12-16-2021, 05:02 AM | #1 |
157
Rep 588
BMW F87 M2 Competition Genuine M Performance 2-way Coilover Suspension Retrofit
Installed this set of suspension onto this 2020 F87 M2 Competition track package.
Many would say there isn't any differece between this set of coilovers and KW V3. This set of coilevers were specifically tuned and modified for the M2 competition. The car is currently running factory damper settings: Front Rebound: 9 clicks open Front Compression: 6 clicks open Rear Rebound: 12 clicks open Rear Compresison: 6 clicks open The car is really turning into corner with a much stiffer feeling and give you so much more confidence when you're really gassing the car. |
12-16-2021, 05:19 AM | #2 |
Rep 95
Drives: BMW M2C
Very nice! Did you also install camber plates?
12-18-2021, 02:36 PM | #4 |
Rep 57
confused on how this is a retrofit?
And these are almost identical to the V3s with the exception of not being able to lower as much
2020 M2C 560/540 f80 paul stock turbos,
7??/6?? Kratos EVOS |
Tags |
f22, f87 m2, geunine suspension, hong kong, icarmix, lowering, m competition, m235i, m2c |
