Classifieds Section > Sponsors Classifieds > Dinan High Performance Adjustable Coil-Over for F87 M2
      10-21-2016, 11:12 AM   #1
HP Autosport
Drives: F80 M3
Smile Dinan High Performance Adjustable Coil-Over for F87 M2
For the driver that demands the best out of their vehicle. The Dinan Adjustable Coil-Over Suspension was bred in the race lab but refined on the street for maximum versatility. No matter the environment, the traction that is bestowed upon the vehicle from the improved suspension will inspire new found confidence when running at higher speeds. Combined with a substantial reduction in body roll as well as reducing dive under breaking and squat under acceleration. Dinan will guarantee you superior handling, performance, and comfort. Dinans design implements threaded collars to allow the user to change the ride height. The end result is a sleek lowered stance that provides improved handling to go along with its stunning visual appearance. The springs combined with progressive bump stops and other components increase travel that allows the car to be lowered up to an 1" in the front and 1-1/2" in the rear. Suspension packers are included to fine tune handling and comfort by changing the clearance of the progressive bump-stops, something no respectable race car is without. Components are machined from 6061-T6 aluminum and black anodized for appearance and corrosion protection.
Benefits of Dinan's High Performance Adjustable Coil-Over Suspension System:
+ Threaded collars allow easy and precise front & rear vehicle height adjustments.
+ Up to 1" of lowering in front and 1 1/2" of lowering in back are possible depending on tire clearance although 3/4" drop in front and a 1/2" drop in the rear is recommended to maintain a civilized ride.
+ Spring rates are nearly 18% stiffer in front and 5% stiffer in the rear.
+ Helper Springs are used in the rear to maintain proper suspension operation under droop conditions.
+ Substantial reduction in body roll.
+ Included suspension packers allow adjustment of bump-stop clearance to fine-tune handling and comfort.
+ Dinan-spec progressive bump stops improve ride quality at lowered ride heights.
+ Components are machined from 6061-T6 aluminum and black anodized for a sporty appearance as well as corrosion protection.
+ Stock upper spring mounts are utilized for quiet operation.
*Note: Due to the extensive lowering possible, and the increased suspension travel, the installer must carefully evaluate tire clearance under all situations. Safety will be compromised if all precautions are not taken. Dinan is not responsible for any property damage or injury.
$1299
Order here:
http://www.hpashop.com/Dinan-High-Pe...ver-F87-M2.htm
      10-25-2016, 01:35 PM   #2
HP Autosport
Drives: F80 M3
bump
      10-27-2016, 06:00 PM   #3
HP Autosport
Drives: F80 M3
bump
      11-03-2016, 03:24 PM   #4
HP Autosport
Drives: F80 M3
bump
      11-07-2016, 01:43 PM   #5
HP Autosport
Drives: F80 M3
bump
      11-07-2016, 09:02 PM   #6
Twt
Twt's Avatar
634
Drives: 2017 M2
How do these compare to the MP coilovers ?
      11-08-2016, 11:37 AM   #7
HP Autosport
Drives: F80 M3
These are height adjustable coils using the OEM dampers. The MP coilovers two-way adjustable) is basically a KW V3. Apples to oranges, really can't compare.
      11-13-2016, 07:51 PM   #8
HP Autosport
Drives: F80 M3
bump
      11-17-2016, 11:42 AM   #9
HP Autosport
Drives: F80 M3
bump
      11-22-2016, 11:01 AM   #10
HP Autosport
Drives: F80 M3
bump
      11-30-2016, 06:15 PM   #11
HP Autosport
Drives: F80 M3
bump
      12-02-2016, 11:17 AM   #12
HP Autosport
Drives: F80 M3
bump
      12-07-2016, 11:57 AM   #13
HP Autosport
Drives: F80 M3
bump
      12-11-2016, 10:20 PM   #14
HP Autosport
Drives: F80 M3
Days to Xmas pricing...PM us for coupon code!
      12-15-2016, 01:34 PM   #15
HP Autosport
Drives: F80 M3
bump
      12-22-2016, 12:56 PM   #16
HP Autosport
Drives: F80 M3
PM us for xmas coupon
      12-27-2016, 05:04 PM   #17
HP Autosport
Drives: F80 M3
bump
      01-01-2017, 10:17 PM   #18
HP Autosport
Drives: F80 M3
PM us for a coupon code!
      01-05-2017, 04:23 PM   #19
HP Autosport
Drives: F80 M3
bump
      01-10-2017, 11:50 AM   #20
HP Autosport
Drives: F80 M3
Dinan!
      01-18-2017, 11:41 AM   #21
HP Autosport
Drives: F80 M3
      01-23-2017, 05:40 PM   #22
HP Autosport
Drives: F80 M3
bump
