M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > M4 GTS coded Traction and Steering – what it means to you
      10-01-2020, 08:42 PM   #89
asciimike
Drives: 2017 M2
2017 M2  [0.00]
Originally Posted by BigBig2 View Post
I don't suppose there is a thread on the F087GTS coding? I'm wondering how well would that work since the M2CS Racing has a purely mechanical differential. Also my car is one of the earlier builds 08-2018, I don't know which ISTEP I have but the dealer has been trying to get me in to update the software which I've been reluctant to do since I heard the 2019 build cars are locked out from being tuned.
Which version of ISTEP are people seeing the F87GTS option? Might ask if I can get an ISTEP upgrade to that version if it's worthwhile.
      10-08-2020, 07:03 PM   #90
BigBig2
Drives: 2007 328i
Originally Posted by widetyres View Post
Interesting re the diff - will have to look into that further.
You have the click difference the wrong way round - I did the same at first given that they are sold as rebound adjustment only. However, I spoke with a racer friend who said that they would definitively be doing compression as well. Knowing that I flipped the clicks difference and it was an amazing result.
It might seem weird to think of it that way, but run the fronts 2 clicks softer than the rears and you won't have any understeer at all and can run the suspension a bit softer all around but still have great turn in.
Well worth a go. Hope it works for you.
I'm about to have my car coded to the settings you have up here, and I'm just wondering beforehand if there are any other aspects of the driving dynamics that can be converted to M4 GTS as well such as the ABS braking or DSC OFF modes?
Since I track in DSC OFF mode, will I still be able to experience the benefits you've described or will it only apply to the Euro MDM mode?
Also just curious if you are running staggered or squared wheel fitment and wondering if that would affect the damper settings since I am on a square setup for track.
Thanks again!
      10-10-2020, 02:51 AM   #91
widetyres
279
Drives: M3 E92 DCT, 2012
I'm not aware that you can change those modes - primary adjustments are EPS, DSC and GHAS.
The steering in DSC off mode with GTS coding is fantastic - the best variant of all the codings/modes available. You will like it.
The Euro setting is apparently only related to the tire monitoring system, so you should get all the benefits either way.
I'm running the staggered on my car at the moment. i shouldn't think it would affect the damping that much, but may have a slight impact due to different unsprung weights.
PS: The 2 click differential front to rear is also great on the road, not just for track.
Cheers.
      10-11-2020, 11:56 AM   #92
MikeF87LCI
MikeF87LCI's Avatar
Drives: BMW F87 M2C
Coded F82 GTS mdm, diff and steering on my OG lci today worked fine. Could feel the difference in the steering and the diff.
Unfortunately though after a few miles I got a drivetrain error on the Idrive. This appeared while giving it some, also had loss of power and only gears 2,4&6. It cleared with BimmerCode, so tried again and it reappeared.
Now coded all back to F87 settings
      10-15-2020, 03:07 PM   #93
BigBig2
Drives: 2007 328i
Cheers.
So I got my M2C coded according to this thread except that the guy left out the F82GTS for the DSC and it is still on the default F87CS. Just wondering if that would make a significant difference in the function or performance? From what I can tell the Euro MDM isn't really much different from US MDM as it is still too intrusive on track and I have to use the DSC OFF mode.
GTS steering definitely feels less artificially heavy and more natural, and I can actually use comfort mode for cruising around town now. The more I read up on these hidden modes the more I get confused though. So is DSC OFF it's own mode as well? I have my M Drive settings on MDM, Drivetrain Sport+, Steering Sport, and once I'm on track I hold the DSC button for DSC OFF after. In that case does that mean the DSC OFF reconfigures my M Drive settings to something else?
Since you mentioned the Euro setting is related to the TPMS, I'm just wondering does the TPMS affect any other systems in the car? As 26 PSI is the ideal tire pressure on track, I constantly get the low tire pressure errors on the dash and I can't reset it to be at that pressure cause I guess it is too low from the manufacture specs.
The GTS Differential does seem to be more reactive to throttle inputs and the car corners a little tighter than before. Although mine is a 6MT, even the shifting feels smoother if that makes any sense as I always found there to be some slop in the shifter engagement.
I flipped the 2-click differential like you said and it does work very well. I'm still confused on as to why as I was expecting the car to be oversteery with the rear stiffer, but the car still handles fairly neutral and easy to catch when the rear does step out.
Sorry for all the questions and thanks again for the tips.
      10-16-2020, 02:45 AM   #94
Megator
Megator's Avatar
518
Drives: M2 Competition
ON an OG M2 the modes are intertwined on an M2C they are not.
