09-28-2017, 04:49 PM | #111 | |
Rep 18
09-28-2017, 07:09 PM | #112 | ||
Rep 166
09-30-2017, 03:54 PM | #113 | |
Rep 209
How is the sport tuner from Dinan? Interesting its so much cheaper than the performance tuner they sell. I'm considering getting it for the M2! |
09-30-2017, 06:59 PM | #114 |
Rep 199
I have the Dinantronics and the Fabspeed sport cat...it is a potent combo...the sport cat really took things up a notch, not sure how much difference the stage 1 Dinantronics has made, but it definitely added to the mid range...I have heard the far less expensive tune is great for far less $; but I am planning on eventually adding the Dinan big turbo-intercooler set up...so I went for the whole enchilada.....
10-01-2017, 12:33 AM | #115 | |
Rep 209
10-10-2017, 08:27 PM | #116 | |
Rep 12
That is, if you were to leave everything under the valve cover stock, every internal part inside the block stock, but change everything else that is "outside" (turbo, exhaust, intercooler, injectors, engine management, etc), how much power can you make before things like pistons and rods need to be changed? It would be totally illegal of course on the street, but I imagine the stuff you guys are doing is technically illegal anyway. For this, I guess assume 92 octane pump gas as the fuel. I don't even want to think about 91 eeesh. Then for a "stage 2" let's say you converted to a flex-fuel engine management, using an off the shelf ethanol sensor, and mixing E85 into the tank to ward off knock at high boost, then what could the engine do on stock internals?
My car specs, mods, dyno, and photos:
http://www.dsmtuners.com/dsm-profile...ld-2016.12870/ Last edited by We're on Boost; 10-10-2017 at 11:51 PM.. |
10-10-2017, 08:50 PM | #117 | ||
Rep 3,075
I recommend it to anyone. I am actually sending one to a friend over in UK this week. Combined with the FMIC and 93 octanes I have had no issues with it, no limp/safe mode running it hard.
Follow me on IG
///cbrash226.50 |
10-10-2017, 09:05 PM | #118 | |
Rep 209
10-10-2017, 09:08 PM | #119 |
Rep 3,075
Was using on Sport+ since day one until I took to the dyno. Did two pulls on sport+ and one in Race and there was a considerable bump. I usually alternate.
Follow me on IG
10-22-2017, 02:59 PM | #120 |
Rep 102
What was better?
15' X5M DG, enzotune
17' M2 *** CTS Turbo FMIC, CTS Turbo DP, CTS Turbo CP, CTS Turbo Intake *** Bootmod3 E30 OTS |
10-22-2017, 03:28 PM | #121 |
Rep 3,075
Race yielded best power.
Follow me on IG
10-23-2017, 12:29 PM | #122 |
Rep 4,541
Drives: 2015 328d xDrive
UK uses RON. North America uses MON.
"Because of the 8 to 12 octane number difference between RON and MON, the AKI shown in Canada and the United States is 4 to 6 octane numbers lower than elsewhere in the world for the same fuel." - Wiki Therefore our fuel isn't shittier. It's just numbered differently. 49/50 states in the USA have 93MON which is the equivalent of your 98RON. It's just California that has to make due with shitty 91. Probably because of emissions. Last edited by AndrewC1989; 10-23-2017 at 04:48 PM.. |
No Boost4021.00 NYC Bimmer259.50 |
10-27-2017, 06:53 PM | #123 |
Rep 238
First run is my baseline and the next two are modded with the following bolt-ons:
JB4 Map 3 with a Boost Additive of 70 BMS Water-Methanol Injection Fabspeed Catless Downpipe Pretty damn happy with the torque figure, wish the HP number was slightly higher. The sharp torque drop right after the car hits peak boost must be something with the dyno / M2 / JB4 logic. If I compare the logs on the dyno vs. on the street you can see that the throttle plate closes right after the car hits peak boost when its on the dyno, but when its on the street it does nothing of the sort - it's a lot smoother in its throttle modulation. Weird, not sure why there would be that difference, but it definitely doesn't feel like there is a sharp torque drop while on the road. Will be sending these graphs and logs off to BMS to see what they say!
Instagram - @niru.s1k
24 BRG M3 - Pending Delivery 17 BSM M2 (SOLD) - PureTurbos Stage 2 - BM3 - Tuned by F80Paul @ Paul Johnson Tunes Last edited by Endeav; 10-27-2017 at 07:05 PM.. |
10-29-2017, 10:38 PM | #124 |
Rep 102
Endeav no map0 or map4 pull to see delta?
Judging by just these numbers, other cars making this power without Meth btw not sure what to make o fit and there's something seriously not happy with the car after 5500rpm when those lines are so choppy (unstable) even on smoothing 5 Grab DRF files from dyno shop and can view at home for further studying.
Endeav388.50 |
10-30-2017, 09:47 AM | #125 | |
Rep 238
I'll grab the DRF files hopefully sometime this week and send them your way. I have the JB4 logs from on the dyno as well - would you like those?
24 BRG M3 - Pending Delivery 17 BSM M2 (SOLD) - PureTurbos Stage 2 - BM3 - Tuned by F80Paul @ Paul Johnson Tunes |
11-06-2017, 01:31 PM | #127 | |
IG @bmwF9xG80
3812
Rep 7,593
60-130mph 6.5s X4M #HCP
NO_USER_537.50 DragonGate71.50 |
11-08-2017, 02:05 PM | #128 |
Rep 190
I had a baseline Dyno run performed today. Car is a 2017 M2 w/ mostly cosmetic and shifter related mods. I do have the Dinan exhaust but that shouldn't add any power. I did have the resonator delete as well but didn't like the highway drone so the shop welded in the stock resonator before the Dyno time. The car is on 93 octane fuel.
HP = 356.5 hp TQ = 385.9 ft-lbs Not that it means a whole lot since the delta is what matters once modding begins but those seem like strong numbers for a stock car.
:::: 2017 AW M2 :::: (SOLD)
12-13-2017, 10:50 PM | #129 |
Rep 209
Hex tune stage one
Modifications previously done:
- Dinan Res Delete - Dinan Cat-back Exhaust Otherwise completely stock car running CA 91 octane. Wheel horsepower - 340 wheel ft/lbs torque - 376 After stage one software Wheel horsepower - 372 wheel ft/lbs torque - 428 |
DroneandDone94.00 BeemerBoost118.00 |
12-14-2017, 05:56 AM | #130 | |
Rep 2,577
Pretty high reading 356whp SAE numbers it seems. We're looking at a 365whp STD corrected, stock.
Lemania 2320
FSociety3811.50 |
12-14-2017, 06:14 AM | #131 |
Rep 190
Like I said, not super concerned with the numbers, more so delta and area under the curve once I get actual power mods. The tech did mention that their dyno typically reads a few percentage points lower than several other Dynojets in the area so IDK
12-20-2017, 12:33 PM | #132 |
Rep 2,829
Now you just need to add downpipe and stg 2.
Your going to be joining the 400 Club ///
BMW I12 i8 Frozen Yellow- H&R springs, 22" Radenergie F10 Monoblock Forged /// F87 M2 Aw -Vorsteiner Aero Kit, VFF-107,Macht Schnell-Springs,VF-Engineering/Hex tuning Stage Two,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe/// Wish list :Mexico delivery 2024 BMW M2 (G87) |
BeemerBoost118.00 BAN_M2C4178.00 |
