03-16-2024, 02:47 PM | #1475 | |
Rep 613
Drives: F87 M2 CS
I went back and forth on whether I should even bother. But ultimately decided to finalize the suspension job the "right" way. That said, I wasn't about to spend $250+ on something I didn't really need. I read positive reviews of Garagistic endlinks from the E3X community and decided to take the chance. Quality seems great, but time will tell on how they hold up.
Current: F87 M2CS - 6MT | Öhlins R&T | Garagistic Endlinks | Autosolutions SSK | AA EL Midpipe & Axleback | 255/275 PS4S
Gone: F87 M2C - 6MT | Öhlins R&T | G.C. Camber Plates | Autosolutions SSK | UCP | AA EL Midpipe & Axleback | Apex EC-7 | 265/295 PS4S |
medphysdave4615.50 |
03-20-2024, 05:03 AM | #1476 |
Rep 177
Incredible - you will NOT regret it! Performance aside, the complete lack of brake dust is something I will never stop appreciating. Had 300 miles between my last washes and not a lick of dust. I take my 350R around the block and the wheels are covered.
Love gold on gold, but they also look SOOO good behind black. I just had to have both |
4
04-08-2024, 04:40 PM | #1477 | |
Rep 454
Taking off the bumper is not as difficult as it would seem. I am not super seasoned in taking cars apart and I had it off more than a dozen times to fit the parts. Thank you COVID for all the time at home. Looks awesome in there thrilla
Ride: 2020 F87 M2C, 6MT Drive: Nine-Four Motorsports
Before: 2013 - 3.8L GTR, first DCT 2012 - 5.2L R8 v10, 6MT 2011 - 4.0L E92 M3, 6MT |
04-09-2024, 03:59 AM | #1478 | |
Rep 893
Drives: F87 M2CS
MY18 F82 M4
Austin Yellow / Black / DCT / MPE |
04-10-2024, 04:45 AM | #1479 |
Rep 177
Purchased from another member on here. They occasionally pop up, and can snag a used set for $2.5-3K depending on rubber…would just keep an eye out and a set will eventually surface. And I agree going OEM CS is the way to go…just a slight bit cleaner!
Reddevils71060.50 |
04-24-2024, 08:54 PM | #1480 |
Rep 4,718
Added some carbotech 1521 pads today. They are definitely not a "grabby" pas, but seem linear. The harder you press the quicker you stop. Quiet from the start. Per recommendation from carbotech I added some permatex to the pistons and holes wheres the retaining rods slide through the pads. I think this is where the horrid squeak was coming from in the xp12s. I used the high temp permatex. Probably wouldn't survive a track day, but it might. I'm going to try some when I swap back to the xp12 for mountain runs this summer.
05-03-2024, 02:08 AM | #1481 |
Rep 73
Hi all,
Apologies if this has been asked before. But where can I find a “wet” carbon interior kit for the CS similar to M3/M4? Seems like the regular M2 M performance kit is dry carbon which doesn’t fit the CS. Looking to replace DCT gearbox base (with alcantara), gear and potentially the CS trim |
Jimjamz4602.50 |
05-03-2024, 08:23 PM | #1483 | |
Rep 893
Drives: F87 M2CS
MY18 F82 M4
05-03-2024, 08:36 PM | #1484 | |
3037
Rep 13,778
That's where I originally bought the hood insert in carbon.
~loud noises~
05-04-2024, 09:14 PM | #1485 |
Rep 4,718
I finally put on the carbotech 1521 pad. No noise and very little dust. The only dislike is the rear pads "clunk" when going in reverse. I find that the 1521 takes a little heat before it bites like I like.
Thefog_M2CS91.50 |
05-05-2024, 01:31 PM | #1486 |
Rep 34
Interesting, I have to look into those for sure.. thanks!
05-06-2024, 10:13 AM | #1487 |
In the garage
392
Rep 213
Recently installed MAD DPs. Great fitment and quality for $350. Need a better audio clip, but with the valve controller (Thanks DadVibes) it's very tame when closed, or fairly loud when open. Cold start with valves open is a little obnoxious but not too crazy.
https://photos.app.goo.gl/gR2LGGFf7o7LQf6v6
BMW M2CS 6MT
IG/TikTok: jd_m2d2 |
05-09-2024, 02:45 PM | #1488 |
Rep 38
05-09-2024, 02:53 PM | #1489 |
Rep 283
Yes, good with the quality and the materials. I did select a color for the Alcantara that’s slightly darker than stock BMw but did find out that they have another color that’s an exact match.
2020 M2 CS - Misano Blue, DCT, CCB
Crossmax54.00 |
05-10-2024, 03:57 AM | #1491 |
Rep 283
Here are a few of the pics I had.
05-17-2024, 04:37 PM | #1493 | |
Rep 2,211
Drives: G81 M3 Touring (Frozen Black)
