but I'm not sure. So will do some more research before I do it.
09-24-2017, 08:14 AM | #30 |
Rep 3,888
Read in "Truth, Lies, and Dynojet Runs" that if you took the car to 25 different Dynojets, the numbers would read the same within 1/2 HP using SAE. But under similar environmental conditions, STD should still yield consistent results on Dynojets.
This suggests that dyno is not skewing readings and that the stock car is simply flowing more air for some reason. Also, that large of power % diff can't be explained by 66F air. The only likely reasons I can think of for a 5-6% gain in power is a problem with the car's MAF sensor reading too low or a mod to car's firmware was done. |
09-24-2017, 11:27 AM | #31 | |
Rep 238
Curious to hear your thoughts / opinion on the JB4-M2 combo!
Instagram - @niru.s1k
24 BRG M3 - Pending Delivery 17 BSM M2 (SOLD) - PureTurbos Stage 2 - BM3 - Tuned by F80Paul @ Paul Johnson Tunes |
09-24-2017, 11:58 AM | #32 | |
IG @bmwF9xG80
3813
Rep 7,593
In my testing X4 M40i (similar M2 engine) made 335/336 stock, 350/349 bolt-ons (DP/FMIC/stock intake) and 355/404 jb4 map2 (but after 5500rpm map2 was dropping under stock bolt on run.
60-130mph 6.5s X4M #HCP
09-24-2017, 12:12 PM | #33 | |
Rep 166
AmuroRay2282.50 |
09-24-2017, 12:15 PM | #34 |
Rep 166
I've had the drivetrain malfunction turn on already. I'm not sure, but honestly on the butt dyno.. it doesn't feel like anything more. But looking at the gauges they sure do go up fast. I'm going to wait for the dyno numbers and than see what happens. My friend just installed mhd on her 235, and she loves it. She is the first car with mhd and the guy is local. So I might switch over to that, depending on how the next week and a half will go and the dyno numbers with the car.
BeemerBoost118.00 |
09-24-2017, 02:00 PM | #35 | ||
Rep 238
I know without any sort of additive fueling the M2 struggles up top (HPFP crashing). I'll hopefully get back on the dyno after going through some tuning adjustments with Terry@BMS. Quote:
What octane are you running?
09-24-2017, 04:37 PM | #36 | |||
Rep 166
09-25-2017, 09:16 PM | #37 | |
Rep 3,888
All dynojets use the same fixed amount of mass for their rollers. F=ma. The 66F ambient temps only go so far in increasing oxygen density. (not 5% over other pulls done around the same temp) Therefore, logically it seems that your car is able to flow more air than others (at same atmospheric pressure and temp) for some reason. Without exhaust mod, this can only be accomplished with higher boost. Octane diff between 91 and 93 would only yield maybe 10-15hp max for stock tune. Most M2's on different dynojets have peaks around 330-335 depending on the octane level. Last edited by zenmaster; 09-25-2017 at 09:21 PM.. |
09-27-2017, 03:23 AM | #38 | |
Rep 12
Glad to see an M2 going to English Racing for some work. I hope there are many more. Maks, do you have the .drf file for that run 003 that you showed in the first post? (003.drf) I would really like to look at it in WinPEP7 where I can see everything without straining my poor eyes LOL. When Lucas loaded my DSM onto his gigantic trailer in 2015, the other 3 cars on it were all Nissan GT-Rs. No BMWs. Would be nice to see that change! |
09-27-2017, 07:55 AM | #40 | |
Rep 650
09-27-2017, 09:16 AM | #42 | ||
Rep 166
09-27-2017, 11:57 AM | #43 |
IG @bmwF9xG80
3813
Rep 7,593
I've dumped WinPep7 as it only shows White Background, a little higher numbers and no temperature, humidity, unlike Winpep8 more features more info and easier on the eyes for overlaying different size.
09-27-2017, 03:15 PM | #44 | |
Rep 36
The STD CF is an older standard that yields slightly higher HP numbers, so don’t allow yourself to fall into the trap (just use the SAE CF!!). Dan Hourigan Vice President, Dynojet Research, Inc. |
FSociety3812.50 blackholescion272.50 |
