10-23-2020, 03:28 PM | #1 |
Rep 403
Xpel Stealth Cost? Thoughts?
Has anyone put Xpel Stealth on your M3/M4? What was the cost to do the entire car?
In addition, I've read that Xpel Stealth gives the car a satin finish. Does that defeat the purpose of having matte paint? I'm considering Frozen Grey on a convertible M4 CS when it comes out next year (need AWD for winter), but am wondering if I am asking for a potential disaster considering I live in a snowy climate (can't hand wash when it's below 0) and it will be my daily driver. Thoughts? |
10-23-2020, 06:15 PM | #2 |
Rep 781
Hi !
As i ordered mine in frozen dark grey I also made a lot of thoughts about it. I was thinking to put an Xpel Stealth on it so I would appreciate if someone here has experience with that? But what I certainly will do is a ceramic coating, I read here this is pretty good and not so expensive. I asked my Dealer but unfortunately they don't do it so I will check with another Garage as soon as I get the Car. |
10-25-2020, 09:59 AM | #6 |
Rep 201
10-25-2020, 10:03 AM | #7 | |
Rep 201
Stealth is really your only option over frozen paint if you don’t want to add gloss. If you need help locating a good installer near you feel free to contact me and I’ll see who’s in your area. |
10-25-2020, 10:45 AM | #8 |
Rep 636
Drives: f32 430ix & 982 GT4 PDK
How does stealth coats compared to say ceramics? Noob here when it comes to coating / exterior mods.
10-25-2020, 01:41 PM | #9 |
Rep 404
10-25-2020, 01:43 PM | #10 |
Rep 636
10-25-2020, 01:49 PM | #11 |
Rep 1,369
When I contacted PPF installers, I was told it was the same price for stealth and regular. $6.5K sounds about right in the northeast
IG: @rise_n_drive
10-25-2020, 02:02 PM | #12 | |
Rep 404
Ceramic coatings are gloss enhancing coatings that give your clearcoat chemical resistance, slickness and hydrophobicity But those come in bottles, Xpel Stealth is a film applied to your paint similar to tinting windows |
Avaley736.00 |
10-25-2020, 04:00 PM | #13 |
Rep 403
10-25-2020, 04:20 PM | #14 | |
Rep 404
But it can also be applied over your gloss paint finish to give you that frozen/matte look |
10-25-2020, 04:27 PM | #15 | |
Rep 403
What's the visual difference between Frozen Black paint covered up with Xpel Stealth vs Black Metallic paint covered up with Xpel Stealth? Will they both appear with matte finish? If so, why would I spend the $3600 on the frozen paint upgrade? |
10-25-2020, 05:05 PM | #16 | ||
Rep 404
Stealth film would cost more than the frozen up charge If you did opt for frozen at $3600, there are much cheaper ceramic coatings specifically for frozen/matte/satin finish paint that offer a lot of protection from the elements and add ease of maintenance These coatings do not offer protection against abrasion and rock chips like a PPF would Others in this thread can probably attest to the visual difference between bare frozen and xpel stealth applied over frozen paint |
10-25-2020, 06:40 PM | #17 |
Rep 4,988
A few folks in F90 forum did it for around $5k in the Midwest recently. I thought about it for my wife's Macan a few years back and was quoted about the same in NJ. Probably similar.
Not that anyone asked, but I would do xpel stealth before frozen paint. Frozen paint is a bit tougher to maintain, and if it does get chipped/damaged, can be expensive to fix, more so than standard paint. With stealth film, you get the frozen look and protection. Of course, you could pay $ for frozen paint AND get xpel stealth, but not sure the point...
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
10-27-2020, 01:50 PM | #18 | |||||
Rep 289
My understanding is that you can do the front facing stuff for around 2k (welcome any corrections here) where the whole car is more like 6K. And unless you are careless about washing, I can't see how PPF over stuff that is not at risk for stone chips etc is really needed. So if you are going for matte look, may be a wash in terms of price between forward facing PPF over Frozen, vs whole car PPF over gloss, but you are PPF'ing stuff that maybe doesn't need to be protected. Quote:
The lower rocker panels are not protected and of course they are pretty dinged up due to road stones getting tossed up by the Michelin Cup 2 and the fact that there is no deflector at the back of the wheel well. But PPF would not really help here unless you had it done every other week IMO. But you can't see them unless you lie on the ground a look up... Having the PPF panels and uncovered Frozen panels right next to each other there is a slight difference with the PPF having more of a satin look, the naked Frozen paint is just ever so slightly less reflective and slightly more aggressive looking, but really, you have to be looking very closely under indirect light to notice the difference, even when looking at an unprotected panel right next to the PPF. I am glad to have the PPF, I can see several stone dings which would have been in the paint if the PPF wasn't there. When it gets too chewed up I will have it re-done, but really it will just be stuff that is damaged, so will be cheaper than the original job by quite a bit. Looking at the PPF you realize why its so expensive, each piece is cut exactly to fit and there are a lot of complex shapes and curves on the F8x front end to be sure. There is even a round piece on the tow hook cover, and little gloss pieces at the bottom of the side view mirror housings where the painted part meets the glossy black plastic bits. |
02-03-2021, 12:51 PM | #19 | |
Rep 197
Drives: 18' C63S, 15' M4
Not sure if I believe it or not, my initial guess is stealth is the same however I may be wrong. What I do know is my friend just took delivery of a frozen grey C63S coupe and when I first saw it I couldn't tell it had stealth on it at all, pretty matte to me. I had to check on the corners eyes wide open where the wrap ends to confirm, otherwise I wouldn't of guessed. Last edited by bmbob; 02-03-2021 at 12:53 PM.. Reason: grammar |
08-10-2021, 01:11 AM | #20 | ||
Go White Sox!
45
Rep 119
08-10-2021, 10:55 PM | #21 |
Rep 630
Drives: 2021 G80 M3
08-11-2021, 08:12 AM | #22 |
Go White Sox!
45
Rep 119
Thanks!