You can mix and match every steering/throttle/trans/DSC mode. Sometimes you need to deselect things (ie going from the boot up mode efficient engine + sport steering + DSC on to sport plus throttle makes the car want to turn on MDM mode).
DSC off (long press of the DSC off button, DSC off light in dash on not MDM light on) is DSC off. The steering/throtle/trans mode you are in doesn't matter and shouldn't change.
BTW I have my M2 button setup as your describe and I do the same thing of turning DSC off as I leave the pitlane.
I have an EU spec car and don't have the low tire pressure problems lots of ppl on here describe. I do reset the sensors each time it complains though. I think the system is not looking for the vehicle specific pressures but +/- 3 PSI from what you set it at.
      10-19-2020, 02:15 PM   #95
widetyres
279
It won't make a difference to DSC off mode, but would to MDM modes like Sport+.
Best to rely on the feedback of the M2C owners, as above - I have an OG.
It's about weight transfer - with the fronts stiffer than the rears, what was happening was that the front shocks were pushing off weight faster than the rears, which unloads the front and means there isn't enough weight over the front tyres to to get good grip/turn in. It's obviously a balancing act - too much weight transfer to the front would also cause understeer, but 2 clicks difference seems to be the sweet spot.
      11-19-2020, 09:56 AM   #96
bngcruiser
bngcruiser's Avatar
Drives: '89 Land Cruiser, '18 M2
2018 BMW M2  [0.00]
New to this ... have used bimmercode and bimmerlink but ESYS is new to me.
So we download the software, buy the correct connection hardware, find someone to do the coding, link to them over the internet with my windows computer with ESYS and voila?
      11-20-2020, 11:32 AM   #97
m3username
Drives: '17 F87 M2
If you're going to get someone over the internet to do it they'll likely give you the software so you only need a working ENET cable, a windows laptop, and an internet connection (presuming your firmware is recent enough).
(Note: Kubax86 on this forum does this type of work for a lot of us and comes recommended)
      03-04-2023, 05:57 PM   #98
peyotepaul
Drives: BMW 328xi, SL55, 2018 M2
This was very concise and helpful guide to coding GTS Steering & MDM.
First, I updated the DSC, EPS, and GHAS ECUs to the latest via PSDz v4.40.11. No issues with DSC and EPS. GHAS gave me a timeout error for certain modules but still seemed to flash correctly.
I was able to FDL code DSC and EPS to the GTS settings but I am not able to code GHAS for some reason. I believe I may have flashed too new of an ECU.
This is the error message I'm getting:
[] SVK-Ist does not match expected SGBMIDs for ecu ECUId:GHAS_0x0F. Excpected (relevant process classes only): [hwel_000007c1-003_001_001, btld_00001056-012_001_000, swfl_00001062-017_000_000, swfl_00001063-017_000_000], Actual (relevant process classes only): [hwel_000007c1-003_001_001, btld_00001056-012_001_000, swfl_00001062-019_000_000, swfl_00001063-019_000_000], Missing SGBMID(s): [swfl_00001062-017_000_000, swfl_00001063-017_000_000], Surplus SGBMID(s): [swfl_00001062-019_000_000, swfl_00001063-019_000_000] [THROWABLE]
[GHAS - F] There was an error during TAL execution, please check the log files. [WARN]
[GHAS - F] - [Exception - GHAS - f] SVK-Ist does not match expected SGBMIDs for ecu ECUId:GHAS_0x0F. Excpected (relevant process classes only): [hwel_000007c1-003_001_001, btld_00001056-012_001_000, swfl_00001062-017_000_000, swfl_00001063-017_000_000], Actual (relevant process classes only): [hwel_000007c1-003_001_001, btld_00001056-012_001_000, swfl_00001062-019_000_000, swfl_00001063-019_000_000], Missing SGBMID(s): [swfl_00001062-017_000_000, swfl_00001063-017_000_000], Surplus SGBMID(s): [swfl_00001062-019_000_000, swfl_00001063-019_000_000]
Is there any way for me to revert GHAS back to an older iStep? If i just changed Target to an older verison?
      03-05-2023, 01:41 AM   #99
widetyres
279
[GHAS - F] - [Exception - GHAS - f] SVK-Ist does not match expected SGBMIDs for ecu ECUId:GHAS_0x0F. Excpected (relevant process classes only): [hwel_000007c1-003_001_001, btld_00001056-012_001_000, swfl_00001062-017_000_000, swfl_00001063-017_000_000], Actual (relevant process classes only): [hwel_000007c1-003_001_001, btld_00001056-012_001_000, swfl_00001062-019_000_000, swfl_00001063-019_000_000], Missing SGBMID(s): [swfl_00001062-017_000_000, swfl_00001063-017_000_000], Surplus SGBMID(s): [...]
