M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Radar mount
      04-28-2016, 09:59 AM   #1
Em-too
Em-too's Avatar
Drives: 2016 M2
Radar mount
Found a DIY on 2addicts http://www.2addicts.com/forums/showthread.php?t=998321
Turned out nice on my M2
      04-28-2016, 08:01 PM   #2
Prodigy.
Prodigy.'s Avatar
698
Drives: ///M2
I've purchased the mirrortap as in the DIY but not the mount. Did you also use a mirrortap? If so were the wires he tapped into the same on the M2.
      04-28-2016, 08:06 PM   #3
Em-too
Em-too's Avatar
Drives: 2016 M2
Yep, I used the Mirrortap and it's wired just the same as in the DIY, no issues.
      04-28-2016, 10:38 PM   #4
miiipilot
miiipilot's Avatar
Drives: 2024 M2 Brooklyn Grey 6mt
It seems like that sits very low in your field of vision No?
I just picked up my car today and noticed how little space b/w the bottom of the mirror and the top of the Nav screen.
I wanted to get the blend mount, but it seems like it would obstruct the field of vision.
miiipilot
'24 M2 Brooklyn Grey, 6mt, Bi-Color, Black M-Color seats,
'16 MG M2, DCT, Exec. Took Delivery 4/30/16 (Sold)
D CHOI581.00
ried791.50
      04-29-2016, 09:03 AM   #5
Em-too
Em-too's Avatar
Drives: 2016 M2
I had it mounted the same way in my previous car (350Z) and it works for me. Never had an issue but then again that car was all about obstruction in view
Honestly though I don't find it much of an obstruction but I did have the same concern as you. I'll take another photo later from the drivers vantage point and post it.
      04-29-2016, 09:43 AM   #6
miiipilot
miiipilot's Avatar
Thank you.
miiipilot
      04-29-2016, 12:22 PM   #7
Em-too
Em-too's Avatar
Drives: 2016 M2
@miiipilot here you go. Not sure if these will help.
D CHOI581.00
      04-30-2016, 11:02 AM   #8
miiipilot
miiipilot's Avatar
thank you
miiipilot
      08-26-2016, 05:10 PM   #9
CAVU
CAVU's Avatar
Drives: '16 F87 M2
Great information for us M2 owners ... thanks for posting.
Quick question, I just ordered the MTX-1015 mirror tap power cord, and it comes with 4 different sets of tap sizes (.040", .045", .060", or .075"). Do you know which size you used?
F87 '16 M2 ... Mineral Grey, 6MT, Exec, MPE
Gone: E82 '13 135is 475/586 ... Mineral Grey / Oyster, DCT, Premium, Tech, HK, Michelin PSS, BMW Performance Suspension
      08-26-2016, 10:11 PM   #10
Em-too
Em-too's Avatar
Drives: 2016 M2
Glad it was useful. Mine was .080, same as used in the 2addicts DIY
      08-26-2016, 10:14 PM   #11
Prodigy.
Prodigy.'s Avatar
698
Drives: ///M2
I don't think it's any of those, i ordered the MT- 4015 for mine with the .080" tap.
Edit: just saw em-too posted the same.
      09-01-2016, 12:07 AM   #12
ric124
ric124's Avatar
Jamaica
452
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
Where did you get the blend mount and which one is the correct one for the M2?
I might not do the mirror tap but instead run the wire from the fuse box using a fuse jumper. Only issue is mirror tap seems so much easier
      09-01-2016, 11:13 AM   #13
Em-too
Em-too's Avatar
Drives: 2016 M2
It depends on which radar you are mounting. I had an Escort 9500 so this is the correct one for that application.
The wiretap is so easy and clean. I'd recommend it vs any other option.
      09-10-2016, 12:03 PM   #14
CAVU
CAVU's Avatar
Drives: '16 F87 M2
Thanks guys! I installed the MirrorTap and BlendMount today and am happy with the results.
I think the MTX-1015 superseded the MT-4015, and is now what MirrorTap is selling on their website for all BMWs. The 0.075" leads ended up being too short, so I used longer 0.060" leads and everything works great!
Em-too279.50
      10-01-2016, 04:21 PM   #15
nopslide
I think you have those measurements backwards but yea I ordered same PN MTX-1015. Its definitely the longest leads that you use on the black connector. Just did it today.
      10-01-2016, 10:10 PM   #16
CAVU
CAVU's Avatar
Drives: '16 F87 M2
I'm glad it worked out for you!
No, those are the measurements. On my package of 4 sets of leads, each set was a different thickness. I started with the thickest leads (0.075" according to the package), but they weren't long enough to make a good connection. The next smaller thickness (0.060" thick) were longer than the 0.075" set, and that did the trick.
      10-02-2016, 12:11 AM   #17
nopslide
Oh I see. I didn't really check the diameter of the pins was just looking at the length.
      11-01-2016, 10:12 PM   #18
toastie
toastie's Avatar
Drives: e39 M5
After you installed the mirrortap, the radar detector turns off with the car right? Coming from a VW, if the mirrortap was tapped wrong, it will stay on and drain the battery.
Also, did it show any signs of dimming or faintness when you put the car in reverse?
      11-02-2016, 12:29 AM   #19
Prodigy.
Prodigy.'s Avatar
698
Drives: ///M2
Yes, RD turns off when the ignition is switched off and no i can't say i've noticed any signs of dimming at all.
      11-02-2016, 09:40 AM   #20
toastie
toastie's Avatar
Drives: e39 M5
Glad I can transfer over my mirrortap from my Golf
      11-10-2016, 05:55 PM   #21
nszzya
Drive Different
nszzya's Avatar
Drives: '16 F15 '17 F87
Does the MirrorTap splice into the wire (i.e. cut through the insulation to make a connection)?
'17 F87 M2 DCT / '16 F15 X5 X35i / '09 E82 135i 6MT*
'10 E70 X5 35d* / '05 E60 M5 SMG* / '01 E53 X5 4.4i* / '76 2002* | '70 2002*
*Gone
      11-11-2016, 12:03 PM   #22
Em-too
Em-too's Avatar
Drives: 2016 M2
No, it just slides into the existing wire harness
