04-04-2017, 06:55 PM | #1 |
Rep 292
Rear quarter panel plastic film – tell me why I shouldn’t remove it
I’m so fed up with that plastic film on the rear quarter panel that I’m ready to remove it. My M2 is white and I’ve had it for six months. The plastic film is beginning to yellow (just a little, but it is definitely not clear) and no matter what I try (simple washing, polish / wax) I cannot get the leading edge clean. It always looks black, not dramatically so, but there it is… a thin line of black along the leading edge of the film. Paint breathes, but it can’t underneath that damn plastic. That can’t be good for the paint long term?
I never drive on gravel roads. I do drive the car in winter. Will I really end up with stone chips if I remove it? Can anyone convince me that it should stay on the car? What are the pros and cons? Has anyone removed it and can report how much damage results?
04-04-2017, 07:03 PM | #2 |
Rep 340
I removed them and then my car exploded the next day on my way to work.
18
SoCalRob281.00 luvmybmmr305.00 Tumbleweeds78125.50 1M Tex240.00 Tag18155.00 arquitecto535.50 emargul204.50 Aust350z243.00 slashrawr94.50 AlexCirci496.50 F87LUV3689.00 Stu Pedasho196.00 M3 Adjuster7905.50 thevanillagorilla11.50 zFrostyy83.00 mikeokimster204.50 Makman230.50 BAN_M2C4185.00 |
04-04-2017, 08:18 PM | #6 | |
Rep 2,200
04-04-2017, 08:22 PM | #7 |
Rep 430
I'm guessing BMW, possibly in wind tunnel testing, realized the wide flared rear panels were being sand blasted over time, hence the protective film. I doubt the film quality is as high as XPEL type commercial products. I don't see any reason you couldn't replace it with one of these films. I'll have to see over time how my CQuartz Finest http://www.cqfinest.com/ paint treatment protects the rear film.
04-04-2017, 08:35 PM | #9 |
Rep 51
the yellowish is due to the glue of the film used.it is not the film that turns yellow.
if you look at most of the porsches, they have the film as well. I would suggest peel it off. not sure if autozkin is available in your country. this definitely works better than xpel. I've used xpel for 2 of my previous ride and let me tell you autozkin definitely beats xpel. http://www.autozkin.com/about-us/ do check out the videos in youtube. |
04-04-2017, 09:14 PM | #10 |
Rep 430
The more film and paint treatment referrals the better. But in the end, it may come down to making a choice from recommended merchants in your locale.
04-04-2017, 09:25 PM | #11 |
Rep 133
Here ya go. Looks like it's possible to remove without doing any damage. In this case it was removed and replaced with Xpel.
http://www.hughsdetailing.com/blog/2...-xpel-ultimate |
04-04-2017, 09:35 PM | #12 |
Rep 1,298
I removed it a week after owning the car (picked it up last June) and so far i only have 2 super small rock chips, basically the size of the end of a needle. Also removed it without any paint damage, just pulled it right off.
So my vote is to remove it, especially since you have AW |
bartginger421.00 M3 Adjuster7905.50 |
04-05-2017, 09:59 AM | #13 |
Rep 93
Don't feel stupid...he's an asshole
04-05-2017, 11:40 AM | #15 | |
Rep 292
Did you have to use any heat to remove it? Blow dryer? Any advice? Can you tell I'm nervous about doing this? XPEL advocates - in case I regret this after removing the factory material, can an XPEL shop apply their product without a template made from the factory application? In other words, can they apply XPEL to the rear quarter panel exactly matching the factory shape and size? I have no experience whatsoever with that stuff. Will it yellow like the factory material did (in only six months!)??
Last edited by andrettifan; 04-05-2017 at 11:42 AM.. Reason: spelling - hate it when I do that |
04-05-2017, 02:21 PM | #16 | ||
Rep 324
04-05-2017, 02:38 PM | #17 |
Rep 3,402
Even without driving on gravel roads you will experience chips in that area beyond the factory plastic. I have seen it on all of the press cars I have seen and all of the M2's at the BMW performance center. I had it removed and my Xpel guy put an expanded piece on that area which is far more protective and far less visible than the factory crap. The shape of the rockers makes them very vulnerable to chips right before the rear tires also. I am an Xpel fan but then again Arizona is not kind to paint so its essential here if you want a nice car.
04-05-2017, 03:01 PM | #18 | |
Space Force - 4 Star General
11463
Rep 3,264
My last car had even bigger rear flares but I never had a problem with chips on that leading edge. This is just a theory and I have no proof to back it up, but my guess is that it has to do with the way in which the trailing edge of the front fender cuts in dramatically where it meets the rocker panel. It's leaves the rear fender in the "line of fire" from the front tires. My Z had little plastic bits that flared the rocker panel out and blocked any debris that might fling off the front tire. The M2 is lacking this and I suspect it might be why it chews up that fender so readily. |
04-05-2017, 04:03 PM | #19 | ||
Rep 324
04-05-2017, 04:57 PM | #20 |
Rep 292
All of you above, thanks so much for the advice. I was convinced I should remove the factory film - but that was only half the answer. I'm now convinced that I should (and will) remove it, but replace it with XPEL (there is a reputable installer near me in CT). If I'm still unhappy with that, I can always remove it later. In the meantime, while I'm not obsessive about avoiding every possible mark on the paint, this does seem like a reasonable thing to do given the design of that rear quarter panel.
This is what I love about this forum... folks are generous with their time and care about helping others solve problems.
bartginger421.00 luvmybmmr305.00 |
04-05-2017, 05:29 PM | #21 | ||||
Rep 13,107
Jan 12, 2016: Quote:
///M is art ↔ Artemis
04-05-2017, 06:10 PM | #22 | |
Rep 3,299
But if you want to have the protection that they are trying for in that area I agree with replacing it with a full coverage piece from the front of the fender to beyond the original area of coverage, that makes much more sense than the little patch. Mine is yellowing also by the way. Mike
