05-28-2020, 09:10 PM | #67 | |
Retired Curmudgeon
2985
Rep 4,047
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
05-29-2020, 05:15 AM | #68 |
Rep 165
Yes I do but it doesn't bug me that much because I feel like it's better than most new cars and the era of truly analog is over. So for me, the M2 is still best in class in that department. It's not as good as like the 991 or anything but it's good.
chris7197334.00 |
05-29-2020, 05:20 AM | #69 | |
Rep 165
05-29-2020, 07:09 AM | #70 | ||
Rep 1,665
I'm happy with the bav sound, huge improvement. I added the door sound deadening around the speakers as well. There is no harshness, clear top end, punchy mids. Very easy to listen over extended periods. The speakers alone reveal how sloppy the stock subs are on the low end so I might do the ghost sub woofers as well. Even with the speakers alone the improvement is massive. Very worthwhile upgrade if you enjoy listening to music. |
05-29-2020, 08:51 AM | #72 | |
Rep 906
2018 had some updates over the 2016-17 model years, particularly the interior and headlights
2009 328i xDrive 6MT (Retired and I miss her)
2015 335i xDrive 6MT (Retired and I dont miss her) 2018 M2 6MT (Never retiring) |
mr.almeida58.50 |
05-29-2020, 12:39 PM | #73 | |
Rep 130
I uninstalled mine when I needed to have the amp replaced, then didn't get around to it, just coded ASD off. I kept thinking how crappy the HK system is. Found some time to install the bypass again and it made a night and day difference. It brings back the mids and I think there is more gain. Now it's an "above" average speaker system, not amazing, but good enough for my semi-hi-fi ears. Before everyone gives me crap for it not making a difference, this is my second time doing it and it's drastically noticeable. Here's my theory. The audio in the M2 is based on analog source. The implementation is something along the lines of a bandpass filter to lower the volume of the music in the "exhaust frequency range" Say 500-4000Hz and mux your exhaust noise. If you code out the ASD, the hardware filter is still there. Unless BMW implemented some expensive DSP processing, that's probably how it's done. |
05-29-2020, 12:55 PM | #74 |
Rep 130
I forgot I bought those door seals, they did make a massive difference.
The M2s N55 is one of the better sounding engines from BMW, definitely better than any s55 and it's one of the best N55 variants ever produced. Buuuut there is still a noticeable torque dip at high rpms. Only way to fix that is a bigger turbo and tunes only make that torque dip more apparent. M2 has the biggest turbo of the N55 variants but it's still not big enough. |
05-30-2020, 01:15 AM | #75 |
Rep 447
For people mentioning the interior noise, it's worth remembering the solid mounted rear subrame certainly will have an effect on NVH versus E90 and earlier gens that had large bushings between the chassis and rear subframe.
2020 M2 CS AW 6-spd
Previous M Cars: M2C, M2, F80 M3, E46 M3, Z3M Coupe, E36 M3...and some other fun rides. |
Tags |
bmw, bmw m2, e90, e90 m3, f87, f87 m2, zcp |
