07-04-2016, 06:35 PM | #1 |
3841
Rep 54,349
Drives: F80 M3
HP Autosport ||Macht Schnell Competition Wheel Spacer Kit
Machined from 6061-T6 aerospace aluminum, these adapters are strong as well as lightweight to limit unsprung/reciprocating weight for maximum performance on or off the track. Spacer edges are also chamfered to allow for easy installation/removal if needed. After machining, the spacers are then anodized for additional strength, anti-corrosion & wear resistance.
A wider track stance increases lateral stability as well as giving your BMW a much more aggressive appearance after installation. Spacers also are used to correct wheel gap normally seen on otherwise stock suspension setups, pushing the wheels outward - filling the fenders. Included with our Competition Wheel Spacer Kits are a full set of extended lug bolts. All wheel fasteners are hardened and tempered to strength class 10.9 or 10 according to DIN/ISO standard 898 and meet the statutory requirements of all countries - including the US. Competition Wheel Spacer kit Features: - Machined from 6061-T6 aerospace aluminum - Chamfered edges allows installation & removal quick and easy - Black anodized finish for additional strength and corrosion/wear resistance - Improve handling by reducing body roll with a wider wheel base - Included zinc plated corrosion-resistant wheel fasteners Competition Wheel Spacer kit Contents: - (2) Competition Wheel Spacers - (10) extended-length zinc plated coated wheel fasteners Price starts at $49 Order here: http://www.hpashop.com/Macht-Schnell...pacers-bmw.htm Last edited by HP Autosport; 01-03-2017 at 04:41 PM.. |
