10-13-2017, 04:13 PM | #1 |
Rep 660
Removing Stock Shift Knob?
Hi All,
I've been trying to the past hour or so to remove the stock shift knob from my LCI in order to swap it out for the M Perf Knob. I've looked online and it seems the accepted method is to pull "very hard". I've tried all sorts of positions, including standing on the seats and pulling with my entire body weight (~170 lbs) with no success. It almost feels like it is glued in place. Does anyone have any suggestions? |
10-13-2017, 05:46 PM | #2 |
Rep 549
Drives: The Bus
Put it in second gear, lean back on it and pull up.
Try not to punch yourself in the face |
10-13-2017, 10:37 PM | #4 |
Rep 463
I put mine into 2nd gear, flipped up the arm rest and rested my elbow on the console(I didn't want to risk denting the arm rest with my elbow). Using my elbow on the console gave me the leverage I needed and to be honest it came off a touch easier than expected.
CommitConfirm474.50 |
10-19-2017, 03:25 PM | #9 | |
Rep 660
Maybe I will post a video of me trying to pull this thing off If I can't get it off before my break in service, I may just pay the dealership to give it a go. |
10-19-2017, 06:27 PM | #10 | |
Rep 1,298
10-19-2017, 07:16 PM | #11 |
Rep 549
Drives: The Bus
These are held on by friction. Go to the gym and work out for a month & try again
10-19-2017, 08:44 PM | #12 |
Rep 1,298
10-20-2017, 12:16 PM | #13 | |
Rep 660
I squat much more than my body weight, and even standing on the seats pulling straight up with my legs, it still does not come out. I'm afraid with the amount of force I'm pulling I may actually damage something... |
10-20-2017, 02:10 PM | #14 |
Rep 549
Drives: The Bus
Wow! That's impressive deadlift buddy. All I can think then is your technique is wrong. That's not a criticism more a thought, it should come off without the force of a god pulling on it.
Are you pulling straight up or are you applying force rewards and levering it up? |
10-20-2017, 02:59 PM | #15 | |
Rep 3,003
10-20-2017, 04:32 PM | #16 | ||
Rep 660
10-20-2017, 06:33 PM | #17 |
Rep 549
Drives: The Bus
12-27-2017, 08:55 AM | #18 |
Rep 1,339
Just got my iND blue stitched CF knob...
I do have the 2er CF knob with white stitching so I just wanted to have the blue back in and bought it from iND. (As i was scared to do the unglue and glue the boot back to the shifter). Friend of mine is buying my 2er knob anyways so I was not worrying to much to spend extra money for the perfect product. LoL Now problem comes to remove this knob... I did remove the boot from the console (easy job no problem) but as the OP is having trouble. Mine does not fking come off... very sturdy. My dealer installed the 2er knob so may be they glued it??? I have no idea. Would it be safe to use hammer with padding and lightly hitting the knob ring from the boot bottom up??? Dammm... now I am getting worry in another part hahaha. I just want to change it soooo bad.. LoL |
