10-04-2017, 09:54 AM | #1 |
Rep 63
Normal oil tempature
What should be a normal oil temperature?
On my previous car (F30 320D) the oil temperature indicator always stayed stable at 90℃(194℉). In my M2 LCI, the temperature is most of the time stable around 95℃(203℉) but a lot of times also around 110℃ (230℉) even when I'm just cruising on the highway at 120kmh (75mph) with an ambient temperature of 15℃ (59℉). Is this normal? What temperatures do you guys see/notice? |
10-05-2017, 01:20 AM | #3 |
Meh
926
Rep 781
Drives: M3CS & Cayman S
i see between 95 and 108C even in 40+C temps
10-06-2017, 04:16 PM | #5 |
Rep 6,635
Something you should know is the cooler works harder in Sport and Sport+ mode than Comfort, so the car gets up to temperature faster in Comfort and probably cruises at a higher temp as well.
This all means if you want to cool the turbo down after a drive idle the car in sport for a minute for faster cooling. |
10-09-2017, 02:55 PM | #6 | |
Rep 3,695
When I switched to Comfort, both elevated to 220F in about three minutes. Switched back to Sport and temps came down in 4-5 min. Will do some logging the next time I’m on track in DSC off to see how high the temps get. |
10-10-2017, 06:37 AM | #7 | |
Rep 549
Drives: The Bus
This is due in part to the oil to coolant heat exchanger. |
10-11-2017, 09:41 AM | #8 |
Rep 570
The engine is more thermally efficient at a higher temp, with better VE and fuel efficiency. So, the new M- motors run hot in Comfort. Since temps rise significantly under more boost and higher throttle inputs, additional cooling (fan, etc) is provided to stabilize temps when on-track or spirited driving (i.e. in Sport/Sport +)
Nice design element, IMO |
FSociety3812.50 |
10-19-2017, 07:02 PM | #9 | |
Rep 251
BMW M2 2018 LBB
BMW X1 2016 PSM Audi S4 2014 SMG |
