01-12-2023, 03:18 PM | #23 |
Rep 1
Hi guys this is my first post so if I am doing something wrong let me know.
I have an M2 45K miles. I have upgraded charge pipe, intercooler, high flow cat exhaust. Parts installed 2 weeks ago. I was running Bootmod3 stage 1 for 2 months and runs fine. After installing parts I upgraded to Stage 2 Bootmod3. There is a. It that says you need HPFP for stage 2, I went and edited the tune making sure I selected OEM HPFP before flashing. The issue is It's cold 32°F and less out and since upgrading to stage 2 the car oil temp is not getting above 160°F. The car will start to vibrate and the fans kick in. I ha e a P3 guage and I can see the oil temp at 140-155. Normally oil temperature sits at 210°. I even tripes a code I read with my code reader, "Coolant temperature below thermostat regulating temperature". I am trying to diagnose..I drove to work today and it vibrated again. I flashed to Stage one and went into the office. When I leave work I will see how it drives. Any suggestions on what could cause engine to not warm between Stage 1 and Stage 2 if same tune? I am trying to eliminate if it is thermostat going out or if yout tune related. |
01-13-2023, 02:57 PM | #25 | |
Rep 484
Drives: 2018 M2 6MT
Secondly: in response to your note about “if I am doing something wrong let me know”: your post kinda hijacks this thread. In other words, your post is off the main/original topic of the thread. Your best bet would be to start up a new thread, probably in the Drivetrain / Exhaust / Bolt-ons / Tuning M2 sub-forum. |
imperfectluck426.50 ///MPhatic13862.50 |
01-13-2023, 03:04 PM | #26 |
Rep 484
Drives: 2018 M2 6MT
I’ve noticed this too. I also notice that on my commute — about 20 minutes of constant speed 45 mph driving out in the countryside — it takes most of that 20-minute commute to get the oil temp gauge up to the ¼ mark. At 45mph in 6th gear, the engine speed is below 2K RPM; takes quite for things to warm up at that low engine speed. So, I don’t get to flog her much on my commute because things aren’t really up to temp until just a short distance before I pull into the gates of my employer’s campus. No opportunity to “give it hell” on my daily commute. That’s what the nearby canyons and backroads are for, right!?
01-13-2023, 07:57 PM | #27 | |
Rep 7,298
01-14-2023, 11:52 AM | #28 |
Instructor/Coach
Rep 3
Drives: BMW M2C
Most racing oils in a turbo charged engine break down after 270 degrees. I change my oil religiously after each track weekend.
