M2 Technical Topics > Track / Autocross / Dragstrip > The track tire thread
      04-27-2017, 04:02 PM   #23
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Some other strange options. Dunlop Sport Maxx Race, Cup 2's, contiforcecontact's
      04-27-2017, 04:07 PM   #24
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Originally Posted by swebster View Post
Here is my impression of both.
RE-71R are amazing. I have used them on this car and the E36. They are great grip for the track. Basically a street legal slick with treads. They do wear quickly. Went through one set in 3 track days. Probably right now the best DOT track tire out there. They are also light which helps for rolling resistance etc.
Hankook RS-3- I got a deal on these and know I see why. These tires on the track are horrible. The car squeals and pushes quite a bit. They are significantly heavier than the RE-71R. The one positive is that they are more durable. For regular street use they are fine but for track I wouldn't recommend. Probably about 2 seconds slower than the RE-71R.
Going to try the TOYO R888R soon through a sponsorship so that will be interesting.
The re-71rs seem to be heavier than all options. What did yours weigh? A 265/35r19 lists at 30lbs! RS3's are lighter and a good compromise/added grip vs MPSS. Those options weigh around 24-26 I believe. How loud are they on the street? What sizes did you run?
      04-27-2017, 07:03 PM   #25
rich8566
rich8566's Avatar
Drives: M2 + Z-4
2014 BMW M235i  [0.00]
Originally Posted by isjoey View Post
rich8566 - Pretty normal, for about any tire, on about any stock car. This is a result of the following - driving style, suspension setup (ie camber) and tire pressure. All three need some adjustment I'd bet. Switching tires will only cover the real issues up. Do you have camber plates?
No camber plates on the old 235i.
      05-02-2017, 05:49 PM   #26
TimOudin
Drives: 2017 BMW M2
Big fan of the Yokohama AD08R here! Haven't run them on the M2 yet but have gone through several sets on a Cayman S. I found them to be a great balance of dry traction, wet traction, heat tolerance, and low road noise for that DD duty. These are some of the best tires I've driven to date since Dunlop stopped making the Star Spec ZI, and in the Cayman they'd go pretty long before getting greasy. I cannot compared to the RE-71R though from what I've heard they probably would out do the AD08R in the dry.
Long life was not a strong suit, though the Cayman was pretty hard on tires with weight on the rears and not nearly enough reasonable options for getting camber into the fronts.
      05-04-2017, 10:59 PM   #27
Jamesembry
Drives: X5
Has anyone run the sport cups?
2024 GLS
2016 X5
      05-04-2017, 11:08 PM   #28
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
Agree. Also the fact that when he switched out from MPSS he also went square. That will give some improvement in wear on the outer front compared to the staggered setup.
      06-11-2017, 09:48 PM   #29
Mr 2
Drives: 2017 LBB M2
All, what about a moderately competitive autocross tire? Is the MPSS in a 265 fr/275 rear or maybe even 275 all around going to be somewhat competitive?
I'd love to get RE71 but this is my quasi daily driver. IMO you can't touch the RE71 for autocross. I had them on a modified Evo and it flew.
Would the RE-11 be a better autocross/daily driver tire? They are discontinued but looks like tire rack has a few sets left.
      06-11-2017, 11:49 PM   #30
dvas
dvas's Avatar
518
Just ran these (Sport Cup 2) at the Glen - I had my dealer install them on the factory wheels pre-delivery (245/265). Pricey relative to the competition but I'm very impressed by the grip level and soft breakaway. For me, it was good for 2:15 on an otherwise stock car.
CrashFL137.50
      06-18-2017, 06:12 PM   #31
aarodynamics
Drives: 17 M2/08 M3/15 Golf R/20 GT4
I just ordered some Pirelli Trofeo R tires and am going to run these on my OE wheels until Apex ships my new FL-5 wheels in January 2018. After that, I'll switch back to my usual NT05 tires or possibly BFG R1 tires. You can't beat the performance of the NT05 for the price.
You absolutely can run MPSS, MP4S, RE11, DSS, etc tires on the track, but they're ultimately street tires and they'll fall apart if you're a seasoned driver that's pushing the car to even 8/10.
rich8566608.50
      06-18-2017, 08:33 PM   #32
rich8566
rich8566's Avatar
Drives: M2 + Z-4
Did you run OEM pads at the Glen?
