M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > 18x9.5 track wheels from Tire Rack!
      07-07-2017, 10:59 AM   #155
Rudy@tirerack
Drives: rudy@tirerack.com
Originally Posted by Jamesembry View Post
Has anyone tried these yet with NT01's? What spacer(s) are required?
265/35/18 does not require spacers.
275/35/18 requires 3-5mm spacers
      07-11-2017, 09:24 PM   #156
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
Originally Posted by Keith@tirerack.com View Post
Originally Posted by 3002 tii View Post
Keith, does TRM have a wheel in same width and offset but in 17" diameter? Looking for something to mount a 255/40-17 on my Z.
This wheel is available in the following 17" sizes:
17x8 ET40
17x8 ET32
17x9 ET30
Please email me directly if you would like to discuss a package for your Z.
Thanks!
Any 19 inch sizes?
      07-12-2017, 02:27 PM   #157
OLO-M2
Belgium
38
Hi Keith (and all),
I've just posted a new message about cheap 18" track rims... and it seems that you have got the solution actually !
Would you have pics with a black M2 ?
Can you ship to Belgium with customs settled ?
What price with/without semi-slick tyres ?
(Incl cap and pressure valve)
Thx :-)
Olivier
      07-21-2017, 09:48 AM   #158
Rudy@tirerack
Originally Posted by Pyrat 2 View Post
Any 19 inch sizes?
No, unfortunately no 19" sizes
      07-21-2017, 09:54 AM   #159
Rudy@tirerack
Originally Posted by OLO-M2 View Post
Hi Keith (and all),
Thx :-)
Olivier
Oliver,
I believe there are some photos available if you look through the earlier pages of this thread.
When you are ready, please email me directly at keith@tirerack.com to discuss your options and the costs.
Thanks!
      07-21-2017, 12:50 PM   #160
OLO-M2
Belgium
38
Hi Keith (and all),
Thx :-)
Olivier
Oliver,
Thanks!
Email sent !
FYI I cannot see any of the pictures posted in the earlier pages, they are hidden (no idea why)..
      07-24-2017, 08:05 PM   #161
Jamesembry
Drives: M2 M Performance Edition
Anything on the RS4?
      07-26-2017, 11:56 AM   #162
Rudy@tirerack
Here is a link to our entire test report comparing:
BFGoodrich g-Force Rival S 1.5
Bridgestone Potenza RE-71R
Hankook Ventus R-S4
Nexen N FERA SUR4G
https://www.tirerack.com/tires/tests...y.jsp?ttid=226
BAN_M2C4154.50
OLO-M237.50
rich8566608.50
      07-31-2017, 09:08 PM   #163
rich8566
rich8566's Avatar
Drives: M2 + Z-4
2014 BMW M235i  [0.00]
I want to bring a couple track wheels to your attention. These are not listed for the M2 on Tirerack.com because they are aggressive track applications.
Both are very strong wheels specifically designed for track use.
265/35/18 would be the best tire size for a square track package.
OZ Challenge
18x9.5
ET33
24lbs
1 piece low-pressure cast
$449 each
Click this link to view the wheel:
Silver - http://www.tirerack.com/wheels/Wheel...b=wheels&a=BS4
TRMotorsport C4
18x9.5
ET33
Will confirm weight once the first shipment comes in.
1 Piece low-pressure cast
$165 each
Will be available in black or light grey.
Black - http://www.tirerack.com/wheels/Wheel...b=wheels&a=BS4
Light Grey - http://www.tirerack.com/wheels/Wheel...b=wheels&a=BS4
This is a wheel Tirerack is having specifically built for M2 track packages, which is why we are able to keep the price so low.
Neither of these wheels are currently listed for the M2 on www.tirerack.com. These would have to be ordered with me directly.
Feel free to email me directly at Keith@tirerack.com if you have any questions or would like to place an order.
Can I mount RS4's in 245/40-18 and 265/40-18 on these wheels 9.5" wheels or would it be better to go to a 9 inch front and 10 inch rear wheel?
      08-02-2017, 08:13 AM   #164
Rudy@tirerack
245/40/18 - rim width range of 8.0-9.5"
265/40/18 - rim width range of 9.0-10.5"
So, yes you can put both of those sizes on 9.5 width wheels.
