M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > ► Official APEX Wheels Showroom Gallery Thread
      05-16-2017, 04:28 PM   #1
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Show Us What You Got!
With an increasing number of F87 M2 enthusiasts mounting APEX wheels on their vehicles for both street and track use, we see many photographs of APEX wheels shared throughout the forum. This thread will compile photos of different APEX wheel fitments, as well as provide the community with detailed information surrounding wheel and tire fitment, alignment settings, brake and suspension clearances and more! Please feel free to ask questions along the way, we have fitment experts ready to provide technical support for both spirited street driving to weekend track warriors.
Feel free to just share pictures, but we know other enthusiasts would greatly appreciate if you included the following:
  • Wheel Model, Color, Size & Offset
  • Front and Rear Tire sizes, Tire Make & Model
  • Suspension Modifications, Camber Plates
  • Any required alignment settings such as added negative camber
  • Any other required modification (Spacers, fender rolling, etc.)
Let's Kick Things Off!
18" EC-7
click here to learn more
Wheels:
Flow Formed EC-7 wheels in Race Silver
18x9.5" ET35 Square
Tires:
Nexen SUR4G
265/35-18 Square
Additional Modifications:
N/A
19" EC-7
Wheels:
Front: 19x9.5" ET28 Rear: 19x10.5" ET45
Tires:
Toyo R888
Front: 265/30-19 Rear: 295/30-19
N/A
18" SM-10
Wheels:
Flow Formed SM-10 in Satin Black
18x9.5" ET35 Square
Tires:
Bridgestone RE-71R
275/35-18 Square
M Performance coilovers
12mm front spacer and 5mm rear spacer
Ground Control camber plates
18" FL-5
Wheels:
Flow Formed FL-5 wheels in Satin Black
18x9.5" ET35 Square
Tires:
Nitto NT01
275/35-18 Square
5mm front spacers
18" ARC-8R
Wheels:
Forged ARC-8R wheels in Polished
18x10.5" ET40 Square
Tires:
Toyo Proxes RR
295/35-18 Square
25mm front spacers
18" EC-7R
Wheels:
Forged EC-7R Wheels in Satin Black
Front: 18x9.5" ET22 Rear: 18x10.5" ET40
Tires:
Nankang AR-1
Front: 265/35-18 Rear: 295/30-18
Ohlins R&T coilovers with custome shim stack
H&R race springs
Millway camber plates
Fall-Line Motorsports toe link and rear camber shims
Looking To Browse A Gallery For Another BMW Chassis? Look No Further!
BMW E9X Non-M
BMW E9X M3
BMW E82/88 1-Series
BMW 1M
BMW E85/86 Z4/Z4M
BMW E89 Z4
BMW F3X 3/4-Series
BMW F8X M3/M4
BMW F22 2-Series
BMW F87 M2
Still Can't Find The Right Picture? Check Out Our Flickr Account For More Content!
      05-16-2017, 05:31 PM   #2
rwalker
Drives: the wheels off
Originally Posted by ApexRaceParts View Post
We will kick things off with this White M2 from Alekshop:
  • APEX EC-7 18x10” ET33 Square
  • 12mm spacers up front
  • Potenza RE-71R 275/35/18 Tires
  • Track alignment (negative camber)
  • AP Racing Pro 5000 Brakes
Up front: 18x10et21 effective? Holy cow! That's 20mm more poke in front than stock! How much camber, which plates?
      05-17-2017, 11:47 AM   #3
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
We are not sure which camber plates they used... possibly Ground Control. This car is sorted for track time so my guess is they dialed in around -3 degrees up front. I will try to verify this for you guys.
- Ryan
      05-17-2017, 11:48 AM   #4
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Our customer Shaun’s BMW M2 with 18” EC-7 Square Setup
Wheels: APEX EC-7 18x9.5" ET35 Square
Tires: 265/35-18 Toyo R888R
Spacers: 15mm spacers up front
Suspension: MCS 2 way remote suspension
Camber: F: -3.2 | R: -2.9
Appreciate 4
JustChris17487.50
F87LUV3689.00
Bosozoku693.50
GFEA228.50
      05-30-2017, 10:06 PM   #5
kenneth
kenneth's Avatar
125
Drives: 335i Sedan
What kind of hubcentric spacers would you recommend in 12 and 15 mm sizes? And what material, aluminum? I have a fear of the spacer lip guillotined by the wheel....
SB, Terra, 6MT. Only a few mods here and there.....nothing extreme!
      05-31-2017, 01:11 AM   #6
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
I would recommend our hubcentric APEX spacers paired with the proper length extended hardware (lug bolts or stud kit). We have great product pages that dive into the details about our spacers.
- Ryan
      07-27-2017, 11:15 AM   #7
Expert@ApexWheels
Expert@ApexWheels's Avatar
3522
Drives: M3
David shared some great shots of his M2 on EC-7 wheels! We think they look amazing on his car
Wheels: Anthracite EC-7 18x9.5 ET35 square
Tires: Michelin PS4 275/35-18
Spacers: 12mm up front for strut clearance (5mm would have worked). 12mm spacer in rear.
Suspension: KW HAS
///Cardia299.50
Bosozoku693.50
Adam68415.00
      07-27-2017, 01:45 PM   #8
BLUE-BEAST///M2
Drives: 2018 BMW M2
Looks great!
