01-24-2023, 04:55 AM | #23 | |
Rep 1,334
8
aatlas192.00 lateapex'er123.00 iam2slow78.50 MooMooM21817.50 mike082802114.00 jason.seki54.00 ///MPhatic13862.50 SilverLakeM3241.00 |
01-24-2023, 08:35 AM | #25 |
Rep 69
nicely done, looking forward to the progression of the build!
Ohlins RT/SPL/Millway
Paragon/Pagid BMC/Active EL/Remus Race BBS e88/513m IG: @aatlas_M2C |
01-24-2023, 08:50 AM | #26 |
Rep 919
01-30-2023, 01:46 PM | #29 | |
Rep 1,334
Finally bought 20mm spacers, I modified them to 17mm, I'm thinking of reducing them to 15mm, this way it would be perfect. Last edited by Track/S; 01-30-2023 at 01:59 PM.. |
01-30-2023, 06:20 PM | #30 | |
Rep 125
How much camber are you running in the front? Where are you located by the way |
02-06-2023, 03:23 PM | #31 |
Rep 1,334
02-12-2023, 12:06 AM | #32 |
Rep 867
Drives: OG M2
Wait so we can fit the 513M in racing wheel spec on OEM 2NH brakes???
02-12-2023, 12:40 PM | #33 |
Rep 1,334
4
02-12-2023, 01:21 PM | #34 |
Rep 867
Drives: OG M2
Broooo that’s crazy - did you trim or change anything in the front besides the dust shield?
02-13-2023, 11:09 AM | #35 |
Rep 125
02-13-2023, 03:20 PM | #37 | ||
Rep 1,334
The pictures above are with 15mm spacers and i can still remove about 5mm. |
iam2slow78.50 SilverLakeM3241.00 |
03-04-2023, 06:48 PM | #40 |
///M Powered for Life
11487
Rep 10,329
OP, did you change your handle/name?
I'm confused about the 513m wheels. If you mill the stock ccb caliper you can get the 18" wheels to clear ccb brakes? I know you did it with 2nh and iron brakes, but those are very similar to ccb |
03-04-2023, 11:35 PM | #41 | |
Rep 1,334
I use ccb discs with 2nh calipers, same as gold of ccb kit. I'm going to do the same on the GTS, these wheels are gorgeous. |
SYT_Shadow11487.00 The_Werm212.00 |
03-05-2023, 02:08 AM | #42 |
Rep 7,298
03-05-2023, 02:28 AM | #43 |
Rep 1,334
03-05-2023, 09:27 AM | #44 | |
11487
Rep 10,329
And you confirm you are using regular 513m wheels? The stock 18" option that was available in the f8x? I would love to run 18" on the ccb calipers and rotors!
ClubsportJunkie311.50 |
