10-06-2017, 07:38 PM | #1 |
Rep 31
Water injection M2
Has anyone tried this for the M2 and what has been your experience? I understand in the making of the M2 CS they are swapping the N55 for the S55 but can we through water cooling see similar gains to transform our cars to be CS like? Expert opinions much appreciated thank you!
10-06-2017, 08:43 PM | #2 |
Rep 3,888
I don't see how you can do better than the Bosch system, and they only claim 5% increase in performance. You may however be able to safely raise boost or hold it longer do to lower combustion temps. So maybe add another 5%. My guess it that with a tune, you could get around 360whp on 93oct with no other changes. The M2 CS will probably make 50whp more than that stock.
10-06-2017, 09:12 PM | #3 | |
Rep 31
10-07-2017, 05:11 AM | #4 | |
Rep 3,888
The water injection also helps cool the combustion and thus keeps track temps down. |
10-08-2017, 08:12 PM | #5 |
Rep 1,644
Water injection on any motor not tuned for it won't give you any extra power. You'll just be able to go longer in heated conditions without losing any.
If you add combustion temp cooling you can usually start playing with the timing advance to find the maximum brake torque values at WOT. Most cars will stay slightly retarded from that max value from factory as a safety margin. If you have direct control of the wg you might be able to squeeze 1 or 2 more psi from a stock turbo in the top end and make small gains (at the expense of killing the turbo). |
