10-11-2017, 06:37 PM | #23 | |
Rep 642
That's it, I'm getting rid of all the cars and buying a bicycle! |
10-11-2017, 07:10 PM | #24 | |
Rep 450
10-12-2017, 02:40 PM | #25 | |
Rep 8,163
I don't really want to rant, but... That's a thing that I can't really wrap my head around. Had an F20 rental for about a week and 750 miles and still did not manage to get used to it. It is actually more complicated - it took more time to set it up than the old CC, which, IIRC, works like this: Up/down - interrupt set speed Left button - resume set speed Forward/backward - set speed or increase/decrease speed That's all. E.g., I reach 35 mph, I push the stalk forward, cruise control set at 35 mph. I see red on the traffic light in distance, I push it down to cancel. Boom, done. I almost do it unconsciously. It's like a nice booty. I see one, I look at it. (I do that unconsciously, too) Now, in the newer cars, they have three buttons (CC, RES, SET) and one weird button/scrolling wheel thingy that do exactly the same as that old stalk with one lonely ass button. And because of that, I cannot change the volume with my left hand which is on the wheel all the time!
jjclyde125.50 |
10-12-2017, 10:48 PM | #26 |
Rep 582
1. What is the issue with the stalks? You say they have changed them to be more similar to other makes, but how and in what way? I have a 2017 and think the turn signal process is fine, if not easy and great.
2. Thank god they changed this, wish I could adapt the changes in my car. Righty tighty, Lefty loosey. Clockwise should always drill down/make the map bigger. No brainer here to me, not sure why BMW struggled here, but then again.... Lastly, wtf is cruise control... |
10-12-2017, 11:38 PM | #27 | |
3160
Rep 9,134
10-24-2017, 11:34 AM | #28 |
Rep 255
I noticed another subtle change yesterday -- engaging the turn signal dims the DRL on the side indicating the turn. E.g. If you signal left, the left-side DRL dimS until the signal is cancelled.
Much nicer than the behavior I've seen in other makes (Audi, Porsche, Land Rover) which is to simply turn the DRL completely off on the signal side. I'm pretty sure this is new behavior with the LCI. Yes/no? |
10-24-2017, 04:04 PM | #29 | |
Rep 289
Drives: '18 M2 MG 6MT, '03 E39
One other useful thing I noticed is that when you have finished reversing in to a spot with the beeping going crazy you can pop the shift lever into neutral and the beeping will stop. This is without rolling forward like many had complained about with pre-lci. You can also turn the car off with reverse engaged, move the shifter out of reverse, and start the car and it will not be beeping. However, it is not completely fixed because I have noticed that if you have the shifter in reverse at the moment you start the car it will not stop beeping regardless of what position you move the gear lever and will beep until you move forward.
Current Car | 2018 ///M2 MG 6MT
Previous Car | 2003 E39 530i Sport |
10-24-2017, 05:02 PM | #30 | ||
Rep 3,968
I swear I have not noticed this! Will compare tonight with my 1M.
10-24-2017, 09:54 PM | #31 |
Rep 3,968
So M2 non-LCI
Turn signal still works the same as it always has - snaps to the center. iDrive map is now reversed (thank GOD). Clockwise out, Counter Clockwise zooms in (the way it should have always been!).
11-06-2017, 12:08 PM | #32 |
Rep 13,093
Removed several posts 'infesting' this thread with off-topic ranting about cyclists' driving behavior, a discussion that 'went oversteer'.
Feel free to post those thoughts in the "Official Road Cycling Thread" in the General section of Bimmerpost: http://f87.bimmerpost.com/forums/sho....php?t=1249294.
///M is art ↔ Artemis
