M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Wireless Charging - Max Phone Size?
      08-19-2019, 05:40 PM   #89
SteveC90
2018 BMW m2  [0.00]
Originally Posted by Protatomonster View Post
Think this will fit the note 10?
I am able to fit my note 9 with a case. Should fit the Note 10 no problem, but not sure about the 10+.
      08-19-2019, 08:19 PM   #90
Protatomonster
Drives: Kia Stinger 2018
This is an S8+ in the note 10 case for size comparison hopefully it will fit how was install?
      08-19-2019, 08:23 PM   #91
Protatomonster
Note 10 Plus is 6.39 x 3.04 x 0.31 in - Note 9 is 6.37 x 3.01 x 0.35 in
The being said it's such a small amount, I think without a case I'll be fine, might put a small case on and hope for the best. Can always take off when i charge.
      08-19-2019, 09:12 PM   #92
MystroX5
MystroX5's Avatar
6290
Drives: 2020 X7 M50i/ 911
How does the Note 9 fit? No one else does. What am I missing?
      08-19-2019, 09:38 PM   #93
Protatomonster
Is it easy to revert back to stock if my phone doesn't fit?
      08-20-2019, 08:19 AM   #94
FreeDarko
Drives: F80
I assumed the wireless charging was in the front console near the cupholders like in the newer BMW.
I was watching the MotoManTV review of the M2c and I see now why he was struggling to get the wireless charging to work.
Anyway, is it easy to remove the wireless part from inside the armrest? I rather use the space for other stuff.
      08-20-2019, 01:33 PM   #95
rocketman99
Lurker
Drives: '19 M2C, '24 X1 M35
We're talking phones fitting after installing the new slide piece, not using the stock slider.
      10-20-2019, 11:01 AM   #96
rak299
Drives: 2021 M3 6MT
I was able to break the cradle during installation. The cables were tight inside the cradle and I broke off one of the leads for the coax. I can solder it back, but I don't want to do that in the car. I have seen plenty of pictures of the cradle and cables so I can see that the sockets aren't far away, but I have seen conflicting posts and cannot tell if the sockets are in front of the shifter or behind the console, by the rear heat vent, I assumed they were in the front of the car (based on the way the cable comes out of the cradle, so I removed the cover and idrive controller (right of the shifter. I loosened the shifting boot (6MT) and removed the button panel to the left of the shifter. I found 2 Torx screws, which I removed, but I cannot get anything to budge. (Many years ago, I learned that if you f**k something up, it is best not to make it worse trying to fix your mistake. Can anyone provide any guidance before I am forced to throw myself on the mercy of the dealer and listen to the lecture on the dangers of weekend mechanics
      10-26-2019, 12:10 PM   #97
ASAP
ASAP's Avatar
10163
Drives: '23 X3 M40i
the wireless charger is a total POS... it overheats the phone while charging at a dead slow speed... this results in extremely slow and unresponsive performance
      12-11-2019, 08:54 AM   #98
Jho1692
Drives: X2
Originally Posted by CanonEOS View Post
1. Using a plastic trim tool, wedge it at the front of the wireless charger assembly and it will pop open, may need to add a little force.
2. Pull up and remove carefully and you'll see screws holding the slider in place, remove screws and remove slider.
3. You can honestly pop it back in place and it will hold a larger phone just fine, or install the 3D printed piece and put together
This took me about 5 min
Hi, how were you able to pop the wireless charger out in your X2 from the front? Tried doing so, but seems like there's a clip keeping it from popping out from the front. Thanks!
FreeDarko217.00
      01-01-2020, 08:33 PM   #99
flybigjet
Remove Before Flight
flybigjet's Avatar
Drives: M2C & Boeing's light twin
Tried my iPhone Xr in a slim case in a M2C at the dealer yesterday.
Fit great, blue light came on.
R.
      03-10-2020, 06:19 AM   #100
Tricki
Tricki's Avatar
215
Drives: BMW M2 Comp
Originally Posted by cptobvious View Post
Thank you!
https://f87.bimmerpost.com/forums/sh....php?t=1523034
Now... how does one go about removing the armrest thing-a-ma-jig to then take out bottom bracket and replace with 3D printed one?
hi cptobvious. I got your message and am happy to share how I removed the charger cradle and disassembled it to remove the bottom bracket. All you really need is a pry tool and a T6 screwdriver.
1) Use the pry tool to lift the charging cradle from the front. Once the front is lifted, you can simple lift the entire cradle out of the armrest.
2) There are four clips (2 on each side) holding the bottom to the charger. I just used a flat head screwdriver to pop them out and then remove the charger.
3) Now the trickiest part, disassembling the charger. For this, I stuck a blade (pry tool was a bit thick) in the open space where the bracket moves and pushed down to separate the top and bottom halves.
