09-28-2017, 07:56 AM | #1 |
Doc Brown
1176
Rep 2,174
Drivetrain Malfunction
So I know that this has been covered before and I have read the posts, but I have been getting them. It typically happens at about 120mph in, I think in 4th gear. It has already been to the dealer, they say that when they scan the car they can see the malfunction registered but they don't know why. I told them about what I read on the fourms about software updates and even showed him the posts but he had no real answers for me , except this..... I have the exhaust valve bypass installed and they told me that they have seen this cause the problem before and I should take it out. The main problem is that the problem is not easily repeatable. Meaning I can not get it to do it specifically. Sometimes it happens and sometimes it won't. I will take it out but I cant see how this can cause a drivetrain malfunction. The only other mods are the FabSpeed HFC and Dinan resonator delete. Nothing to the computer. Any help would be great.
09-28-2017, 12:04 PM | #2 |
IG @bmwF9xG80
3813
Rep 7,593
No tune ? I've only seen DTMAL with bad gas or bad tune
60-130mph 6.5s X4M #HCP
09-29-2017, 06:52 AM | #3 |
Doc Brown
1176
Rep 2,174
I don't know either. I don't think that is was bad gas as the car was running fine otherwise. It is so frustrating because I don't know when and if this will continue to happen. I love pushing the car but now I always have this in the back of my mind.
VegasM285.50 |
09-29-2017, 12:57 PM | #4 |
IG @bmwF9xG80
3813
Rep 7,593
no jb+ or Dinan sport hooked up ?
09-30-2017, 02:49 PM | #5 |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
A HFC could certainly cause the car to think that something is wrong.
10-02-2017, 07:18 AM | #7 |
Doc Brown
1176
Rep 2,174
I spoke to the dealer about that and he did not think that would cause it. People with completely stock cars are getting the same warning.
10-02-2017, 08:14 AM | #8 |
Rep 312
Just a thought. Could it be fuel starvation? There's been a number of reports of fuel pump issues at the track with less than 1/4 tank at high rpm.
AndrewC198910929.50 |
10-02-2017, 08:35 AM | #9 |
Doc Brown
1176
Rep 2,174
I guess that it is possible, I would have to try and duplicate it. But there was no noticeable signs of that while driving. The acceleration was smooth until the warning came up.
10-02-2017, 10:04 AM | #10 |
Rep 2,856
Easy solution by the looks of it! Your HFC might be causing the issue here.
Ask the dealer to do PUMA 62732575-01, after that retry if you have the issue. Same thing happened to my car, the drivetrain needed to be re-calibrated and adjusted to your new set up. MR |
VegasM285.50 |
10-03-2017, 07:28 AM | #11 |
Doc Brown
1176
Rep 2,174
Thanks, I will tell them.
10-11-2017, 10:26 AM | #12 |
Doc Brown
1176
Rep 2,174
So I haven't gone to the dealership again, but the light came on again yesterday. I was in 4th gear and accelerated (mildly) form 80 to 100 and BOOM! I had half a tank of gas and the temp was 74 deg. This is getting very frustrating. I have the info that MR. gave me but I am waiting to hit the 1200 mile mark to have my rear dif oil changed since I had the recall done. Hopefully that will fix this issue.
10-11-2017, 12:21 PM | #13 | |
IG @bmwF9xG80
3813
Rep 7,593
You can plug in and read your car to see what is the underlying Fault Codes Otherwise I would just take it to dealer let them diagnose
10-11-2017, 01:38 PM | #14 |
Doc Brown
1176
Rep 2,174
BMW said that there are no specific fault codes. They see the warning when they scan the car but they don't know why it is happening, or what is causing it.
10-11-2017, 03:10 PM | #15 |
Rep 306
Drives: MY17 LBB M2
10-11-2017, 03:39 PM | #16 |
Rep 6,635
10-12-2017, 07:40 AM | #17 | |
Doc Brown
1176
Rep 2,174
That is correct. I had the rear diff replaced under a recall, so I have to bring it back to have the oil changed again.
10-12-2017, 02:32 PM | #18 |
Rep 6,635
I would just probably get everything back to stock again see if you can get the drivetrain error to happen. If you do then we learned it's likely nothing you have done with the car. If it doesn't happen, add back a piece at a time until you know what's causing the problem.
10-12-2017, 03:33 PM | #19 | |
Doc Brown
1176
Rep 2,174
10-14-2017, 11:11 AM | #20 |
Rep 2,856
10-14-2017, 09:37 PM | #22 |
Chuggin' Along
333
Rep 588
Sorry some of that is cut off. What was your issue and fix? EKPS module (no idea what that is) was replaced, and that fixed voltage problem to the low pressure fuel pump?
