10-09-2017, 07:32 PM | #1 |
2018 M2 DCT MGM
9
Rep 24
Where do you put sunglasses?
I thought it is a common question, but I cannot seem to find a thread about it. Where do you put sunglasses in your M2?
10-09-2017, 08:20 PM | #3 |
Rep 255
This sorta came up before. I found this to be the perfect place (assuming you keep your sunglasses in their case):
http://f87.bimmerpost.com/forums/sho....php?t=1396767 |
AngryBaby344.50 |
10-09-2017, 08:26 PM | #4 |
Cars, beer, hiking
367
Rep 259
Glovebox
AndrewC198910931.00 |
10-09-2017, 08:52 PM | #5 |
Rep 642
If only getting out of the car for a short time I throw them over the top of the shifter and they lay nicely in the soft Alcantara boot (with manual anyway). Otherwise in their case in the door panel.
10-09-2017, 08:55 PM | #6 |
Rep 715
I put mine on my face. I rest them above the nose and on top the ears.
When not wearing in the cup holder. |
10-09-2017, 09:15 PM | #8 |
Rep 642
10-09-2017, 11:47 PM | #9 |
Rep 2,200
I keep them in a case, and the case sits in the slot in the middle of the rear seat
10-10-2017, 09:26 AM | #14 |
Rep 146
Drives: '76 2002 / '17 F87 M2
Use the driver's sun visor for short term storage (slide one temple in between the mirror and the liner). Works pretty well as long as your sunglasses screws are tight
2017 M2 - LBB, 6MT, Exec, ED (April 2017), PCD (July 2017)
Instagram - @LongBeachBlueM2 My M2 European Delivery Adventure - April 2017 / Part II - Performance Center Re-Delivery - July 2017 |
10-10-2017, 09:45 AM | #15 |
Rep 642
Transition lenses don't work so well in the car because the windshield blocks UV light. I prefer polarized prescription sunglasses which also block UV better when you are not in the car. Good luck seeing your pre LCI gauges though!
10-10-2017, 11:19 AM | #16 |
I used to be conceited, now I'm perfect.
570
Rep 1,826
Drives: 2018 M3 CS
Doesn't anybody have a center console?
2018 M3 CS - Alpine White l l
"I used to be conceited. Now I'm perfect" |
10-10-2017, 12:23 PM | #17 |
Rep 3,297
My transitions don't get dark in the car! Car's glass blocks UV and that is needed to darken your glasses. Work around is to drive with glasses outside of car pointed at the sun for about 3 minutes, then put them back on, Down side is being blind for about 3 minutes.
I use old man clip on sunglasses. Convenient. And I put them in the door.
M2Nebula547.50 |
10-10-2017, 02:38 PM | #19 | |
Rep 642
10-10-2017, 04:44 PM | #20 |
Rep 430
I use the cup holder, but also purchased the following BMW mesh net.
There are also holders that use the visor. https://www.ecstuning.com/b-genuine-...t/51470429466/ |
10-10-2017, 04:55 PM | #21 |
Rep 549
Drives: The Bus
On my face :
10-10-2017, 05:00 PM | #22 |
Rep 199
For $25 I bought the BMW sunglass holder insert...pop out the ashtray and in goes the insert....30 seconds and you have a place to put your glasses...part number is #51169227896
Insert mat, compartment, front From:07/01/2011To:-Weight:0.060 kgPrice: Part 51169227896 was found on the following vehicles: 1' F20 (07/2010 — 02/2015) 1' F20 LCI (05/2014 — 06/2017) 1' F21 (07/2010 — 02/2015) 1' F21 LCI (05/2014 — 05/2017) 2' F22 (10/2012 — 06/2017) 2' F87 M2 (11/2014 — 06/2017) 2' F23 (03/2014 — 06/2017) Photos to follow...
