09-12-2017, 02:51 AM | #1 |
Rep 1,027
M2 MT - 1st to 2nd Gear
Quick question for M2 MT owners
What RPM do you shift from 1st to 2nd second gear? For me anything above 2000-2500 rpm results in a rough shift with a rubber banding sensation... Granted the car still doesn't have much mileage, it hasn't improved much since driving it the first day If not mistaken you should be able to shift from 1st to 2nd gear at much higher rpms, so I'm a bit confused For those that will say that I need to gain proficiency with the clutch... I've tried it in all ways with the same result Would love some opinions on this |
09-12-2017, 03:05 AM | #2 | |
Rep 709
2011 Lotus Elise SC, 2002 BMW 330d, 1990 Caterham Super 7 HPC (sold), 1985 Porsche 911 Carrera SC (sold), 1978 Caterham Super 7 (sold), 1972 Triumph TR6 (sold), 1972 Jensen Healey (sold), 1965 Triumph TR4A (sold)
09-12-2017, 03:05 AM | #3 |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
Depending on mileage, it may just need more break-in?
09-12-2017, 03:08 AM | #4 |
Rep 931
I'm up to 4500km and find a relaxed shift up to 3500rpm is fine but sometimes find if I'm hurrying my change is a bit umm...perceptible...If anything it's best if I don't overthink it and coming off the accelerator briskly then waiting until the lever fully slots into 2nd before letting the clutch out and throttling away usually does the trick. Perhaps it's about giving the rev-match enough time 'alone' to do its thing? Anyway it rarely bothers me now and all the other changes are sweet. Still rank it amongst the nicest clutch/shifts I've driven, rev match on or off.
09-12-2017, 03:37 AM | #5 | |
Rep 709
09-12-2017, 06:58 AM | #6 |
Rep 2,948
I usually short shift it under regular driving because of the ratios, usually at like 1800-2000 to avoid the clunkiness. If I'm driving for real, it'll be in the 4500-5000 range once it smooths over again.
09-12-2017, 08:59 AM | #8 |
Rep 56
09-12-2017, 09:01 AM | #9 |
Rep 341
Search 1st to 2nd gear grind and you'll stumble on something you probably won't be happy to find...
Sent from my Samsung Galaxy S2
09-12-2017, 10:35 AM | #10 |
Rep 642
Never understood any advantage of revving the piss out of first gear, especially on this car with the gear ratios as they are. It is less smooth and in-efficient.
I almost always short shift 1st to get enough momentum going and then rev the piss out of all the other gears! Can't even tell you what rpm really, I just go by feel and my own internal auto-pilot. |
4
09-12-2017, 11:31 AM | #11 |
Rep 507
I have similar experiences when shifting in the 2500-3k range. I find either shifting under 2k or a hair over 4k give it an easy smooth shift without any resistance. Also, I grab the shifter backhand and it feels better on the shift. If I pull from the top I feel a hair of resistance. Almost wanted to ask the dealer about it but I feel like that'd be too nitpicky. It never grinds so I just chalk it up to the way the synchros and transmission are. It's under warranty anyways so any real issues would come up long before warranty is over.
Side note: I feel the engine rev programming is best with the hidden exhaust mode for around town driving. Comfort, sport, or sport + give me that resistance more often. The bonus is it sounds better anyways. |
09-12-2017, 02:25 PM | #12 | |
The deuce gets loose
290
Rep 499
M3 Adjuster7905.50 |
09-12-2017, 02:45 PM | #13 | |
Rep 5,369
OP - The 6MT will get smoother as it gets some miles (usually 5K or so). |
Bosozoku693.50 |
09-12-2017, 03:19 PM | #14 |
Rep 642
09-12-2017, 03:26 PM | #15 | |
Rep 642
09-12-2017, 04:29 PM | #16 |
Rep 7,295
Every BMW manual sucks at rushing a shift into 2nd. Some more than others, though. By most accounts the transmission in the F8x M cars is one of the best as far as resistance and notchiness into 2nd.
09-12-2017, 05:16 PM | #17 |
Rep 549
Drives: The Bus
7k in all gears
M3 Adjuster7905.50 termigni1081.00 |
09-12-2017, 09:14 PM | #19 |
Rep 2,948
M3 Adjuster7905.50 CommitConfirm474.50 |
09-12-2017, 11:46 PM | #20 |
Rep 4,253
You just need to get more familiar with the trans. Careful modulation of clutch and throttle is required. This is the same for essentially every BMW I have ever driven. 1 to 2 is always tricky but keep at it.
M3 Adjuster7905.50 ewohar21.50 |
09-13-2017, 12:05 AM | #21 |
Rep 709
If I ever need to buy a second hand car I think I'll avoid YOU
09-13-2017, 05:30 AM | #22 |
Rep 417
Much smoother with sport mode on I find.
F82 M4 | 6-speed manual | PP performance Stage 2 tune | Re-valved Bilstein B16s | VRSF midpipe | OEM CS front splitter | OEM GTS hood | OEM M-performance rear diffuser| Evolve tuning catless downpipes | 310rwkw (415rwhp)
chief1richard381.00 |
