06-20-2023, 05:24 PM | #67 |
Rep 4,516
What spacers are you running on the rear axle with 10.5” wide et 46mm and 295/30 tyres ?
Current '22 X3M LCI.. |
06-21-2023, 06:59 AM | #68 | ||
Rep 1,334
Oem suspension won't fit on gts knulckles. |
Bee Pee1779.00 |
06-23-2023, 02:23 PM | #69 |
Rep 1,334
gphung193.50 Philly_sweden580.00 |
07-04-2023, 03:19 PM | #71 |
Rep 1,334
07-04-2023, 06:44 PM | #72 | |
Remove Before Flight
6822
Rep 1,611
Specifically-- How do they mount? Do you drill into the bumper? Part numbers? Will they fit a M2C w/ no modification? I've been lacking on the car lately (too much else going on in life), so I'm not "up to speed" on this topic. TIA! R.
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 |
07-05-2023, 05:27 AM | #74 | ||
Rep 1,334
I didn't drill holes in the bumper, I cut the tabs and used zip ties. I had to make a few cuts with a cutter to insert these tabs, nothing more! Quote:
With coilovers you can use 15mm spacer and +-3.0° of negative camber. If u use regulable control arms you can go with less than 3° of negative camber. Yes Last edited by Track/S; 07-05-2023 at 05:38 AM.. |
07-07-2023, 03:06 PM | #75 |
Rep 422
Drives: F87 M2 DCT, F15 X5
Great thread, subscribed.
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Sold in 2023 '12 F30 335i 8AT Sport Line Sold in 2020 '08 E92 335xi 6MT Sold in 2016 '08 E90 335i 6MT - FBO |
07-07-2023, 04:53 PM | #76 |
Rep 1,334
07-07-2023, 09:03 PM | #77 |
3024
Rep 13,763
Man I put mesh grills on my Macan GTS and those guys on that side of the forum would be up in arms saying how much airflow restriction these probably add. What a nutty group.
~loud noises~
Kevin_The_Clean13272.50 D_SheerDrivingPleasure1092.50 |
07-08-2023, 06:12 AM | #78 |
Rep 919
Haha! Nutty is right . On Rennslist there is a discussion about possible engine wear caused by the poor air from the Canadian wild fires. One 992 owner won't start his car and he installed an air filtration system in his garage. A slightly less neurotic Porsche owner wrote that he won't exceed 4,000 rpm unless air quality index is below 125.
07-08-2023, 04:50 PM | #79 | |
3024
Rep 13,763
~loud noises~
07-09-2023, 08:54 AM | #80 | |
Rep 1,334
God level paranoia |
07-25-2023, 04:28 PM | #82 |
Rep 1,334
15
chris7197334.00 to_riffic3023.50 Fabb228.50 gphung193.50 Kevin_The_Clean13272.50 whoop_ass355.00 jason.seki54.00 CoffeeLife397.00 The_Werm212.00 Bee Pee1779.00 Distinct147.00 neonbrown274.50 aatlas192.00 dtmurf481.50 HomoPirate84.00 |
09-08-2023, 07:45 AM | #83 |
The Seeker
13863
Rep 3,323
My god this thread.
Your name should be The Solutionist. |
SYT_Shadow11488.50 |
09-08-2023, 02:14 PM | #86 |
///M Powered for Life
11489
Rep 10,329
I sent mine, he did a great job!
chris7197334.00 ///MPhatic13862.50 |
09-08-2023, 03:41 PM | #87 |
Rep 1,334
09-08-2023, 05:44 PM | #88 |
Rep 4,672
It's great to have someone out there thinking outside the box. Asking things like... Why do we need this, when we can do this?
It's been my belief from the beginning that the 2nh caliper is quite capable. Especially when paired with CCB. Now that it can be paired with a smaller more efficient iron rotor to run 18" wheels is great. Now if only the CCB rotors cost as much as the iron.