I would be careful re dependencies between the modules and their versions. Looks like you might have updated ghas beyond what another module is expecting.
To get around this, you either need to do a full update (to all modules), or check the dependencies table and make sure the versions you are sending to the modules are compatible.
WT
      03-05-2023, 10:50 AM   #100
TheNine90
578
Drives: bmw
If the SVT ist and soll have blue and red HWEL then it will bring this error. Make sure the HWEL is black. After calculating svt soll press HWID from SVT actual the the HWEL will be black. The calculate svt tal.
      03-05-2023, 05:36 PM   #101
peyotepaul
Thank you both for the help and suggestions!
widetyres
I'm not seeing any dependencies in TAL-editor. GHAS isn't even listed in there.
TheNine90
I have no red or blue within the GHAS module. Everything is black. I don't believe I pressed HWID from SVT actual when I did the initial VO coding. I'm also not seeing an option to reflash GHAS within VCM. I haven't had any codes pop up. Should I be able to see the module?
Thanks!
      03-05-2023, 07:09 PM   #102
peyotepaul
minor update: I was able to re-flash GHAS by using a previous day's TAL file. This time it finished with no errors. However, after I coded F87GTS I got a "Rear Axle Differential Lock" error on iDrive when i started the car. I cleared the code but it keeps coming back as soon as i start the car.
I changed the coding back to F87 but the error persists. I'll take it for a longer drive and see if it clears on it's own.
EDIT: Solved! let the car sit for a while and took it on a short drive. Re-coded GHAS to GTS spec. No errors and no codes.
      03-06-2023, 01:24 AM   #103
widetyres
279
Great that it is OK now - did you run the diff initialization sequence in ISTA? You won't need to now if you didn't (as it has sorted itself out), but it might have accelerated the clearing of the error.
      03-06-2023, 07:26 PM   #104
peyotepaul
I did not. That was going to be my next step if it didn't get sorted
      03-24-2023, 08:33 PM   #105
F87source
F87source's Avatar
Drives: Bmw M2
Hey guys, if anyone needs a tool to code f87cs parameters (which will not be doable with the old esys launcher pro 2.8.1 which you can find on the forums) then you can use the protool app to do it. This app can code anything esys can, so it's literally a mobile esys.
Here's my review on the app and my guides on how to code the eps, ghas, and dsc:
Main review: https://f87.bimmerpost.com/forums/sh...php?p=29968185
Guide on how to use Protool to Code:
EPS module: https://f87.bimmerpost.com/forums/sh...4#post29968214
DSC module: https://f87.bimmerpost.com/forums/sh...8#post29968208
GHAS module: https://f87.bimmerpost.com/forums/sh...7#post29968227
      04-13-2023, 05:03 PM   #106
BadgerDog
BadgerDog's Avatar
178
Drives: 2017 BMW M2
2017 BMW M2  [9.50]
This has been shown to be false in other threads. There are 5 modes:
Comfort
Sport
Sport+
MDM (short press of traction control button)
DTC off (long press of traction control button).
Which mode you are in when you press the dtc button doesn't matter. The two modes that button enables are fully featured modes of their own with associated settings. There's a big chart floating around that is straight out of a tech publication from BMW.
Appologies if I got any acronyms wrong, I'm doing this from memory.
      03-28-2024, 01:56 AM   #107
alexdaoe
Drives: Bmw M4 LCI '18
Hello, I have a 2017 LCI M4 and I just did the GTS coding by changing C_Variante_Fahrzeug_e (on DSC ECU), DSS IPM & TASC (on GHAS ECU) and variantencodierung normal (on EPS ECU) to F082GTS with E-sys.
It all went great and now I have GTS coding for LSD, Steering and MDM. Now I want to try this coding on an early F80 M3 2014 (before the GTS was launched) and I'm wondering if this will be possible to do like on mine without fully updating/flashing the ECUS to the latest version (on mine I just had to change the values above mentioned from f082 to f082GTS).
Thanks!
      04-02-2024, 09:33 AM   #108
Inviam
Drives: 2016 M2
Have these been moved to sonwhere else?
      04-02-2024, 10:16 AM   #109
jefe2000
jefe2000's Avatar
Drives: 2018 M2 6MT
2018 BMW M2  [10.00]
No, somehow the links in the embedded comment above are broken. The links in the original post are still functional and good. See this (the links are at the bottom of the first post in the thread):
https://www.bimmerpost.com/forums/sh...php?p=29968167
F87source7253.50
      04-02-2024, 11:43 AM   #110
Inviam
Drives: 2016 M2
Thank you very much
