05-01-2024, 12:15 PM | #52 |
3881
Rep 54,449
Drives: F80 M3
The Öhlins TTX-Pro range of suspension systems have been developed for discerning club-level racers and track day aficionados looking to utilize identical technology as the pros use to maximize performance. The dampers are carefully chosen for each application from Öhlins professional TTX motorsport range and adapted to suit road-going cars where the focus is on track use. Öhlins TTX dampers are pressure balanced at every clicker setting without the need of excessive nitrogen pressure, resulting in a broad range of adjustability without cavitation. The vehicle-specific suspension settings have been rigorously tested to ensure they deliver on track, while being compliant for the journey back home. All dampers are truly independent in compression and rebound adjustability, providing owners the possibility to fine-tune their set-up according to the conditions of the track.
The benefits are immediately apparent: reduced weight and an improved grip and feel in the car like never before. As expected from Öhlins, only the highest quality materials are used. Each system is dyno matched to ensure consistent handling. If you’re looking to lap quicker through improved confidence in your car’s suspension, then look no further than Öhlins TTX-Pro range of suspension systems. HIGHLIGHTED FEATURES TTX Technology Developed for Track-Focused Cars Independent Damping Adjustment Pressure Balanced Dyno Matched Popular Applications Rebuildable *System includes spherical upper mounts. *Cancellation kit available for vehicles with OE active dampers. Active damper functionality is lost. *System offers independent rebound and compression adjustment via separate compression and rebound knobs. *System includes adjustable front stablizer bar links. Landing in the US in late Summer More info to come later |