      06-18-2017, 08:47 PM   #33
MaritimeM235i
Drives: 2015 M235i, Estoril Blue
2015 BMW M235i  [0.00]
Not running an M2, but saw this tire thread. Running M235i with tuner boost up to 275 Hp at the crank and significant increased torque. Had same issue as rich8566 with MPSS- got greasy at temperature and even though wear was even across face, the walls were soft and you get flaking and chunking of rubber down to the steel belts on the outside edges—would not recommend them for track. Right now running Hancook RS4's (235/R40/18 F, 255/R35/18 R) and they are very nice. Heat up well, maintain lots of grip, even wear, will last longer than RE71's. Paired with 19 lb 18" rims, shaved 3-5 seconds off lap time on track where 1:20 is an excellent time.
rich8566608.50
      06-19-2017, 09:56 AM   #34
dvas
dvas's Avatar
518
PFC08s
      06-19-2017, 06:28 PM   #35
rich8566
rich8566's Avatar
Drives: M2 + Z-4
You must mean 375 hp at the crank, not "...Running M235i with tuner boost up to 275 Hp at the crank and significant increased torque."
daijc32.50
      06-19-2017, 07:55 PM   #36
MaritimeM235i
Yes- finger hit 2 rather than 3.
Always good to have proof readers!
rich8566608.50
      06-21-2017, 11:38 PM   #37
Mr 2
Drives: 2017 LBB M2
Any thoughts on running a 265/40/19 RE71 on all four tires? Square setup should make rotation easier and a 40 series tire would add 2 mph or so to the top speed in 2nd gear. Plus they are about $50 cheaper a tire than 35 series
      06-22-2017, 03:20 PM   #38
rich8566
rich8566's Avatar
Drives: M2 + Z-4
If these tires change the speed in any gear then that amounts to a change in gearing. So in this specific instance wouldn't this amount to slower acceleration? Also, what about the weight of this tire - can I assume it is heavier than the OEM tires? Last question - wouldn't you need to change out the staggered wheels since I don't think you'd want to rotate the rear rims to the front.
      06-23-2017, 07:52 AM   #39
Mr 2
Drives: 2017 LBB M2
Lol, whoops the fronts would look like monster tires with 265/40.
It would be slower acceleration day to day but might help with not having to shift on certain autocross courses where there is a long straight and not worth it to shift to 3rd and back down to 2nd at the next turn. Running 275 or 285/35 would also do the same thing and lots of people are at least going 275/35 on the rear.
      11-17-2017, 12:39 PM   #40
iceboss23
Drives: 2016 M2
I finally broke down and got the TRM 18" wheels and a set of square 265/35/18 Hankook RS4 and ran out at VIR a couple weekends ago. I chose them over the RE71 because performance reviews were so close across forums and Tire Rack + $50 less/tire + universally being regarded as a much longer wearing tire = better overall value. Tires felt amazing compared to the stock MPSS. Granted this is my first experience with any upgraded tire but the grip was extremely confidence inspiring and I knocked about 4-5 seconds off my best previous time (best now 2:13.75). Also very impressed with ride quality, noise levels, and wear. It doesn't even really look like they've been used and I beat on them for 2 days... to be fair we had some rain the first day so that certainly helps. Overall very happy with the purchase and will update as I do more events.
rich8566608.50
      11-22-2017, 10:32 PM   #41
SEAT TIME RULES
SEAT TIME RULES's Avatar
1103
2020 BMW M2C  [5.00]
If you can get them to fit the BFG Rivals are a solid track & Solo 2 tire.
17
P255/40ZR17
89W
18
P275/35ZR18
87W
P315/30ZR18
91W
P335/30ZR18
95W
On my 2017 MX-5 RF I run the 245/40/18 Rival 1.5's.
I've also run the Hankook RS-3's in the past and they are a solid durable option as well.
There are tires I ran on a FR-S and the MX-5.
On my 510WHP EVO I run BFG R1's. 285/30/18's. You would be surprised how many HPDE's I can squeeze out of a set. (Not for the street)
YMMV,
HAZMAT
2004 Mazda Rev It Up Finalist
HPDE Instructor 2002- to present
rich8566608.50
      12-19-2017, 04:43 PM   #42
Noel911
Drives: 2017 M2 & 2019 Golf R (Daily)
I'm using four 265/35/18 RE-71Rs on Apex EC-7 18X9.5" wheels for track work. Nice since they can be rotated to even out wear. No rubbing, no issues.
Oh, all four also fit in the back seat of the M2 for transport!!!
      12-19-2017, 04:59 PM   #43
Jevi Javi
Dominican Republic
80
Drives: e46 M3 + G05 X5
I'm using 275/35r18 Hankook RS-4s. I have over 30 laps on them. Not happy. They are not faster than the MPSS. Pretty similar lap times. On the other hand, they do seem to be a durable tire. Anways, Im going to be ordering a set of RE-71Rs soon.
CrashFL137.50
      12-21-2017, 10:21 AM   #44
gsrbri
gsrbri's Avatar
Drives: F87 6MT
I've run MPSC 2 tires in the factory sizes (star spec) and very pleased with them at LRP. I have stock suspension and definitely need camber plates - I can see the front shoulders are overheating.
I drove the car to the track to remove the mold release compound, and they are great on dry roads (not noisy but quite stiff - no shock there).
