M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > MPE + Fabspeed Sport Cat
      04-11-2017, 04:12 AM   #23
Dav3
Dav3's Avatar
947
Drives: G87 M2/E89 35is/F21 M140i/GT4
kiysersosae Any update on the video?
      04-11-2017, 07:53 AM   #24
AGM2
AGM2's Avatar
Drives: M2 LBB 17
+1
      04-11-2017, 10:58 AM   #25
Fabspeed Motorsport
Fabspeed Motorsport's Avatar
Drives: BMW M235i
      04-13-2017, 10:43 AM   #26
mike@x-ph.com
mike@x-ph.com's Avatar
In stock, get your orders in before we run out again
https://x-ph.com/sale/
Phone number 702-494-9435
      04-28-2017, 11:41 AM   #27
AGM2
AGM2's Avatar
Drives: M2 LBB 17
Thanks MIKE only 5 left
      04-28-2017, 11:47 AM   #28
mike@x-ph.com
My pleasure
      05-03-2017, 02:13 PM   #29
gavinsan
Drives: F82 M4
I have recently gone with this set up and it is exceptionally good .
The sound over stock is much more aggressive and you can hear the turbo spool much more .
The less restrictive cat is noticable immediately
I would highly recommend
      05-03-2017, 02:27 PM   #30
Fabspeed Motorsport
Drives: BMW M235i
Oh yeah!
Thank you!
gavinsan149.00
      05-08-2017, 12:52 PM   #31
TXSurfer
TXSurfer's Avatar
Drives: 335i E92
Oh yeah!
Thank you!
So what was the verdict with the MPE I'm looking at purchasing.
      05-08-2017, 06:07 PM   #32
BishUK
BishUK's Avatar
440
Drives: M2 DCT LBB
I dyno'd 393bhp at the wheels, I'm running Fabspeed Sport Cat, ITG panel filter and MPE.
The car sounds insane in track mode, not far off a V10 Huracan when nailing the M2 in long tunnels.
Turbo is eager and ready to go all the time, car is really pulling hard at 3,000rpm and beyond. A little rev time when stationary at the lights in track mode is smile inducing - car has really transformed in to an animal.
Having Wagner IC, ER charge pipes, PureTurbo's Inlet pipe and new DV+ fitted to end of week so hope to break the 400bhp zone pretty comfortably.
All running 99 Ron.
      05-08-2017, 06:52 PM   #33
LBBDrew
Drives: 2017 LBB M2
Nice man! did you do a before dyno run?
All running 99 Ron.
      05-08-2017, 07:13 PM   #34
No Boost
enthusiasm > practicality
No Boost's Avatar
Drives: 987 CS | G35x
Isn't bhp at the wheels contradictory? But yes, the sport cat DP alone gets you close to 400 bhp.
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp
Left lane campers, GTFO!
AndrewC198910903.50
BruceM983.00
      05-09-2017, 02:08 AM   #35
BishUK
BishUK's Avatar
440
Drives: M2 DCT LBB
Nope, didn't Dyno stock car I'm afraid, wish I did really. I was part of a group of 4 M2s that dyno'd back to back on same dyno. 2 were completely stock, one hit 362, the other 364bhp - I've heard from others too so it's pretty safe to say BMW are being very accurate with their bhp quotes for M2, if anything, general consensus says it's actually a little under 370.
Will Dyno again once IC and hard-pipes have been installed.
      05-10-2017, 07:05 PM   #36
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
When you dyno a car, it ceases to be bhp and it becomes whp. Bhp is what the engine makes at the flywheel. So 365bhp is what the m2's engine has from factory. Whp is what the entire car (not just the engine) actually puts down at the wheels on a dyno. Bhp is typically 15% higher than whp on a rwd car. They're not interchangeable terms, nor should they be used together. You can't have 393bhp at the wheels. You can either have 393bph or 334whp.
https://www.carthrottle.com/post/the...whp-explained/
BruceM983.00
No Boost4019.00
Corinne1171.00
      05-10-2017, 07:51 PM   #37
Deutsches Blut
82
Drives: 2012 335i E92 M Sport / 2008 C
Thanks everyone, you all just made my wallet lighter! I will now have to get a dp.