4) Now you have access to the two t6 screws that hold the bottom bracket in place.
Below are pictures I just took of the step by step process. Let me know if I can be of more help.
BTW, with this mod i can fit my massive Note 9 on here.
Ur a legend Thx...... ordered this from ur links although no hole underneath...
I assume it just screws into the plastic?
      05-01-2020, 07:34 AM   #101
MMMBRAP
Drives: A Car
Wireless Charger Mods?
Prior to getting the M2C, I was actually pretty happy about it having the Wireless Charger in it, as part of the Exec Pack.
Except it's utterly useless, (can't fit phones that aren't from 2009, and based on what I've read about it, it's great as a phone warmer) and doesn't actually do any sort of decent charging.
Has anyone done any mods to the armrest console, either by taking the wireless charging unit out entirely to just use the console for putting stuff in or is there a mod that can somehow actually make the wireless charger useful?
ASAP10162.50
      05-01-2020, 08:28 AM   #102
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2017 Audi Q7 3.0  [0.00]
2020 M2C  [0.00]
What issues are you having, and what phone do you have? I hardly use mine because its in the center console, and I have to remove my case which also houses my ID and credit cards, but the few times I've used it, it has been ok. Isn't the fastest charger, but it does the job and my phone isn't too hot.
I suppose if you have those "Max" versions, they dont fit?
      05-01-2020, 08:31 AM   #103
pizza240
pizza240's Avatar
801
Drives: 2023 M3 Competition xDrive
I've been using it to thaw frozen meat. Gets nice and hot especially using Waze.
It fits the standard phone sizes, but not the "max" type of models, so it takes longer for cuts like an 18oz bone-in ribeye, but it's decent on a 12oz.
Appreciate 6
BigKutta3906.50
cptobvious2531.50
Kankles1484.50
KevinM2935.50
      05-01-2020, 08:36 AM   #104
MMMBRAP
Drives: A Car
I have a Samsung Note 10+. It's a gigantic phone, yes, but imo a pretty "standard" sized phone for 2020.
I've seen that thread where you can modify the "spring bar" part but the whole process just looks overcomplicated tbh. Hell, I wonder if I can just remove that spring bar so I can just sit my phone in it and it still charge, but I'm going to assume that part is essential for the system to activate the charging process.
Right now I'm putting my phone in the area by the cup holders, but it tends to move around a lot while I drive. Thinking I'll just get a vent phone mount for now, which I honestly don't really prefer.
LMAO!
      05-01-2020, 10:37 AM   #105
JCZ5
JCZ5's Avatar
1483
Drives: BMW X5 (G05)
Yeah, this was an issue when I first realized the size. It does not fit my max iPhone. Surprised there has not been a BMW upgrade to this piece as I'm sure it can be easily disassembled.
I'm so use to have an in-car wireless charger on the new X5
IG: @rise_n_drive
      05-01-2020, 10:48 AM   #106
TrentMeister
TrentMeister's Avatar
2860
Drives: g82 comp
I could go for removing the whole thing
jkoral1024.50
      05-01-2020, 10:49 AM   #107
SilverScotty
SilverScotty's Avatar
320
Drives: 2020 M2C HS 6MT
There was a thread about a year ago where someone posted a model that you could 3-D print to extend it for new(er) phones. Some disassembly is required inside the armrest console but it looked to be a good fix. I think this is it:
https://f87.bimmerpost.com/forums/sh....php?t=1534787
      05-01-2020, 11:00 AM   #108
xxyion
xxyion's Avatar
761
Drives: 2024 M4 Competition xDrive
I was in the exact same position. I use my smaller iphone(work phone) for my carplay, and my bigger Android is my personal phone. I imagined it would be great to jump in the car, put my iphone in the charging port and be done with it.
But as many have said, it overheats the phone, to the point where i dont feel its safe. And it doesnt charge as fast as me just plugging it in. At this point i dont use it at all which is a bit of a disappointment.
      05-01-2020, 12:52 PM   #109
MrOhnoez
Drives: '21 GLI, '79 beetle, '99 M3
I had the 3D printed bracket to allow it to fit my phone.
It kept getting snagged as I tried to retract it back.
Finally broke.
Put back the stock one, never really used it anyways.
      05-01-2020, 01:42 PM   #110
ASAP
ASAP's Avatar
10163
Drives: '23 X3 M40i
You can modify the charger to your heart's content but the charger is still a pile of steamy crap...
It will overheat just about any phone (especially if you are actively using it for carplay or streaming music) and will charge your phone in close to 10 hours.
BMW should have never allowed this junk into the car... it clearly went thru no QC... if someone has advice on how to remove it to make more glovebox room; i am all ears.
