M2 Technical Topics > Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) > cleaning bugs off radiator and oil cooler
      07-02-2019, 08:28 PM   #1
andrettifan
Drives: 2020 M2C; 2017 330i wagon
Just took my car on its first road trip (Watkins Glen - IMSA event - Turner M6 looked solid but Rahal M8s weren't really competitive). Anyway, after 600 miles on the highway, with all the front rad / cooler exposure the M2C has, there are a lot of bugs buried in. Obviously I've tried spraying with soap and water but the hose just buries them deeper. Most wash off, but too many left for my standard of clean.
Any suggestions how to clean out the bugs?
      07-02-2019, 08:52 PM   #2
waldrops
waldrops's Avatar
171
Drives: BMW M2 Competition
https://www.ammonyc.com/shop/big-wheel-brush/
Very expensive option, but you can find cheaper versions on amazon. Also very helpful for cleaning wheels/trim
      07-02-2019, 09:05 PM   #3
Tag
this is the way
Tag's Avatar
18152
Drives: N-1 starfighter
You can try spraying it down with some goo gone, let it sit for a bit to loosen up and then do a low pressure rinse.
NEfan5082658.50
      07-02-2019, 09:17 PM   #4
ONLYA6
Drives: '20 X3M '19 M2C
I soak with Poorboys Bug Squash then hose. Repeat over and over until they get softened up enough to flush away.
2020 X3MC, 2019 M2C
'14 F-150 Tremor, '99 Mustang Turbo
      07-03-2019, 11:04 AM   #5
NEfan508
NEfan508's Avatar
Drives: 2019 M2C
***Be careful if your using a power washer***
Im busy with work and family so she sits mostly, the few days I get free we go on 200+ mile day trips (Maine coast then back) bugs and gunk with red, yellow and green blood everywhere?!?! that's gotta be great for the paint lol
so I power washed it, but I'm a dumbass when it comes to powerwashing, I broke my headlight (water damage inside) $2650 bill from the dealer
Headlights have small vent(s) so some moisture CAN come in & out but power washing could be an issue
I played dumb, took it in, they investigated found no damage but water inside? They replaced it no charge because it was so new
Just don't point the gun directly in front of the front end to clean off bugs, lots of sensitive parts (be careful)
      07-03-2019, 11:08 AM   #6
NEfan508
NEfan508's Avatar
Drives: 2019 M2C
#lowpressure
      07-03-2019, 11:32 AM   #7
MystroX5
MystroX5's Avatar
6290
Drives: 2020 X7 M50i/ 911
Use a foam gun to soften them up. It worked with the similar 911 Turbo front intakes.
I use this one:
https://www.autogeek.net/dp-quart-foam-gun.html
I won’t use a power washer on my Power Wagon. Too much risk.
      07-03-2019, 11:50 AM   #8
AlpsRider
AlpsRider's Avatar
2865
I just wait until they are dry and crispy then I use the jet spray. If you get too close with the jet it will bend the small flanges though.
      07-03-2019, 12:03 PM   #9
msdss
msdss's Avatar
Drives: Alpine White 2020 BMW M2C
Use a foam gun, then a dedicated detailers brush. I bought a 5 pieces brush kit off of amazon for 12 dollars. Works amazingly well for unpainted surfaces like behind the grills, wheel wells, and lug nuts.
https://www.amazon.com/Master-Detail...gateway&sr=8-3
Avoid pressure washing any car at high psi. Use a wide nozzle, and a good amount of distance. Do test blasts on the cement, or some other safe area. If it cleans the cement, then it's way too fucking powerful for your car. lol
NEfan5082658.50
      07-03-2019, 02:55 PM   #10
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
Snow foam to soften up, then pressure wash through grills, but 100psI max with 40deg nozzle no closer then 12" minimum is safe for rads etc, more of a high flow flush then jet blast..
Problem with rads is access due to the grills.
      07-03-2019, 03:05 PM   #11
doughboy
doughboy's Avatar
1545
These cars have to be fine to be driven in heavy pouring rain at 140+mph, that is one hell of a water blast.
A long as you don't spray in odd directions I find it hard to believe headlights get water in them when sprayed from the front.
      07-03-2019, 05:23 PM   #12
NEfan508
NEfan508's Avatar
Drives: 2019 M2C
When your an idiot (me) with a new pressure washer you can damage a headlight
I agree, I've used the carwash bays on my truck for years (stronger) never had an issue but my cream puff m2 I F'ed it up
has small vents, pressure washer could and did in my case screw it up (see pics above early post) just writing as a warning be more gentle with a spray gun
      07-03-2019, 05:28 PM   #13
infinitekidM2C
infinitekidM2C's Avatar
Drives: 2019 M2 Competition
I pulled out a sizeable butterfly much to my daughter's dismay and a cigarette butt. Had to use some wire to get it out
      07-03-2019, 05:51 PM   #14
AZ-Wildcat
AZ-Wildcat's Avatar
620
Drives: BMW HS M2C DCT
Great topic! Just landed in Laguna Beach from San Jose. SO MANY BUGS.
And oh man do I miss cruisin PCH. The roads in NorCal are atrocious
      07-04-2019, 07:34 AM   #15
andrettifan
Thanks guys. There are some good suggestions above and I've already ordered some bug cleaning spray and will try that with a low pressure water spray. Brushes (and wire - yikes!) aren't an option here (rad and oil coolers are well back from the plastic grills) unless I remove the plastic grills and I'm not going to try that. Even with the plastic grills removed, I'd be worried about bending the flanges / fins using a brush.
One of the issues with spraying water at the bugs (I'm using a garden hose, so not high pressure) is that the spray just drives the bugs deeper into the flanges / fins of the rads. It washes out some of them, but not all and not the big ones. I know this might seem a little obsessive, but there is so much exposed rad / cooler area and the black grills have large openings so the bugs really show.
      07-04-2019, 07:57 AM   #16
doughboy
doughboy's Avatar
1545
The bugs will dry up and disintegrate and just blow away in time, if every bug you ever hit stayed wedged in the rads for ever the car would overheat!
natmad667.00
      07-04-2019, 08:09 AM   #17
andrettifan
Yes, but I don't want to wait until they dry up and disintegrate. The front of the car looks ... disgusting!
      07-04-2019, 11:04 AM   #18
doughboy
doughboy's Avatar
1545
OK, yes, but you can't even see the rads unless you bend down infront of the car, no one else will notice..
