M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > M2 dyno'd with Dinan Sport tuner
      01-17-2017, 07:52 PM   #45
RPM2-85
Drives: 2017 M2 AW
Originally Posted by zenmaster View Post
Isn't this a simple air mass sensor piggy? If so, there is no f*cking with the boost, as you get the same effect by driving at high elevations.
Boost controller.
      01-17-2017, 08:01 PM   #46
zenmaster
Drives: '17 M2
Originally Posted by RPM2-85 View Post
Boost controller.
Looks like a MAF signal modifier to me. I'm just looking at the connectors.
      01-17-2017, 08:05 PM   #47
RPM2-85
Drives: 2017 M2 AW
Thats where it plugs into...... I guess your saying theres no way to control boost from that connector?
      01-17-2017, 08:19 PM   #48
PackPride85
It's sitting on the MAP sensor on the charge pipe. Most likely limits the output of the sensor either at the top end of the signal range or some variable value throughout. Either way, these are generally not considered ideal and can lead to issues.
      01-17-2017, 08:27 PM   #49
zenmaster
Drives: '17 M2
No, it will allow you to control boost in an indirect manner. It's more like a boost "influencer".
The car automatically determines appropriate boost level to move an amount of air. When the air density reduces (e.g. at altitude), the car applies more boost. When air density increases (e.g. very cold day) the car will applies less boost (than a warmer day).
BMW want theirs turbo cars to produce a consistent amount of power under varying atmospheric conditions. Devices like this exploit the fact that there is a higher, reserved, boost pressure limit built in by the factory programming. The car should stop producing boost past max programmed limits because the ECU is still getting the actual boost reading.
So by changing the MAF reading, the boost is effectively raised (to the factory limit) or lowered. Hence "boost controller". Anyway that's my understanding of it.
      01-17-2017, 08:38 PM   #50
zenmaster
Drives: '17 M2
Yeah I'd think the A/F ratio might be off some, but other than that I'd think it'd either work or not. I'd be more concerned about heat and/or turbo stress which this device should not really induce on 93 octane. You probably don't want to run this device on 91 octane with an M2 unless you are in a cold climate. Terry already showed where timing was pulled on 91 in stock form.
Also, I don't think you can get legitimate dyno results on this by doing quick back-to-back runs. You probably have to drive the car for many miles after installation and do several WOT runs, for ECU adaption purposes.
      01-18-2017, 06:52 AM   #51
auf Deutsch
auf Deutsch's Avatar
2017 BMW M2  [0.00]
You're right, it's not ideal given its one sensor connection point. It merely manipulates the DME into making more boost. That doesn't mean it's not a great product. I'm using it as a stopgap until the weather warms up and I can get stage 4 done. I can't get the power down as it is right now.
I've had zero issues running 93, smooth as butter.
As for the dyno runs, the first run was with the unit on (installed and continually running for about a month). Then we dyno'd with it disconnected. The results should be viable .
retired: 2014 435xi|MPPK|335 bhp|3/5 stars
No Boost4021.00
      01-18-2017, 07:27 AM   #52
RPM2-85
Drives: 2017 M2 AW
SO if this is the case, then the DME should never read overboost levels? Effectively the DME cant record anything out of the ordinary because it doesnt have the ability to go past stock configuration. Maybe this device cant be seen by the dealership if removed?
Anyway, I am going to run an intercooler with this setup for a while once the heat comes back. Then possibly go to a Bootmod3 setup down the road. Its fast enough now so I just want to dial in what I have.
Either way, the DME has acted wonderfully and gives loads of power with no lag all over the place. I absolutely love love this engine. 2nd gear fights for traction. Its funny to be at 2000rpms and instantly have the tires start to shred when you mash it.
      01-18-2017, 10:07 PM   #53
zenmaster
Drives: '17 M2
AFAIK, it should only provide a way to make use of the built-in amount of overhead boost. The computer is still reading direct AIT, waste gate duty cycle, A/F etc. You shouldn't get a fault unless something is wrong with the signal, because the ECU programming is designed to compensate for the (viable) MAF signal range indicated.
      01-19-2017, 06:59 AM   #54
auf Deutsch
2017 BMW M2  [0.00]
Exactly!!! Get a DP and the thing gets pretty squirmy.
Waiting to hear back from Fabspeed Motorsport to set up an appointment for install and subsequent dyno runs.
No Boost4021.00
BAN_M2C4185.00
      01-19-2017, 07:09 AM   #55
No Boost
enthusiasm > practicality
No Boost's Avatar
Drives: 987 CS | G35x
Looking forward to your review
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp
Left lane campers, GTFO!
      01-19-2017, 02:27 PM   #56
Fabspeed Motorsport
Fabspeed Motorsport's Avatar
Drives: BMW M235i
I'm excited to get this all done for you! You're definitely going to notice a difference with the Sport Cat. Boost hits in a lot harder and turns these cars into little rocket ships.
pup73 Thanks for chiming in! I hope all is well with your M2 and S2K!
BAN_M2C4185.00
No Boost4021.00
pup73516.50
      01-25-2017, 10:08 AM   #57
twin fed
Doc Brown
twin fed's Avatar
1176
Drives: 2016 MG MT M2
I am going to be ordering the Fabspeed sport cat real soon
      01-25-2017, 10:16 AM   #58
auf Deutsch
2017 BMW M2  [0.00]
By all accounts, it's the one to have.
      01-25-2017, 10:18 AM   #59
twin fed
Doc Brown
twin fed's Avatar
1176
Yeah, that seems to be the case.
      01-25-2017, 02:05 PM   #60
Fabspeed Motorsport
Drives: BMW M235i
I'd be happy to get you set up with one! Check your PMs!
Thanks bud!
pup73516.50
      01-26-2017, 08:53 AM   #61
twin fed
Doc Brown
twin fed's Avatar
1176
Thanks bud!
Thanks, but we had already talked and I mentioned the deal that I was getting from Mike at Extreme and you told me to go with him. But anyway, I ordered it today. Can't wait to install it and see how this beast opens up!
      01-26-2017, 09:17 AM   #62
Fabspeed Motorsport
Drives: BMW M235i
Sorry for the brain fart, so much stuff going on here on a day-to-day basis. We have to respect our retailers but I'm glad Mike was able to take care of you - he's a great dude!
      01-26-2017, 11:15 AM   #63
twin fed
Doc Brown
twin fed's Avatar
1176
No problem, I totally hear ya. He definitely hooked it up!
      03-06-2017, 10:24 AM   #64
NO_USER_
Drives: .
What gear should the 6 speed manual be in during a dyno run?
      03-06-2017, 11:00 AM   #65
Fabspeed Motorsport
Drives: BMW M235i
6spd cars usually are dyno'd in 4th gear but every car is different. I know we dyno the M2 in 4th gear.
      03-06-2017, 11:03 AM   #66
NO_USER_
Drives: .
Thanks! I've been reading some have been doing the manual M2 in 5th gear as well. Do you know what the gear ratios are? Wonder which one is closest to 1:1
Thanks!
