10-08-2017, 07:19 PM | #199 |
Rep 360
The M Performance is not thicker than the original wheel.
I reckon the Alcantara is probably warmer to the touch than the standard leather. |
10-08-2017, 07:53 PM | #200 | |
Rep 236
Can someone that has done the swap confirm that it is not thicker. Maybe do a side by side photo of the two, I really thought it was thicker. Thanks in advance. |
10-08-2017, 08:00 PM | #201 |
Rep 1,011
it is thicker. there are photos comparisons out there somewhere. it certainly feels a lot more substantial. the alcantara is very temperature neutral. so on very cold or hot days it is the same unlike leather. i was happy to give up heated steering in favor of the huge improvement in feel, aesthetics, and confidence.
2017 x5 w/MPPK & MPE build thread
http://f15.bimmerpost.com/forums/sho....php?t=1427846 |
AndrewC198910903.50 |
10-08-2017, 08:14 PM | #202 |
Rep 360
Maybe there are thickness differences in the different variants. Mine is the full Alcantara with the LED display. Doesn?t feel thicker than the original.
10-08-2017, 11:06 PM | #203 | |
Rep 1,514
http://f87.bimmerpost.com/forums/sho...1&postcount=97 |
10-09-2017, 02:34 AM | #204 |
Rep 327
Drives: Ex BMW owner, will return soon
This thread is not about the LED display wheel, it's about the M performance wheel that debuted when around the time when the M2 launched. The one you're talking about is much thinner you're right, about the same thickness as the stock wheel which is why I never considered buying it. The M performance wheel is not only thicker than the stock wheel, it's also shaped differently. I only wish it was smaller in diameter, other than that it's one of the best steering wheels I've held.
10-09-2017, 02:21 PM | #205 |
Rep 360
I wouldn't have changed the wheel if not for the lack of oil/water temp displays on the M2 otherwise, the original rims was just fine. Honestly, Alcantara doesn't seem to wear well.
11-06-2017, 08:17 AM | #206 |
Rep 54
Drives: M3 CS (LRG)
Hi does anybody know where to find a user manual for the wheel with race display?
Even non-official is fine. Seems like there is no official user manual. |
11-07-2017, 09:57 PM | #207 |
Rep 715
11-13-2017, 02:27 PM | #208 |
Rep 110
If you are purely worried about wear, taking care of alcantara isn't too hard. Just need to clean it once in a while and it goes back to almost brand new. Sonax has some good stuff to clean alcantara. Just an FYI if you were on the fence.
12-05-2017, 07:59 PM | #209 |
Rep 521
Just installed this wheel over the weekend, big fan cosmetically and its tactile feel. One thing I like is the groove behind the 3:00 and 9:00 location of the alcantara where your fingers can really dig in to.
Also, one question to owners, I'm pretty sure my lane assist motor is rubbing against my wheel trim as I can hear it when it triggers. It'll be a 10 min job to get back in there (after the 20 min wait after disconnecting the battery). Question is do you get much feel from the vibrations from this wheel? I know with the stock m wheel, I barely feel it compared to my wife's standard wheel in the X1 where it really vibrates. Photo for bait! |
AndrewC198910903.50 IND-Distribution9549.00 |
01-21-2018, 06:27 PM | #210 | |
Rep 1,895
Current: 11 E90 M3 ZCP / R8 Performance
Past Performance Cars: 01 M3, 05 M3, 06 M5, 08 M6, 08 M3, 11 M3, 13 M3, 15 M3, 911 C4S, 911 GTS, 17 M2,R8 V8, R8 RWS |
01-21-2018, 08:09 PM | #211 |
Rep 1,011
01-23-2018, 02:44 AM | #213 |
Rep 715
I was on the fence for a couple of weeks and now can't live without it. Drove Mum's 430 the other day and it just doesn't feel the same. Too thin.
01-23-2018, 06:48 AM | #214 |
Rep 1,011
i can't imagine the drive without the upgraded wheel. the extra contours and girth and weight are incredible. the feel of the material is excellent.
01-23-2018, 09:12 PM | #215 |
Rep 1,895
Excellent. I'm shopping to order.
I plan to use the stock cover. Not buy the carbon fiber one. I can do that correct? I thought I read in one of the threads that I can re use it. Partly being cheap. The other is it might be a little too much CF for me. TIA
01-25-2018, 12:27 AM | #216 |
Rep 360
Correct, the CF one is the same as the stock one. You can use the stock cover with the M Performance wheel, and you can use the CF cover with the stock wheel.
01-25-2018, 02:03 AM | #217 |
Rep 327
Even the normal cover from non full M cars works.
02-03-2018, 03:35 PM | #218 | |
Rep 1,895
While it feels nice and meaty. Is it leather or plastic on the wheel? It feels very plastic on install. I miss the nice leather on the M2 M wheel. Is it leather on the performance wheel, and will it break in to be soft like the stock M wheel?