      05-10-2017, 08:00 PM   #38
No Boost
No Boost's Avatar
^^that's some funny shit Andrew. I really wish all car manufacturers had to abide by the SAE formula that I believe GM uses, a set-in-stone standard. Dynos are great for modding a particular car so you know the HP and TQ that was added after said mod. Other than that, there's just too many variables between each machine. One dyno could read 340 for an M2, another could read 320. These dynos cost upwards of $100k. You'd think they would be surgically accurate uniformly across the board. I'm done bitching. I'll take Dinan's word for it....360 bhp for stock, 446 for P2 package, add 30 for the 200 cell DP and viola...476 bhp is what I'll tell people.
      05-10-2017, 08:08 PM   #39
AndrewC1989
i only use bhp if i'm talking to someone who knows nothing about cars because i don't feel like explaining the difference to them and i'm sure they don't care. when i'm talking to a fellow car enthusiast or modder though i don't ever use anything other then what i make at the wheels. a dinan p2 pack with a fabspeed sportcat will make around 380/390wheel. You can probably get away with just saying 400wheel to make your life easier. or if you wanna be "that guy" you can say 475 and then explain yourself
"A customer of ours hit our Dynojet to see what his built up M2 can do.
This M2 has the following components:
Fabspeed Sport Cat Downpipe
Dinan "Big Turbo" Upgrade
Dinan Exhaust
Dinan Intercooler
Dinan Intake
Dinan Tune
POWER NUMBERS
382.01 whp at 6,200 RPM
408.71 ft-lbs of torque at 3,4200 RPM"
No Boost4019.00
      05-10-2017, 08:47 PM   #40
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
All running 99 Ron.
IC makes very little, if any, horsepower unless your car is overheating from a single gear pull, which mostly happens only with aftermarket tune. You probably will lose power, seeing 1~2 psi pressure drop from bigger IC and no better timing from cooler IAT.
Even catless DP, without tune, will net you no more than 10~15whp in peak. The nice gain you see in down low is mostly a result of quicker spool up.
Whatever stock power you think m2 is making, 10~15whp more is what you have with your current setup.
Lemania 2320
      05-11-2017, 09:18 AM   #41
auf Deutsch
auf Deutsch's Avatar
2017 BMW M2  [0.00]
Dinan Exhaust
Dinan Intercooler
Dinan Intake
Dinan Tune
POWER NUMBERS
http://f87.bimmerpost.com/forums/att...1&d=1484529911
I'm thinking of going back to this particular dyno. I put down 349/367 bone stock and 367/408 with the Dinan sport tuner only (no DP).
I should absolutely crush the 400 whp barrier and push upwards of 450 WTQ on this sweetheart of a dyno....if only for bragging rights. Thoughts?
retired: 2014 435xi|MPPK|335 bhp|3/5 stars
      05-11-2017, 09:39 AM   #42
Fabspeed Motorsport
Drives: BMW M235i
All running 99 Ron.
That sounds awesome! And thank you for the kind words!
Our Sport Cat is 200% the way to go! I'd be happy to get you set up with one if you'd like! Check your PMs!
      05-11-2017, 10:43 AM   #43
AndrewC1989
I'm kinda bummed that you're barely cracking 400 with the P2 and a sport cat. Their claims were much more...enthusiastic.
You're running a full bolt on set up with modified turbo's and only getting a 50hp gain? To me it doesn't seem like it's worth $6000.
      05-11-2017, 10:54 AM   #44
velociti
Drives: 2009 E90 M3
That's BHP claims from Dinan, though. With a roughly 13-14% drivetrain loss, you're roughly at what he put down on the dyno. I do agree that even then, though, their claims seem a little optimistic, and the "value" component of $6000 is pretty nonexistent. As always, it's about warrantied, flexible (in terms of octane), and bulletproof power when you go the Dinan route.
Meanwhile, VF's Hex tune and the Fabspeed downpipe get you...
