09-24-2017, 11:46 PM | #1 |
Rep 251
Tire Rotation
For the M2 the parts manager advises not to rotate the tires, not even from one side to the other. Doesn?t sound right. Any thoughts would be appreciated.
BMW M2 2018 LBB
BMW X1 2016 PSM Audi S4 2014 SMG |
09-25-2017, 05:55 AM | #2 |
Rep 931
Well you obviously can't swap front-to-rear which is generally the point of 'rotating' tyres. If you are getting excess outer edge wear of the driver's side front and the tyres are not directional then maybe you could squeeze an extra 1-2k km out of a pair however not everyone subscribes to the wisdom of changing the direction of a tyre in a high performance car. Are you noticing an excess wear pattern? I'm finding the M2 is wearing quite evenly whereas I did flip the fronts on my M135i due to outside edge issues....
09-25-2017, 07:24 AM | #3 |
Rep 2,924
No point swapping tires from side to side unless one side is wearing faster (either you always turn on he same side or you have other issues ie alignment, rubbing, etc).
After 5,000km on my car, wear is even.
BMW ///M Club Montreal
BMW ///M Club Montreal Facebook Page |
09-25-2017, 11:15 AM | #4 | |
Rep 251
BMW M2 2018 LBB
09-25-2017, 01:17 PM | #5 |
Rep 570
I believe the factory position, from BMW, on tire rotation is that once the tires begin to wear/shift internally due to the particular loads of the vehicle, rotation is not recommended. For example, if you remove your LF wheel/tire after you've accumulated some miles/KMs, you'll notice it won't roll straight once off the car. It adopts some camber change and is not longer uniform relative to a new tire. Given this, and the staggered set-up on it's performance tires/sport suspension, rotation is normally not recommended.
However, I've rotated side/side for the race track and for snow tires, where I ran a square set-up. If cost and tire longevity was no object, I wouldn't bother, but sometimes I'm looking to eek a bit more from the tires. Regardless, I am adopting some risk. I'm sure experience varies on this subject. I haven't read what the current manual says... |
09-25-2017, 02:07 PM | #6 | |
Rep 251
BMW M2 2018 LBB