AP3X_FTW215.50
      08-02-2017, 09:30 PM   #9
MRufo
I Love it! You really think the 275 would fit with a 35 offset and only a 5mm spacer? I was thinking I would go with the 22mm.
      08-03-2017, 04:31 PM   #10
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Originally Posted by BLUE-BEAST///M2 View Post
Looks great!
Appreciate it!
Thank you for the compliment. Yes, 275's work very well with the 18x9.5" ET35 square fitment, however spacer thickness requirements up front for proper strut clearance will vary depending on tire brand, vehicle ride height as well as suspension type.
With stock suspension, lowering springs with stock shocks, or most aftermarket coilovers with linear springs, inner clearance is maximized and 5mm spacers can be used with most 275 tires. With height adjustable sleeve kits or coilovers like KW, Bilstein or Ohlins, thicker spacers may be required due to the suspensions design.
Yes, by running the 9.5" ET22 you could bypass the need for spacers. however now you have a very aggressive fitment in the rear. There are pro's and con's to either, and that is ultimately why we are developing the 18x9.5" ET28 for this chassis.
- Ryan
      08-04-2017, 08:34 AM   #11
AGM2
AGM2's Avatar
Drives: M2 LBB 17
Suspension: KW HAS
      08-20-2017, 11:19 AM   #12
mrcheezle19
Drives: 21 M2C 6MT
18s with meaty tires looks so good on this car.
      08-20-2017, 03:46 PM   #13
Orange fever
Orange fever's Avatar
Thailand
2351
yup lked them on my e90m, maybe next set of wheels
BMW I12 i8 Frozen Yellow- H&R springs, 22" Radenergie F10 Monoblock Forged ///
F87 M2 Aw -Vorsteiner Aero Kit, VFF-107,Macht Schnell-Springs,VF-Engineering/Hex tuning Stage Two,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe/// Wish list :Mexico delivery 2024 BMW M2 (G87)
ApexWheels1426.50
      09-23-2017, 09:49 AM   #14
Jevi Javi
Dominican Republic
80
Drives: e46 M3 + G05 X5
FL-5 18" x 9.5" et22
-3.5 camber up front
hankook rs-4 275/35/18
what do you guys think?
      09-23-2017, 01:31 PM   #15
Pic18
Drives: 18' F80 Comp, Spec E46
I think it looks really good, big fan of the apex products.
      10-10-2017, 01:17 PM   #16
Expert@ApexWheels
3522
Drives: M3
Great setup
      10-16-2017, 12:03 PM   #17
Expert@ApexWheels
3522
Drives: M3
Here are some recent customer photos of this Alpine White M2 with FL-5 wheels in satin black wrapped with some meaty Bridgestones.
Square setup:
18x9.5" ET35 FL-5 wheels in Satin Black
12mm front spacers
-3 front camber
275/35 R18, bridgestone potenza RE71Rs up front.
-2.2 rear camber
275/35 R18, bridgestone potenza RE71Rs in the rear
ObsidianX130.00
      10-20-2017, 09:26 AM   #18
ObsidianX
Drives: 2017 M2 (LBB, 6MT)
Love these FL-5... but these specs seem ideal for track setups. What would you recommend for a daily driver M2 without suspension mods and camber plates? How wide can I safely go for wheels and tires?
2017 BMW M2 (LBB, 6MT)
2011 BMW 335i xDrive (N55)
2006 BMW X3 3.0 (M54B30) - Sold 5/17
      10-23-2017, 01:49 PM   #19
Expert@ApexWheels
3522
Drives: M3
Hi ObsidianX
We'd recommend the following fitment...
Front:
18x9" ET30 FL-5 wheels with 245/40-18 tires
Rear:
18x9.5" ET35 FL-5 wheels with 265/40-18* or 275/35-18 tires
*Edited with correct tire size.
ObsidianX130.00
      10-23-2017, 05:06 PM   #20
ObsidianX
Hi ObsidianX
Front:
Rear:
18x9.5" ET35 FL-5 wheels with 265/35-18 or 275/35-18 tires
Why not 265/40R18 or 275/40R18 in the rear? Isn't the stock 19" tire 265/35R19?
      10-24-2017, 12:38 PM   #21
Expert@ApexWheels
3522
Drives: M3
Performance Technic's M2 project car with 18" SM-10 Wheels, custom painted in Alpine White.
Specs:
- 18x9.5" ET35 SM-10 (custom painted Alpine White)
- 275/35-18 Bridgestone Potenza RE-71R Tires
- 20mm Spacer in the front (for a flush look)
- 5mm spacer in the rear (to match the front)
- Ohlins Road and Tracks Suspension
- Ground Control Camber Plates
- Dinan Sway Bars
- APEX Extended Stud Kit
ObsidianX130.00
M3 Alex122.50
      10-24-2017, 03:01 PM   #22
_pancho_
_pancho_'s Avatar
Sweden
16
Drives: modified F87 M2 Man -17
My Swedish '17
Wheel/chassi specs:
- 18x10" ET33 APEX EC-7 Silver
- 265/35-18 Toyo R888
- 10mm H&R Spacers in the front with longer bolts
- KW v3 Suspension
- Millway adjustable Camberplates (Swedish brand)
/Tobias
GVN*2FLY102.00
adisz165.50
