01-20-2017, 10:37 PM | #45 |
Space Force - 4 Star General
11461
Rep 3,264
Yes, this. Let's see what those mesh shields look like. I pulled my rear wheel off and poked around the dust shield. There's really no obvious place to affix the shield. if anyone has a mesh shield installed I'd sure love to see it. I guess I was envisioning an air inlet scoop of some sort on the dust shield. Some obvious place that calls out for being covered. But there simply isnt. I'm thinking that bending the backing plate back is probably the best course of action.
01-21-2017, 10:10 PM | #46 |
Rep 123
Mine is a 2017 and I have 4 noises, thumps, vibrations and screeches happening. There is definitely something going on when going slowly up a steep hill getting on and off the throttle.
Just checked mybmw today and no recalls yet. |
silverlude23.50 |
01-22-2017, 07:34 AM | #48 |
Rep 121
I had the scraping sound again this morning. It's always over a sharp/steep bump.
01-23-2017, 04:15 AM | #49 | |
Rep 20
It sounds like scratching over the ground or having snow between tires and wheel housing. It has the DCT and was build in week 51 of 2016. I drove him about 750km until now and my run-in driving is very gentle with no reving over 3500rpm and just giving half throttle. The actual outside temperatures are about -10°C. I can replicate the noise - mostly in the 4th gear at about 2000rpm - and it also comes in Sport mode. If this is really a noise caused because of the low temperature, all would be fine ... nevertheless it's really annoying. |
01-23-2017, 05:24 AM | #50 | |
Rep 13,097
///M is art ↔ Artemis
01-23-2017, 10:10 AM | #51 |
Rep 817
I honestly cannot believe anyone still questions whether or not it's the differential.
It's not. There have been no reports of a diff making the "soda can crunch" noise for a reason other than rocks in the brake shield. Yes, it sounds terrible. Yes, it's sounds like a crunch, or metal-on-metal scrape, and yes it can happen several times in rapid succession or it might happen once in a great while. It does go away over time, especially if you flex the shield to give any rocks that might get lodged in there more clearance to fall out. There's no way to reliably reproduce the phenomenon, and it's somewhat alarming when it does happen. But it's completely benign, will not hurt your car, and none of this should be conflated with the old diff recall that affected early MY '16 vehicles. |
01-23-2017, 11:34 AM | #53 |
Rep 202
01-23-2017, 05:23 PM | #54 |
Rep 121
I found a driveway to replicate the crunching sound. It's very repeatable on steep roads. But it's not the diff or rocks in the dust shield. It's when one rear tire has nearly no weight on it. The tire does a mini burnout. Almost half a rotation before transferring power.
Odd part is I'm going 1-2 mph |
01-23-2017, 07:48 PM | #55 | |
11461
Rep 3,264
01-24-2017, 01:18 AM | #57 |
Rep 6,635
I can reproduce the can crush sound on inclines. MY17 DCT about 700 miles on it. Seems to happen only in Sport + mode I think....
Two video I took tonight of the sound, one going uphill, one going downhill. Sorry for the camera work I was just trying to get the sound. On the downhill looks like I was in 2nd and took my foot off the gas before it happened. I assume this sound is what other people are hearing? |
01-24-2017, 02:00 AM | #58 | |
7906
Rep 11,785
That's not the rock between the rotor and guard noise at all. Is there any resistance in the chassis when this happens ? Someone mentioned the car lifting up at the rear ? Omg if my car had this I think I would make the dealer service rep ride in the car and listen until they scream MAKE IT STOP! and throw the keys to a loaner while they call BMW about a new DIFF.. yikes. |
Corinne1171.00 |
01-24-2017, 02:13 AM | #59 | |
7906
Rep 11,785
Now then if the diff is making a noise like akkando then , I'm no mechanical engineer, but it sounds like a clutch pack responsible for lockup in the differential is chattering ? The M diff definitely can do some funky things ..seeing as its all electronic and hydraulics and all. Wonder if a servo is wigging out ... |
01-24-2017, 06:11 AM | #60 | |
Rep 121
M3 Adjuster7905.50 |
01-24-2017, 06:48 AM | #61 |
Rep 486
Mine sounds like that but it's much shorter. It also only seems to happen on roads with rocks or debris. If you take that vid and cut the sound after the first instance before it starts the actual chatter, that's what mine sounds like. Less than 1 second of noise.
I'm now wondering if this isn't just rocks/debris and is the diff. |
01-24-2017, 07:46 AM | #62 | |
11461
Rep 3,264
I'm going to try mine today in the parking garage at work. It's also a slight incline like in your video. BTW, can you please post these in the "Soda Can Crunch" thread as well? This is by far the best video/audio of the issue anyone has managed to capture. Nice work!!!! |
01-24-2017, 12:21 PM | #63 |
Rep 817
01-24-2017, 12:27 PM | #64 | |
Rep 6,635
I can only hear rocks in my brake shield when in sport + mode? Seems fishy to me. Seems like when the rear wheels are allowed to slip more, then it's more likely to happen. It also seems like it's more likely to happen when the car is cold because so far I can't as easily reproduce if it's been driven for more than ten minutes. That's my experience so far anyway. |
01-24-2017, 02:51 PM | #65 |
Rep 241
GJ on the videos I couldn't help but laugh by your comments at the end of them. Hopefully we can figure out wtf that is for sure and not just assume every sound people hear is rocks On the brake shield.
