03-07-2020, 11:21 AM | #1 |
Rear Admiral
1485
Rep 1,706
Drives: Bavarian Milk Wagon
Only aesthetic thing I prefer on the OG M2 is the more traditional front grille. On the F80 I had the IND color matched grille surrounds and really like the look in person.
On the M2c I decided to paint the surround myself so it gives the two distinct kidneys. Still not a huge fan of center strip painted so went this route to see how it would look. Color isn't a perfect match (need a glossier clear) but it's good enough for me. Last edited by Kankles; 04-01-2020 at 09:51 AM.. |
03-08-2020, 05:21 AM | #3 |
Rear Admiral
1485
Rep 1,706
03-08-2020, 07:35 AM | #4 |
Rep 542
Not something I would do, but I don't think it looks bad. Seems to blend into the car well enough.
I was explaining the BMW kidney grill to my daughter and how the M2C does not have the split that BMW typically does. She said the stock grill looks like a butterfly. lol |
03-08-2020, 07:38 AM | #5 | |
Rear Admiral
1485
Rep 1,706
Her opinion—the painted surround looks better than stock |
IcewaterPete2146.50 |
03-08-2020, 10:52 AM | #6 |
756
Rep 2,149
I like this a lot better than the original and a lot better than just painting the center piece. I think I like it because I'm a fan of the smaller grilles with center opening, painting the whole surround gives the illusion of that.
03-08-2020, 01:24 PM | #7 |
Rear Admiral
1485
Rep 1,706
Yup, that was basically the intent. Give it an overall smaller profile and two distinct kidneys.
03-11-2020, 03:02 PM | #9 |
Rear Admiral
1485
Rep 1,706
03-12-2020, 12:02 AM | #11 |
Rear Admiral
1485
Rep 1,706
Threeebowel31.50 |
03-13-2020, 05:45 PM | #12 | |
Rep 58
I hope you don't mind sharing how you removed the grille. Did it involve removing the bumper or is there a quicker way of doing it? |
03-14-2020, 04:30 AM | #13 | ||
Rear Admiral
1485
Rep 1,706
1. Remove rubber strip covering the front fascia T30 torx screws. 2. Remove six T30 Torx. 3. Pull fascia forward (it's very pliable) and slip hand in. 4. Locate top plastic tabs along grill and push those in and forward while you pull on grille from outside with other hand. (This takes some patience and going back and forth between tabs). 5. While pulling up and out with external hand, push in tabs along bottom of grille. It takes a bit of patience first time you do it. After one time however it becomes a lot easier. |
HSM2C17.00 |
03-14-2020, 04:36 AM | #14 |
Rear Admiral
1485
Rep 1,706
Threeebowel31.50 |
03-14-2020, 12:24 PM | #15 |
Rep 2,067
That looks great.
My main gripe with HS was that the front end didn't look right with the mega kidney. That looks awesome curious how an LBB car would look. Also saw an HS m2 on an overcast day for the first time and man it really does its thing in that lighting. |
Kankles1484.50 |
03-14-2020, 12:30 PM | #16 | |
Rear Admiral
1485
Rep 1,706
My thought was this, it's 115 euro for a new grille surround if I don't like it (I do, very much). Probably even cheaper in the US. If I don't like it it's easy to go back to OEM. For LBB I'm sure it would look awesome, just make sure to get a good glossy clear to go with the LBB OEM spray can. Also, the prep (scuffing/cleaning) is probably most important step. |
TrentMeister2860.00 |
03-20-2020, 12:04 PM | #19 | |
Rear Admiral
1485
Rep 1,706
Great minds! Haha |
twin fed1175.50 |
01-07-2024, 08:55 PM | #21 |
Rep 1,530
So glad I found this thread. I’ve been thinking about painting the center strip for the past three years, but now I’m a convert to your concept. Thanks!