Those sizes would probably look better on a 9" and 10" wheel, but if you wanted to run them on a 9.5", there is no problem doing so.
      08-02-2017, 02:40 PM   #165
MRufo
Keith,
I'm running your square set up (TR rims) with 265 star specs. The car has pulled HARD to the right since day one. Even on a flat even surface with no road crowning. With the stock wheels on it pulls ever so slightly. I had my alignment checked twice by a race shop and they said it was spot on. Is it possible that the rim/s could be out of balance from the manufacturing process? Maybe a bad tire? Rotating the tire front to back doesn't seem to make a difference.
The shop said they swapped the front wheel/tire left to right then it pulled to the left. So in there opinion it's a rim/tire problem.
I'm taking my car to the dealership next week to have the alignment checked for a third time. Do you have any ideas?
Thanks,
Martin
      08-03-2017, 05:35 AM   #166
OLO-M2
Belgium
38
Same issue with my car, but tires really worn at the outside side of front right tire. A geometry could not fix it. Consequence of track days ;-)
      08-04-2017, 01:55 PM   #167
Rudy@tirerack
Originally Posted by MRufo View Post
Keith,
Thanks,
Martin
We typically would have noticed if there was a problem with the product when we balanced the package before shipping to you. Although, it is possible we missed something. Please contact customer service ASAP. 800-428-8355 ext 4360. They will be able to work with you to find a solution.
Thanks!
      08-11-2017, 06:52 AM   #168
Twt
Twt's Avatar
633
Drives: 2017 M2
Turner spacer
I just did a test fit of the Turner 7.5 spacer....amazing quality. I am running on MP coilovers with -3.2 camber, TR 18 wheels and 275/35/18 Hoosier R7s... a smaller spacer would rub on the adjustment collar :
      08-11-2017, 06:55 AM   #169
Twt
Twt's Avatar
633
Drives: 2017 M2
This shows the clearance with the 7.5 spacer:
      10-08-2017, 06:04 PM   #170
serrated
Are the stock center caps supposed to fit? Mine don't seem like they're even close, and the wheels didn't ship with any and the paperwork doesn't say anything
Edit: the page for those wheels on your website shows center caps included at no cost. God damn it -.-
      10-09-2017, 02:00 PM   #171
GinsMarc
GinsMarc's Avatar
Drives: 2017 BMW M2
I bought some Apex 18X9.5" ET28. Do you know if I go with a 265 Sq setup will i need a camber plates in the front for 265/35ZR18?
      02-20-2018, 08:25 PM   #172
BAN_M2C
BAN_M2C's Avatar
4155
1987 BMW 325is  [10.00]
2004 BMW X3  [6.50]
2018 Porsche 911 GT3  [10.00]
1974 BMW 2002tii  [10.00]
2004 BMW M3  [10.00]
Originally Posted by Rudy@tirerack View Post
Messaged you about 4 days ago to confirm price on a set of C4s wrapped in RE71Rs can you please back to me?
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii
      02-21-2018, 01:08 PM   #173
DLag30
Drives: F80M3 & F36
I tried emailing you guys for a black set. It appears Keith is no longer with Tirerack as I got a automated reply redirecting me to sales. Is there a new contact we can place our order?
Thanks
      02-21-2018, 01:56 PM   #174
ZM2
Drives: 2017 LBB M2
Just wanted to chime in that I had a set of these and had to trash them after 10 track days. It seems the heat, curbs, and the M2s weight warped them out of true.
My Apex’s are holding up much better.
      02-21-2018, 03:21 PM   #175
greasypeanut
Drives: F87
You can just email rudy himself. His email is sn. I ordered some last December. Have worked well for me the past two track days and one autox. I have mine wrapped in federal rs-rr
      03-05-2018, 08:08 AM   #176
BAN_M2C
BAN_M2C's Avatar
4155
2004 BMW X3  [6.50]
2004 BMW M3  [10.00]
Thanks for the feedback! Reading this and seeing no follow up from them might be a signal.
I know Keith is no longer around since I got the automated reply but that's why this new account had been posting on this thread.
Follow me on IG
rich8566608.50
